Grinding front left wheel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-17-2019, 03:33 PM   #1 (permalink)
Member # 240290
Hey guys I get like a groaning grinding sound at low speeds from the front left wheel... I have replaced the wheel bearings and it made no change to this. Brake pads are new so that’s not the issue... could it be the carrier bearings?
Looking for tips thanks guys
Also best way to check those bearings?
Eskimomann209 is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 10:06 PM   #2 (permalink)
Member # 13786
What year?
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 10:30 PM   #3 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Really depends what year, what vehicle etc.
Given your detailed analysis Id say its a fetzer valve.
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 04-18-2019, 02:43 AM   #4 (permalink)
Member # 225201
The 7th Fetzer? I hope so.
Hope he knows it’s all about the Quaker State and ball bearings these days...
Given your detailed analysis I’d say it’s a fetzer valve.
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 04:53 AM   #5 (permalink)
Member # 343
New brake pads can still grind....when the caliper is stuck.
Put old pads on and see if that helps. if you no longer have them try it without brake pads, it shouldn't grind if the pads were at fault. NOTE: Be careful driving as it may pull hard to right at times, especially when you panic....and you WILL....LOL
PS. Best way to check those bearings? Shake them, if they rattle like a can of spray paint...they no good.
cj8scrambld is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 05:29 AM   #6 (permalink)
5TonDreamin's Avatar
Member # 487154
Along with year,make, model.. How are you sure it's coming from the left side? Heard lots of people say their left side is grinding, groaning, moaning, skreeching, etc. and when I'd start looking, it was the right side. Misdirection, being that your closer to the front left at and what not
_________
____ . ... .
________/__/__\____\_,__
|- /\_''______/\-[]===[]
_`(o)_)<>)_)__`(o)_)o==)_)
Mathematics itself operates as Whiteness.
5TonDreamin is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 05:30 AM   #7 (permalink)
mothfuckle
fredycruger's Avatar
Member # 225557
flip the brake pads around
fredycruger is online now   Reply With Quote Quick reply to this message
Old 04-18-2019, 06:20 AM   #8 (permalink)
Member # 213125
Just keep throwing new parts at it. Much easier than actually looking at it to see what needs fixed.
Aisin is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 07:17 AM   #9 (permalink)
Member # 240290
Haha good points gents
It’s a Dana 44 front axle from the 70s Chevy.
The pads were worn which is the reason I swapped them out.
The bearings I have no idea when they were changed so for good measure I switched them out because I didn’t know their history.
PO didn’t mention anything wrong with it.
The calipers on this thing have bad bleeder screws( PO jacked them up with pliers it looks like)
Maybe I’ll try harder to get those off and bleed the brakes to eliminate the calipers as an issue
Old 04-18-2019, 07:21 AM   #10 (permalink)
Member # 240290
That’s possible
I have gotten both wheels off the ground and spun the wheel and didn’t really find anything screaming at me
I checked the wheel for play... took the wheel off and checked the hub for play. Didn’t see much
The driver spindle did look like it took a few hits from a hammer then was filed to get the burrs off?
Old 04-18-2019, 07:27 AM   #11 (permalink)
Member # 13786
Check the front driveshaft at the t-case, may be getting a residual spin of the shaft and find a bad CV. You didn't mention whether or not this is in 2wd or 4wd
Old 04-18-2019, 07:35 AM   #12 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Does it jave the shitty tin dust shields? Is it bent over and rubbing the rotor?
Old 04-18-2019, 09:01 AM   #13 (permalink)
Member # 240290
D44 with front shaft installed
Yes
I’ll check on that too it’s got 20s in so I should be able to see it
Old 04-18-2019, 11:29 AM   #14 (permalink)
Member # 343
Originally Posted by Eskimomann209 View Post
PO didnt mention anything wrong with it.
Wow, that's a rarity!!
Up till this point we didn't know if it was even a 4wd vehicle, let alone if it had a T-case at all...or it being CV equipped! LOL
Old 04-18-2019, 11:32 AM   #15 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
That happened to a long-standing pirate member in the last year.
& Blaine
:tank:
Similar Threads
info on Ford Super Duty Dana 60 axle TrailTamer XJ General 4x4 Discussion 3956 Today 01:51 AM
Revolution Gear packages w/Koyo bearing masters HUGE SALE SweetCJ7 Axles/Tires/Wheels 0 02-02-2017 11:29 AM
Dana 44 Axle ID 85GAJEEPCJ7 Newbie General 4x4 Discussion 12 06-02-2014 11:18 PM
We are now carrying FJ80 Front Wheel Bearing Kits! BigMike Axles/Tires/Wheels 0 05-30-2012 11:36 AM
