Balljoint 60 Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Ballistic Zone
Old 10-20-2009, 10:50 PM   #1 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Balljoint 60 Build
I think it's out of a 02 Superduty...
I plan on takin down the housing a few inches on the short drivers side. And having it welded up to the tube and the cast.
The day I brought him home, he's so cute....
Not much room there...
Had to bring him in the house for the night...
MY BUILD
04 Rubicant Ultra4
My precious.... 72 K5 Blazer
web wheeler...
DJ404564X4 is offline   Quick reply to this message
Old 10-20-2009, 10:53 PM   #2 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Got some Solid knuckles...
and Rockstomper brake brakets...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 10-20-2009, 10:55 PM   #3 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Had a well built 44. Why this?
yes, those would be my dress Vans...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 10-20-2009, 10:57 PM   #4 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Gotta love the sand blaster...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 10-20-2009, 10:59 PM   #5 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Ok, I'm sure your askin why I'm in here??
This
That
en Dis
Make THIS!
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 10-20-2009, 11:10 PM   #6 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Once I figure out how tall I need them to be I'll order up some of these upper control arm mounts, and have one welded to the housing.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 10-21-2009, 07:36 AM   #7 (permalink)
Banned
DrVic723's Avatar
Member # 46226
Thanks for the build thread, let us know if you have questions about our product or need some general advise.
Jeff
DrVic723 is offline   Quick reply to this message
Old 10-21-2009, 09:26 AM   #8 (permalink)
Member # 40665
Send a message via Yahoo to joe_and_jeep
I'm building an '03 Superduty 60. Subscribed. I ended up getting 97 I think ball joint knuckles and getting D50 outer. Curious to see how u cut the drivers side.
I Like Boobs
joe_and_jeep is offline   Quick reply to this message
Old 11-29-2009, 04:25 PM   #9 (permalink)
Member # 15499
Send a message via AIM to Mattsyj7
BUMP.
Any updates?
Im thinking about building a BJ 60 for under My TJ and would like to see some pics of this bracket kit installed.
Mattsyj7 is offline   Quick reply to this message
Old 11-29-2009, 04:37 PM   #10 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
should be starting on it this week. my welder has been tied up over the last couple of weeks.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 11-29-2009, 08:50 PM   #11 (permalink)
Member # 135950
i am trying to figure out the same damn thing. have the same axle and trying to put it under my jk. driverside gives me no damn room for lower control arms and spring perch. keep it coming
jerzeyjeep is offline   Quick reply to this message
Old 12-04-2009, 05:44 PM   #12 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
cuts will be something like this...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-04-2009, 07:09 PM   #13 (permalink)
Member # 129208
Looks good man...subscribing for updates.
97 SAS'd Ranger
DB_1 is offline   Quick reply to this message
Old 12-04-2009, 08:04 PM   #14 (permalink)
TrailTamer XJ's Avatar
Member # 140878
i sometime wonders why nobody want to extend the short side by cut the tube then length it by using a internal sleeve that fit inside the tubes then weld it up shut so you should have much more room to work with?? similar to this from greatlakes4x4.com
http://www.greatlakes4x4.com/showthread.php?t=67134
Originally Posted by Jeepaholic View Post
Though I would do a write up of sorts on the dana 30 I built.
The goal was to use all easy to get parts, IE stock tj inners. But to also have high steer and lockouts. And not have to build another truss for the driver side uca :stan3: . Started out as a Xj hp 30, you will also need a cj dana 30 for tubes and inner C's, and dana 44 knuckles and hubs.
First cut these off
I used the shafts to measure for the amount of tube I needed to leave on the CJ dana 30 knuckles
Cut
Doing the other side
Mocked up
I used 2" 1/8" wall dom as a internal sleeve
TrailTamer XJ is offline   Quick reply to this message
Old 12-04-2009, 08:05 PM   #15 (permalink)
Member # 140878
One side done
Just a couple of brackets left to weld on.
tell me why this wont work
Old 12-04-2009, 08:42 PM   #16 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
nice job.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-04-2009, 08:44 PM   #17 (permalink)
Member # 140878
Originally Posted by DJ404564X4 View Post
nice job.
the links above on that axle are not my axle FYI. I just want to learn how guys get around in here and wonders why I dont see anybody do similar thing to their D60 instead of the D30. I hope I dont pull anyone's chain
Old 12-04-2009, 08:46 PM   #18 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
not my axle FYI, just want to learn how guys get around in here. I hope I dont pull anyone's chain
i caught that, good idea. i want to be able to get stock parts.
no odd ball axles.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-04-2009, 08:52 PM   #19 (permalink)
Member # 140878
I am no expert on the axle shafts but I'd image that its possible to get the driver side lengthened to a certain point so that using the 78'/79' driver side inner axle shaft would fit?
Old 12-06-2009, 05:32 PM   #20 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Phil started cleaning...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-06-2009, 05:33 PM   #21 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
a little cutting...
THIS GOT WELDED UP>>>
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-06-2009, 05:34 PM   #22 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
a little test fitting...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-06-2009, 07:23 PM   #23 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-06-2009, 07:24 PM   #24 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-08-2009, 11:08 AM   #25 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
got my Ballistic uppers...
Phil plans on making up his own truss, this should be good....
MY BUILD
04 Rubicant Ultra4
web wheeler...
