Member # 843697
YJ SBC swap overheat no matter what
Hello all, I have a YJ that I swapped a TBI 350 in with a Holley 600cfm. My issue here is that it always overheats on the highway but not at idle. The fan properly cycles and cools the fluid at idle but as soon as I start moving the temp creeps up (250) within a few miles. The few trips I took when it was still cold out (30s and 40s) were a little on the warm side (210) but not over heating. My setup is as follows:
350 out of a 92 k1500 with a serpentine belt setup. New water pump from local store Aluminium radiator with approximately 18in x 19in fin area 3 core (new) with 16lb cap Derale 2400cfm electric puller fan sucking air through the radiator properly 180* Thermostat (new and tested to be working with a 3/32 hole drilled to vent air pockets) New head gaskets (which I'm fairly certain can't be installed backwards/upside down on this engine) 50/50 coolant - burped SUM-226016 intake manifold and SUM-G2410 gasket Timing without vacuum is appx 10-12* at idle then maxes out at about 30-35* with vacuum advance connected to a full vacuum port bumps both up about 10* with about 24in of vacuum at idle I'm running at about 12-14 afr as it bounces around a bit. I've tested the cooling system for exhaust gases by using one of those fancy vacuum tubes with the color changing fluid (no exhaust in coolant). I have looked at the water pumps by pulling the back off and both pumps spin correctly per a thread on another site that I am unable to link to. The only thing I can think of is the intake or intake gaskets are wrong or the radiator either isn't getting enough flow or isn't efficient enough The one thing I've found peculiar is if I start it and stop it after a less than a minutes, pressure immediately builds slightly to the point where if I pull the cap off coolant sprays all over but there's no presence of exhaust in the coolant. I'm at a complete loss here. Any help would be MUCH appreciated. |
#2 (permalink) | |
Member # 343
Right away I was thinking water pump rotation....but you got that covered. "Generally" overheating at speed is an airflow issue. |
Sponsored Links |
Member # 1792
Got a pic of your radiator set up. But for me I think 2400 cfm is not enough. I have a 3500cfm pusher in my CJ crawler with a sbc406 and it gets warm when hot rodding it. It's fine normally when wheeling.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers. Kid's '70 Jeepster D44/14bolt FF. |
#4 (permalink) | ||
Member # 843697
I ordered a 17 inch flex fan and am gonna try that and see if it helps. I went with the 2400 because the only other one that pushed more air between this one and Spal was meant for paved circle track. I didn't believe the amazon/ebay ones that claimed bigger numbers for $50. also this motor is just a stock 350 TBI with a carb instead and shorty headers that are wrapped. |
Member # 1792
First thing I would try is move the trans cooler to a separate location. This is just adding heat to the radiator.
Member # 343
^^^^ the above. Plus it also sounds like you have a lot of air FLOW restricting articles in the way there too....winch....pusher fan....puller fan. What are they ratings of the pusher fan.
As far as blockage...when you said it builds press in less than a minute, I thought you meant the hoses became pressurized in less than a minute. So, it spits out coolant where, the over flow? |
Member # 843265
Those two fans may be fighting each other.
Try pulling the fuses or turning them off if you have a switch, then try running the truck at speed and see what happens. GM LS factory programming usually turns off all fans at speeds above 45 mph. Also, try another radiator cap even if the one you have is new. If it's burping that quick most likely it's bad. Check heater core for trapped air. "If you can't build it then buy it, either way, hit the trails while you're young enough to enjoy it." Bigger tires and more horsepower are not the answer to all problems, but they sure help!
Your Government cannot grant you "Liberties", it can only defend or destroy them. |
Member # 739689
https://www.speedwaymotors.com/Water...r-Kit,605.html try something like this, or just take an old thermostat and cut the core out and shove it back in, see if you get any change
#10 (permalink) | |
Member # 106377
What water pump, thermostat and radiator cap are you running?
Member # 56430
Opinions;
Electric fans aren't appropriate for cooling at highway speeds. Get a good mechanical fan, big, lots of blades, and a quality clutched fan. Get a shroud. Build one, buy one, whatever. I've got a TJ and YJ both with V8 conversions. Also, my stock replacement radiator cools way better than my $$$ aluminum one. Go figure.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13 Member Eldorado Dust Devils, a PNW4WDA member Last edited by Treeclimber; 05-09-2018 at 06:16 PM. |
#13 (permalink) |
Member # 13786
Are you sure you got the correct reverse rotation water pump? AND get rid of the electric fans and go with a fan clutch and a solid blade fan and a shroud. I used to have a big block 454, 4x tow truck with a bad ass dual electric fan set up, heavy wiring, relays the whole thing. Always overheated no matter what I did. Put the factory style fan system on it and no more problems...ever!
#14 (permalink) | |
Member # 166485
I had a similar issue on my flatty with a sbc. The lower radiator hose was collapsing at higher rpm. do you have a spring in it?
"No Toyota Tech Here" Quote:
#15 (permalink) |
Member # 72951
I ran a stock tbi 350 in my 76 cj7 with a sbc conversion radiator, Ford Taurus fan and never had an issue with it overheating. I had a normal re-man water pump from oreillys and 180* T-stat.
If your yj is anything like my cj was, there probably isn't enough clearance to put in a mech fan. ![]()
04 Ram 1500 qc KPD60 AAM11.5 4.88's bilstein 9300s Hemi 40" Nitto Trails Last edited by mudskipper4x4; 05-12-2018 at 10:46 AM. |
#16 (permalink) | |
Member # 56430
Got mechanical in BOTH my YJ and TJ with V8s. And a big shroud. Plenty of room.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13 Member Eldorado Dust Devils, a PNW4WDA member |
#17 (permalink) | |
Member # 72951
04 Ram 1500 qc KPD60 AAM11.5 4.88's bilstein 9300s Hemi 40" Nitto Trails |
#18 (permalink) | |
Member # 17632
Travis..
18 Ram 2500 4x4 Big C and a 6 speed 73 Dodge W100, 400 4spd, stepside project |
#19 (permalink) | |
Member # 343
Although, admittedly the argument doesn't stop there, rad design and construction carry it on. ![]() |
#21 (permalink) |
Member # 13644
The first thing I'm thinking is water pump rotation... if you open the radiator cap are you able to see that the water is Flowing from the top of the engine to the bottom? It's pretty obvious on my truck which is a 72 engine converted to Serpentine.
The pressure build-up really is strange. That sounds more like the wrong head or intake manifold gaskets.
72 GMC K/30 Jimmy - the toy 99 Chevy K2500 - the tow rig |
#22 (permalink) | ||
Member # 17632
Travis..
#23 (permalink) |
Member # 312354
Considering that engine had a 5-6000CFM mechanical fan and a huge radiator in its original home, I'm going to say that it's an air flow issue and a radiator issue. Assuming the water pump is correct and the thermostat isn't hanging up. Let it idle with the cap off and see if you can see the coolant flow when the thermostat opens up. You could also rev it up to highway RPM's and see if the lower hose is collapsing.
#24 (permalink) | |
Member # 1792
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers. Kid's '70 Jeepster D44/14bolt FF. Last edited by Cheepin; 05-16-2018 at 05:19 PM. |
Thread Tools | |
Display Modes | |
