Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Front Dana 60, weld, spool or locker?
View Single Post
Old 08-15-2006, 08:25 AM   #18 (permalink)
rcurrier44
Member # 15404
Originally Posted by Mh4Runner
The cancellation of the joints center leaving centerline is only achieved if there are two joints on the shaft. An axleshaft with just one joint on it has no clue what the other side axleshaft is doing if it is lined up or not.
When you run a spool/welded both front shafts are basicaly the same shaft since they are solidly hooked together....so you have 2 u-joints...one on the left side and one on the right side.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
