Allison to np205 - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-12-2014, 11:13 PM   #26 (permalink)
Member # 84454
Originally Posted by carslut View Post
who has successfully ran the vss in the tail housing of there t-case?
GM, for starters. I know of several swaps that are running the VSS in the t-case, but none are using the Destroked setup.
[QUOTE=-Dex-;13278433]You're the kind of guy who isn't happy with just sticking a finger up his ass while jacking off, you have to pull it out and smell it afterwards too don't you?[/QUOTE]
MaxPF is offline   Reply With Quote Quick reply to this message
Old 12-13-2014, 05:09 AM   #27 (permalink)
Member # 214231
I almost started this very same build..but got side tracked due things ...(life, kids, job,etc,etc..) and have prolly read and reread every single build thread i could find about this subject...maxpf has been a wealth of knowledge about allisons and 205's...i also checked out http://www.howards-conversions-allison.com/...this guys has some good parts aswell...def worth calling and talking to him...just my 2 cents...please post up some pics when you get rolling on this build...
steve
sebaeb is offline   Reply With Quote Quick reply to this message
Old 12-27-2014, 10:21 PM   #28 (permalink)
Member # 206522
Since this is allison tech thread, i have a stak4x4 2-speed 29 spline input made specially for the allison trans. It has a reluctor ring and vss. Its at the classifieds for sale. Thanks
urmaster85 is offline   Reply With Quote Quick reply to this message
Old 12-28-2014, 12:46 PM   #29 (permalink)
Member # 83634
should be cool when its done, I also had started this same project years ago but the lack of after market parts to make it an easy swap I gave up and sold everything, i find it cheaper and easier to just use the duramax Allison combo good luck with the build
84 K30 tubed truggy, duramax swap, 2.5 rockwells 18.4x16.1 tractor tires
07 classic duramax
07 classic duramax service truck
80 big block vette
84 western star 4964 8V92 detroit diesel 13 speed
84 chevy stepside 454 slow build
chevypower is offline   Reply With Quote Quick reply to this message
Old 01-04-2015, 04:29 PM   #30 (permalink)
pvkj454's Avatar
Member # 73302
This is the first place that I have seen that 1995 was the year that the NP241 gear cut changed. I have a 2000 Series Allison and controller to replace the NV4500 in my Cummins powered Chevy K30. I have the Chevy 4x4 tail housing and output shaft and my K30 already has a RH drop NP241 with a VSS. Too bad the date code on my parts 241DLD is from 2001.
pvkj454 is offline   Reply With Quote Quick reply to this message
Old 01-04-2015, 07:14 PM   #31 (permalink)
Member # 122902
The input shaft and bearing are only about $150 to make the early 241c 29 spline from Midwest transmission center
eric_banks32 is offline   Reply With Quote Quick reply to this message
Old 08-18-2015, 06:30 AM   #32 (permalink)
Member # 214231
Any updates?
Old 08-18-2015, 03:55 PM   #33 (permalink)
Member # 122902
Project got stalled for the time being. Not sure when or if I'll start working on it again.
Old 11-08-2016, 07:51 PM   #34 (permalink)
Member # 10144
Originally Posted by DieselS10 View Post
I mounted the VSS in the tail housing of my Allison and the reluctor ring over the front of the input gear of the front 241. Couldn't run it in the rear due to the doubler, but it works flawlessly in front of the cases. The speedometer just isn't anywhere close when in low.
Has anyone else here mounted the VSS in tail housing of the Allison? I'm doing a build and that's what I'm thinking.
not4show is offline   Reply With Quote Quick reply to this message
