Artec Industries 2.0 Turbo JLU Belly Pan - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Body/Armor
Old 05-29-2019, 10:42 AM   #1 (permalink)
InArtecWeTruss
Artec's Avatar
Member # 117381
ALUMINUM SKID PLATES FOR HEAVY DUTY YET LIGHTWEIGHT PROTECTION.
At a total of 91 lbs, the total net weight is only 15 lbs more than factory skids but much heavier duty and more complete coverage.
Artec Industries' NEW JL Bellypan is designed to give your 2018+ Jeep JLU Wrangler 2.0L Turbo full protection underneath the vehicle. Designed using CAD files directly from the manufacturer, this belly pan skid plate ensures that you have a great fit with factory components. Made from 1/4" thick 6061 Aluminum and 3/16" zinc plated Steel, and CNC cut and formed, the Artec JL Bellypan Kit offers both a strong and lightweight solution for your new Jeep JL.
Adds only 15 lbs to net weight of vehicle yet covers far more and is heavier duty than factory skids
91 lbs total weight compared to the Steel version at 163 lbs...a 44% weight savings
Increases ground clearance of 3/4" from factory skids and even more compared to other aftermarket skid plates
1/4" 6061 Aluminum for skid plates, 3/16" zinc plated steel brackets
Includes 1/4" thick Aluminum skid plate for 48 volt E-Torque battery system
Designed from factory CAD files for great and ultra precise fit.
CNC laser cut and CNC formed using custom rolled dies for high strength, unique look, and perfect contour fitment to OEM components.
All bolts under skid plate are countersunk for absolutely smooth bottom
All nuts are pressed into steel brackets for easy, one tool removal
Bolts directly to OEM T-case crossmember and frame using heavy duty flat head bolts that match OEM thread
No need for an aftermarket T-case crossmember for completely flat surface
Modular design lets you take off only one section for vehicle servicing
Protects Oil Pan, Transmission Pan, Gas Tank, Front Exhaust, Transfer Case, E-Torque Battery
OEM gas tank skid is replaced for reduced weight and 3/4" higher clearance*
Artec Gas tank skid can be removed without dropping entire tank thanks to new additional cross-member and tank strap.
Clearance near rear drive yoke shaft to prevent rubbing
*OEM gas tank skid removal required. For easiest install, remove skid when tank is near empty. See instructions for simple ideas on removing OEM gas tank skid.
On sale$1,799.99
PREORDER - Shipments begin June 28th
Part Number:JL4102
https://youtu.be/js3GCjhrABM
ARTEC INDUSTRIES
1-855-ARTEC99
Like us on
Quick Links:
Artec is offline   Reply With Quote Quick reply to this message
Old 09-06-2019, 06:20 AM   #2 (permalink)
Member # 872560
clean...I like
Jackalope Sean is offline   Reply With Quote Quick reply to this message
