New Revolution Gearing packages available now! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 04-14-2016, 01:36 PM   #1 (permalink)
Customer Service #1
SweetCJ7's Avatar
Member # 600
Arrow New Revolution Gearing packages available now!
Lot's of new package deals for you guys. Same warranty, same quality, same everything. Free Shipping as always for these. California residents add 7.5% sales tax.
For a limited time only, mention Pirate4x4.com and get 10% off pricing below.
Jeep Packages:
Rev-JK-Non-456 JK Non Rubicon (D44/D30) 4.56 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Non-488 JK Non Rubicon (D44/D30) 4.88 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Non-513 JK Non Rubicon (D44/D30) 5.13 gear package front & rear with master overhaul kits (Front case required for factory 3.21 ratio only) $604.80
Rev-JK-Rub-411 JK Rubicon (D44/D44) 4.11 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-456 JK Rubicon (D44/D44) 4.56 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-488 JK Rubicon (D44/D44) 4.88 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-513 JK Rubicon (D44/D44) 5.13 gear package front & rear with master overhaul kits $660.15
Rev-JK-Rub-538 JK Rubicon (D44/D44) 5.38 gear package front & rear with master overhaul kits $660.15
Rev-TJ-D35-373 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 3.73 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-410 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-456 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-488 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D35-513 Jeep TJ & 96-04 Grand Cherokee (D35/D30) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-TJ-D44-373 Jeep TJ (D44/D30) 3.73 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-410 Jeep TJ (D44/D30) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-456 Jeep TJ (D44/D30) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-488 Jeep TJ (D44/D30) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-D44-513 Jeep TJ (D44/D30) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $519.75
Rev-TJ-Rub-456 Jeep TJ Rubicon 4.56 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-488 Jeep TJ Rubicon 4.88 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-513 Jeep TJ Rubicon 5.13 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-TJ-Rub-538 Jeep TJ Rubicon 5.38 gear package front & rear with master overhaul kits (Comes with thick gears so no carriers needed) $573.75
Rev-YJ/XJ-D35-410 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-456 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-488 Jeep YJ/XJ 84-96 (D35/D30 reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D35-513 Jeep YJ/XJ 84-96 (D35/D30 reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $492.75
Rev-YJ/XJ-D44-410 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-456 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-488 Jeep YJ/XJ 87-96 (D44/D30 reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-YJ/XJ-D44-513 Jeep YJ/XJ 87-96 (D44/D30 reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier cases) $506.25
Rev-XJ-8.25-410 Jeep XJ 91-99 (8.25/D30reverse) 4.10 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-456 Jeep XJ 91-99 (8.25/D30reverse) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-488 Jeep XJ 91-99 (8.25/D30reverse) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25-513 Jeep XJ 91-99 (8.25/D30reverse) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-373 Jeep XJ 96-01 (8.25/D30 short) 3.73 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-410 Jeep XJ 96-01 (8.25/D30 short) 4.11 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-456 Jeep XJ 96-01 (8.25/D30 short) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-488 Jeep XJ 96-01 (8.25/D30 short) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-8.25/D30S-513 Jeep XJ 96-01 (8.25/D30 short) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $538.65
Rev-XJ-D35/D30S-373 Jeep XJ 96-01 (D35/D30 short) 3.73 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-410 Jeep XJ 96-01 (D35/D30 short) 4.10 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-456 Jeep XJ 96-01 (D35/D30 short) 4.56 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-488 Jeep XJ 96-01 (D35/D30 short) 4.88 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-XJ-D35/D30S-513 Jeep XJ 96-01 (D35/D30 short) 5.13 gear package front & rear with master overhaul kits (Does not include carrier case) $498.15
Rev-ZJ/WJ-410 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.10 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-456 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.56 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-488 Jeep Grand Cherokee 96-04 (D44HD/D30short) 4.88 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Rev-ZJ/WJ-513 Jeep Grand Cherokee 96-04 (D44HD/D30short) 5.13 Gear Package Front & Rear Gears & Master Kits (no front carrier) $681.75
Toyota Packages:
Rev-FJ-8.2-W/lock-456 Toyota w/factory locker 2010 & up FJ, 10 & Up 4runner (8.2/8ifs) 4.56 Gear Package Front & Rear Gears and Master Kits (thick front gear to fit 3.73 & down case) $1,086.75
Rev-FJ-8.2-W/lock-488 Toyota w/factory locker 2010 & up FJ, 10 & Up 4runner (8.2/8ifs) 4.88 Gear Package Front & Rear Gears and Master Kits (thick front gear to fit 3.73 & down case) $1,086.75
Rev-FJ-8.2-W/o-Lock-456 Toyota w/o factory locker 2010 & up FJ, 2010 & Up 4runner (8.2/8ifs) 4.56 Gear Package Front & Rear Gears and Master Kits (thick front gear to fit 3.73 & down case) $1,019.25
Rev-FJ-8.2-W/o-Lock-488 Toyota w/o factory locker 2010 & up FJ, 2010 & Up 4runner (8.2/8ifs) 4.88 Gear Package Front & Rear Gears and Master Kits (thick front gear to fit 3.73 & down case) $1,019.25
Rev-FJ-W/lock-456 Toyota w/factory locker 07-09 FJ, 05 & Up Tacoma, 03-08 4runner (8/8ifs) 4.56 Gear Package front & rear gears and master kits (thick front gear to fit 3.73 & down case) $965.25
Rev-FJ-W/lock-488 Toyota w/factory locker 07-09 FJ, 05 & Up Tacoma, 03-08 4runner (8/8ifs) 4.88 Gear Package front & rear gears and master kits (thick front gear to fit 3.73 & down case) $965.25
Rev-FJ-W/o-Lock-456 Toyota w/o factory locker 07-09 FJ, 05 & Up Tacoma, 03-08 4runner (8/8ifs) 4.56 Gear Package front & rear gears and master kits (thick front gear to fit 3.73 & down case) $864.00
Rev-FJ-W/o-Lock-488 Toyota w/o factory locker 07-09 FJ, 05 & Up Tacoma, 03-08 4runner (8/8ifs) 4.88 Gear Package front & rear gears and master kits (thick front gear to fit 3.73 & down case) $864.00
Rev-Taco-Late-W/o-Lock-456 Toyota Tacoma 2005 & Up (8.4/8ifs) 4.56Gear Package Front & Rear Gears & Master Kits $903.15
Rev-Taco-Late-W/o-Lock-488 Toyota Tacoma 2005 & Up (8.4/8ifs) 4.88 Gear Package Front & Rear Gears & Master Kits $903.15
Rev-Taco-W/o-Lock-456 Toyota Tacoma 95-04, Tundra 00-06 W/out Factory Locker (8.4/7.5reverse) 4.56 Gear Package Front & Rear Gears and Master Kits $799.20
Rev-Taco-W/o-Lock-488 Toyota Tacoma 95-04, Tundra 00-06 W/out Factory Locker (8.4/7.5reverse) 4.88 Gear Package Front & Rear Gears and Master Kits $799.20
Rev-Taco-W/o-Lock-529 Toyota Tacoma 95-04, Tundra 00-06 W/out Factory Locker (8.4/7.5reverse) 5.29 Gear Package Front & Rear Gears and Master Kits $799.20
Rev-TLC-488 Toyota Land Cruiser 69-90 (9.5/9.5) 4.88 Gear Package Front & Rear Gears & Master Kits $911.25
Rev-TLC-529 Toyota Land Cruiser 69-90 (9.5/9.5) 5.29 Gear Package Front & Rear Gears & Master Kits $911.25
Rev-TLC100-W/lock-488 Toyota Land Cruiser 100 series w/factory locker 98-02 only (9.5/8reverse) 4.88 Gear Package Front & Rear Gears and Master Kits (not available for 03-07) $1,147.50
Rev-TLC100-W/o-Lock-488 Toyota Land Cruiser 100 series w/o factory locker 98-02 only (9.5/8reverse) 4.88 Gear Package Front & Rear gears and master kits (not available for 03-07) $1,147.50
Rev-TLC200-488 Toyota 08 & Up Land Cruiser and 07 & Up Tundra with 4.6L/4.7L engine (9.5/9reverse) 4.88 Gear Package Front & Rear Gears & Master Kits $1,348.65
Rev-TLC80-W/lock-488 Toyota Land Cruiser 91-97 With Factory Locker (9.5/8reverse) 4.88 Gear Package Front & Rear gears and Master Kits $946.35
Rev-TLC80-W/lock-529 Toyota Land Cruiser 91-97 With Factory Locker (9.5/8reverse) 5.29 Gear Package Front & Rear gears and Master Kits $946.35
Rev-TLC80-W/o-Lock-488 Toyota Land Cruiser 91-97 With Factory Locker (9.5/8reverse) 4.88 Gear Package Front & Rear Gears and Master Kits $946.35
Rev-TLC80-W/o-Lock-529 Toyota Land Cruiser 91-97 With Factory Locker (9.5/8reverse) 5.29 Gear Package Front & Rear Gears and Master Kits $946.35
Rev-Tundra-488 Toyota Tundra 2007 & Up (10.5/9reverse) 4.88 Gear Package Front & Rear Gears & Master Kits $1,470.15
Rev-Tundra-9.5-488 Toyota Tunda 07 & Up w/ 4.6L or 4.7L 4.88 Gear Package Front & Rear Gears & Master Kits $1,470.15
Dodge Truck:
Rev-Dodge-1500-410 94-01 Dodge 1500 (9.25/D44) 4.10 Gear Package Front & Rear Gears & Master Kits (no front carrier included) $639.90
Rev-Dodge-1500-456 94-01 Dodge 1500 (9.25/D44) 4.56 Gear Package Front & Rear Gears & Master Kits (no front carrier included) $639.90
Rev-Dodge-1500-488 94-01 Dodge 1500 (9.25/D44) 4.88 Gear Package Front & Rear Gears & Master Kits (no front carrier included) $639.90
Chevy Truck:
Rev-Chevy-1500-410 88-98 Chevy 1500 (8.5/8.25) 4.10 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-456 88-98 Chevy 1500 (8.5/8.25) 4.56 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-488 88-98 Chevy 1500 (8.5/8.25) 4.88 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-513 88-98 Chevy 1500 (8.5/8.25) 5.13 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-8.6-410 99-08 Chevy 1500 (8.6/8.25) 4.10 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-8.6-456 99-08 Chevy 1500 (8.6/8.25) 4.56 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-8.6-488 99-08 Chevy 1500 (8.6/8.25) 4.88 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-8.6-513 99-08 Chevy 1500 (8.6/8.25) 5.13 Gear Package Front & Rear Gears & Master Kits $533.25
Rev-Chevy-1500-Late-410 2009 & Up Chevy 1500 (8.6/8.25) 4.10 Gear Package Front & Rear Gears & Master Kits $579.15
Rev-Chevy-1500-Late-456 2009 & Up Chevy 1500 (8.6/8.25) 4.56 Gear Package Front & Rear Gears & Master Kits $579.15
Rev-Chevy-1500-Late-488 2009 & Up Chevy 1500 (8.6/8.25) 4.88 Gear Package Front & Rear Gears & Master Kits $579.15
Rev-Chevy-1500-Late-513 2009 & Up Chevy 1500 (8.6/8.25) 5.13 Gear Package Front & Rear Gears & Master Kits $579.15
Let me know if you want/need a carrier or locker. Now online at Allen's Offroad. Use coupon code "REVPKG10" at checkout for the additional savings.
Have a blessed and prosperous day!
Allen
Allen's Offroad - 530-620-1100 Email me at:
FREE SHIPPING on orders of $99.99 or more.
SweetCJ7 is offline   Reply With Quote Quick reply to this message
Old 04-15-2016, 10:28 AM   #2 (permalink)
Customer Service #1
SweetCJ7's Avatar
Member # 600
Allen
Old 07-15-2016, 11:11 AM   #3 (permalink)
Customer Service #1
SweetCJ7's Avatar
Member # 600
I know someone needs or wants to regear. Check out the deals from Allen's Offroad on Revolution gears.
Have a great day!
Allen
