Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - Fairly well researched hydro steering question
View Single Post
Old 03-20-2007, 07:17 PM   #3 (permalink)
BillaVista
Member # 3547
When you say "it takes too many turns" do you mean on paper, or in practice?
First - your pump is undersized - whether you change your steering unit or not the pump needs to be upgraded.
If you go to a steering unit with greater cu in/rev you will certainly need a pump capable of greater flow. If not, you will steer and then lose all power until the pump can catch up.
BillaVista is offline   Reply With Quote
