Pirate4x4.Com : 4x4 and Off-Road Forum - View Single Post - complete bypass of toy ignitor and coil for 30$
View Single Post
Old 12-29-2008, 08:50 PM   #78 (permalink)
kjvforme
Member # 126074
An update from my last post the resistor was in fact a 1K Ohm. I soldered a new resistor on the C terminal of the module and connected it to the yellow wire. A closer inspection of the Coil shows it needing a external resistor. Made a trip to Scrapa (NAPA) an picked up a external resistor. Hooked it all up and the tach works, but the engine is still stalling. In fact I think it's gotten worse. I checked the grounds with my fluke meter on continuity and everything is good to go on the grounds. What is causing this thing not to work. People I would love to finish this post with an exact set of instruction on how to make the toyota to GM swap work. SOme of you have made this thing work, please help, thanks.
kjvforme is offline   Reply With Quote
