Dana 60 or 14 bolt disc brake kit $315 shipped - Page 39 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Axles/Tires/Wheels
Old 08-07-2018, 09:05 AM   #951 (permalink)
Member # 466497
Thank you very much for the reply. An add came up on Facebook for the (4) 38.5x16 Gumbo mudders on 16.5 rims (8 on 6.5 lug pattern) for $200. I didn't know if they would or not. But for $200, I could resell them if need be.. Thank you again for the reply.
Bigboyztj is offline   Reply With Quote Quick reply to this message
Old 08-10-2018, 11:33 PM   #952 (permalink)
Member # 164139
When will you have the parking brake calipers in stock? Every time I look they are out of stock.
Bruce 1 is offline   Reply With Quote Quick reply to this message
Old 08-11-2018, 03:44 AM   #953 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I have 300 sets on order. They are supposed to be here the end of September, but I wouldn't be surprised if there is a delay.
Dana 60 or 14 bolt disk brake kits $315 shipped -->
Dana 70 kits $300 -->
. . Sterling 10.25 kits $390 -->
Dana 60 front 3/4 ton kits $295-->
GubNi is offline   Reply With Quote Quick reply to this message
Old 08-11-2018, 04:39 PM   #954 (permalink)
Member # 717698
Does the 14 bolt kit have a required max wheel backspacing?
fur_pig is offline   Reply With Quote Quick reply to this message
Old 08-13-2018, 07:57 AM   #955 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
It depends in wheel size.
15" I recommend 3" or less. 3.5" is possible with grinding. More than 3.5" requires wheel spacers.
16" or bigger I have never seen a problem with backspacing.
Old 08-16-2018, 08:45 AM   #956 (permalink)
Ol'Customcj7's Avatar
Member # 43637
Saw the delay. Is there a long wait line? Chances of getting some if I order?
Need some 14bolt calipers with Ebrake.
[QUOTE=PAToyota;19894137]Back in college, we were making up acetylene balloons and putting them in a box to take off to light. Guy comes into the room, goes "Balloons!" and grabs a balloon, rubs it on his head, and sticks it to the wall... Everyone was diving for cover... :D[/QUOTE]
Ol'Customcj7 is offline   Reply With Quote Quick reply to this message
Old 08-16-2018, 08:58 AM   #957 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Your chances are 100%. I have several people that have put them on back order. I just don't have an exact date. I am expecting them late September or early October.
Another option is to place the order with coupon code ebrake. I will ship everything but the bare left caliper. Several people have done that and have been able to source that caliper themself. The part number is 18-4117.
Old 08-16-2018, 09:08 AM   #958 (permalink)
Member # 43637
I can take this to PM. I've already got a full disc brake setup, but I would like to put an E-brake back on it. Your kit is the E-brake caliper right? Or brake in hat style?
I've also get to be sure on what date range my 14bolt is. Been so long, I've forgotten.
Old 08-16-2018, 09:26 AM   #959 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Yes, PM would probably be best.
Date doesn't matter unless it's 87 or older. They made the older style brakes with drum behind the hub from 73-2000 and the newer brakes style with slide off drums from 88-2000.
My kit uses an emergency brake caliper from a 76 Cadillac Eldorado.
Old 10-13-2018, 09:59 AM   #960 (permalink)
Member # 322937
btt
Hey whats the shipping weight of a Front Chevy Dana 60 kit and 14 Bolt Rear kit both to fit 15x10 3.5BS wheels?
Need weights for my freight forwarding company as I don't live in the US
R0CKY is offline   Reply With Quote Quick reply to this message
Old 10-13-2018, 10:04 AM   #961 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
The weight is about 71 lbs per kit, so a 142 pounds for both.
Old 11-27-2018, 09:11 AM   #962 (permalink)
Member # 859822
E-Brake calipers
I did a rear conversion already, but couldn't find the e-brake calipers. Do you sell just the calipers with the e-brake?
JonMatrix is offline   Reply With Quote Quick reply to this message
Old 11-27-2018, 09:21 AM   #963 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I am out of them at the moment. I have 300 on order though.
Old 12-11-2018, 10:20 AM   #964 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Emergency brake calipers should be here in about a month. Here a first picture. They will ship complete with hardware and springs to make them work.
Old 12-11-2018, 10:45 AM   #965 (permalink)
Member # 214685
You offer a kit for the newer style 14b? Mine has factory discs and I’d like to save a little weight.
The factory calipers are huge, I don’t see a need for them as the buggy is lighter than the original vehicle the axle came out of.
Byro is offline   Reply With Quote Quick reply to this message
Old 12-11-2018, 10:50 AM   #966 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I do offer kits for the newer style 14 bolt with drum brakes. I do not offer a kit for an axle with factory disc brakes yet. It's in the works for 2019 though.
Old 12-13-2018, 07:06 AM   #967 (permalink)
Member # 859822
GubNi, Put me down for a set once you get them in. Shoot me a post when they arrive. When do you expect them in?
Old 12-13-2018, 07:08 AM   #968 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
PM me your email address and I certainly will.
Old 02-02-2019, 09:13 AM   #969 (permalink)
Member # 164139
When will the emergency calipers be in? Do you have a update?
Old 02-02-2019, 11:24 AM   #970 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I am expecting them the first week of March
Old 02-12-2019, 03:41 AM   #971 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Btt
Old 02-19-2019, 08:32 AM   #972 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
btt
Old 02-24-2019, 05:46 AM   #973 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
btt
Old 03-02-2019, 04:42 AM   #974 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
btt
Old 03-10-2019, 03:46 PM   #975 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Btt
