Need to Level 2001 Suburban K2500 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2019, 08:35 PM   #1 (permalink)
Member # 539746
Fellas -
Tired of the way my Suburban sits too low up front; only time it sits level is when I'm towing. I understand this is a fairly common issue.
I think all I need are the keys, right? Something like this? https://www.amazon.com/Supreme-Suspe.../dp/B00VVR7DH4
And I should plan on getting an alignment after I'm done, correct?
Anything else I'm missing?
Thanks,
Scott
bulletpruf is offline   Reply With Quote Quick reply to this message
Old 05-26-2019, 08:38 PM   #2 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Crank the torsion bars and get an alignment.
& Blaine
:tank:
Old 05-26-2019, 08:52 PM   #3 (permalink)
Member # 130483
K1500 keys are the same and alot cheaper at any wrecker
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote Quick reply to this message
Old 05-26-2019, 10:11 PM   #4 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Yup, crank the bars and buy 2" longer shocks.
Then look at you sagging ass when youre towing think d'oh.
Old 05-27-2019, 10:09 AM   #5 (permalink)
Member # 52361
You could find those for half the price on amazon, but you won't get the keychain
Buy the $21 torsion bar tool. Or have a 50/50 chance of spending the evening getting stitches
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 05-27-2019, 01:56 PM   #6 (permalink)
Jason4x4's Avatar
Member # 104033
you'll probably wwon't get level with cranking the factory bars, but it will bring it up better. at least mine didn't level.
Jason4x4 is offline   Reply With Quote Quick reply to this message
Old 05-27-2019, 05:15 PM   #7 (permalink)
Member # 539746
Ok, what's the danger of cranking on the torsion bars without the specialty tool?
Old 05-27-2019, 05:26 PM   #8 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
You can crank them with just a floor jack. If you want to change the keys depending on what GM vehicle you’re working on, a C clamp may relax the tension otherwise you need the specialty tool. I bought one when working on an HD because it was such a bitch it bent my C clamp I had used 1000 times.
If it were my truck I would put a floor jack under it put two rotations on the adjuster bolts and see where I end up. You may need to buy torsion keys and longer sharks or you may be OK without. Try not to run the shock topped out because it will ride like shit. If you put in to long to shock you will break upper ball joints.
& Blaine
:tank:
Old 05-27-2019, 10:20 PM   #9 (permalink)
Jason4x4's Avatar
Member # 104033
From my experience, the tool is only need to put the leveling keys in, you don't need it to remove the factory keys, but since the leveling keys are clocked different, you need the tool to install.
Old 05-28-2019, 11:33 AM   #10 (permalink)
Member # 52361
You don't need the tool to adjust them, but to swap them, especially the lift keys, just buy the tool instead of fixing around for hours with Jacks and pry bars and smashed fingers
Like said, you could use k1500 keys, but the time spent tracking them down, dealing with a yard, paying for them, just have bezos drop a set on your doorstep for $40
Any luck on those Fairlane parts btw?
Old 05-28-2019, 01:20 PM   #11 (permalink)
Member # 539746
thanks for the info. No luck on Fairlane parts yet; haven't been to my storage unit in a few weeks. Should be there within the next week, however. Will let you know.
69 Bronco; 01 Suburban K2500; 66 Fairlane GT convt; 68 GTO convt; 71 Javelin; 72 Alfa Romeo GTV
Old 05-28-2019, 07:24 PM   #12 (permalink)
Member # 539746
Cranked down on the keys. Got it pretty darn close. Within 1/4" of being level.
Before:
After:
Old 05-30-2019, 04:06 AM   #13 (permalink)
Member # 343
Did you get taller when the second pic was taken....LOL
Looks to be about right IMO...
cj8scrambld is offline   Reply With Quote Quick reply to this message
Old 05-30-2019, 06:30 AM   #14 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Every torsion bar crank or key lift I was ever involved with was followed up within a year by a customer complaining their ball joints were trashed or their CV axles were popping.
I'm really shocked that nobody has ever offered high misalignment ball joints and axles for these trucks. Seems people just run everything in a bind and tell themselves everything is fine.
Action Fab is offline   Reply With Quote Quick reply to this message
