WTK: Best Brake Rotor Dana 70 Disc Brake Conversion ¿? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2020, 07:18 PM   #1 (permalink)
Member # 69633
Location: I live in my body: On the land near Paradise Township, Jefferson State, not by choice.
Title says it all.
Want bolt on brackets hopefully but also want a rotor that does not require a huge spacer.
Dana 70 Differential out of a 1985 one ton dually pickup truck.
Well im going with a Dana 60 dually rotors just like I used on my first 14 bolt conversion.
More to come.
Got the rotors from Napa yesterday and they are real stout.
So you are a US citizen ehhh ?https://pbs.twimg.com/media/EPzWL1zW4AMEG2U?format=jpg&name=small
ParadiseAutoElectric is online now   Reply With Quote Quick reply to this message
Old 02-15-2020, 07:25 PM   #2 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
If that’s out of a GM pick up (not a cab & chassis) it’s a D70HD, which makes a difference. Try Diy4x.com, they have a kit for the HD axle.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 02-15-2020, 10:07 PM   #3 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Nothing ive ever heard of that is the standard kit that DOESNT use a spacer
And nothing again usings a modern rotor that DOEST requier welding.
If youre going to use the drw wheels you have to use the spacered setup or use 19.5 wheels.
On my 1970 truck i found the hard way using ruffstuff off set drw bracket doesnt clear the inner wheel.
Old 02-16-2020, 12:18 AM   #4 (permalink)
Member # 69633
Any idea if the backing plate to axle mount bolt pattern on the Dana 70 is the same as on a 14 bolt differential ?
Made my own kit on a 14 bolt can do it on a D70.
Maybe
Old 02-16-2020, 12:31 AM   #5 (permalink)
Member # 742465
https://www.ruffstuffspecialties.com/catalog/R2050.html
I have that kit on my 70HD, no spacers bolts right up. I'm using DRW hubs. 4" axle tubes are beef, but a pain to buy for
Bowtech99 is offline   Reply With Quote Quick reply to this message
Old 02-16-2020, 12:40 AM   #6 (permalink)
Member # 69633
Unless I'm misunderstanding the quote from the link.
I need the dually axle with all 4 tires.
Found this setup, may work.
http://vi.raptor.ebaydesc.com/ws/eBa...77&cspheader=1
This is for converting to standard single steel wheel minimum 15" with a maximum 4" back spacing
Old 02-16-2020, 10:05 AM   #7 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
Why don’t you weld a new flange on the tube further out and bolt the bracket directly to it? Easy solution.
Did you look at the Diy4x kit?
John
Old 02-16-2020, 10:16 AM   #8 (permalink)
Member # 69633
Might work to weld a flange.
Yes see the quote from the link I'm running dually wheels / tires dont want single wheel / tire setup, it wouldn't have the capacity for the application.
Old 02-16-2020, 10:28 AM   #9 (permalink)
M92pv4u's Avatar
Member # 860424
Is this the kit you looked at?
Dana 70 Dually/14bff Cab and Chassis Disk Conversion
← Previous productNext product →
View detailed images (1)
This disc conversion kit works for both the Cab and Chassis 14BFF and for the Dana 70 for dual wheels applications.
Clears most stock 16" bud rims. Some calipers may need slight grinding on the outer edge.
3/8" thick bracket bent and braced. Uses our standard caliper from a 73-87 3/4 ton 4x4 front axle chevy. It's all bolt on and go. We are also including an inside pad spacer pair. This spacer goes between the inside pad and the caliper piston. This gives you back just a little bit of piston stroke.
Kit includes, 1 pair of brackets, full hardware set and 1 pair inside pad spacer and a corresponding rotor part number. Rotors are NOT included in the kit and must be sourced locally.
This kit comes standard with Black Satin powdercoat. Other color options are available, if you would like a different color please call for custom color options.
Don't make fun of the things l do or you'll be laughing all day
M92pv4u is online now   Reply With Quote Quick reply to this message
Old 02-16-2020, 11:37 AM   #10 (permalink)
M92pv4u's Avatar
Member # 860424
Yeah I think that I misunderstood the axle that you have.
So do you have the standard dually axle or the cab and chassis axle?
Old 02-16-2020, 11:41 AM   #11 (permalink)
Member # 69633
DANA 70 HD as came out of a C30 GMC CREW CAB DUALLY PICKUP BED TYPE TRUCK.
Old 02-16-2020, 11:46 AM   #12 (permalink)
Member # 4243
Why not start with a deep (5"+) rotor like found on a 01-02 Dodge D80 DRW, or some of the DRW Savana/Express vans?
EDIT: The D70HD (DRW pickup) and 14BFF (C&C) from square-body GM trucks use the *same* wheel ends (hubs & brakes).
Dodge cobbler... (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 02-16-2020, 11:52 AM   #13 (permalink)
Member # 69633
Looks like rock auto does not have dimensional data on their website.
Specs ?
Diameter ?
Thickness ?
Offset ?
About to dig out my centric rotor drum spec book.
EDIT: The D70HD (DRW pickup) and 14BFF (C&C) from square-body GM trucks use the wheel ends (hubs & brakes).
Old 02-16-2020, 11:54 AM   #14 (permalink)
Member # 4243
Specs ?
Diameter ?
Thickness ?
Offset ?
Its all on rockauto... easier to lookup oneself than to try and screenshot and present it here.
Old 02-16-2020, 12:05 PM   #15 (permalink)
Member # 69633
Translate please.
Old 02-16-2020, 12:06 PM   #16 (permalink)
Member # 4243
Translate please.
Two different dually diffs... same outers. Got it?
Old 02-16-2020, 12:10 PM   #17 (permalink)
Member # 69633
Yes
Old 02-20-2020, 07:21 AM   #18 (permalink)
Member # 69633
OK I need a Dana 70 axle spindle end, for mock up purposes.
Anyone ?
Newb ?
