KOH Story, What took You Out? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Competition and Event Info > Competitions and Events
Old 02-06-2016, 12:44 PM   #1 (permalink)
Drakeslayer's Avatar
Member # 175109
What broke? What's your mishap? Tell us why your KOH details. Keyboard racers have needs too!
Drakeslayer is offline   Reply With Quote Quick reply to this message
Old 02-07-2016, 12:00 PM   #2 (permalink)
RCKRATZ's Avatar
Member # 2485
Send a message via Yahoo to RCKRATZ
Lost an upper link bolt which would have been an easy fix but the crank pulley got wasted in the process.
Keith Ratzburg aka "El Rolo"
Ratz Racing #4821
Big thanks to the vendors that have helped us out!
Goatbuilt, South Bay Driveline, East Coast Gear Supply, Rugged Radios, 150tunes.com, Pro Comp, Raceline Wheels, FOX Shocks
RCKRATZ is offline   Reply With Quote Quick reply to this message
Old 02-07-2016, 01:17 PM   #3 (permalink)
Member # 177350
Broke winch line just prior to Chocolate Thunder and lost driver-codriver coms.
EMC 4524
Formerly known as nobody20
sol_searcher is offline   Reply With Quote Quick reply to this message
Old 02-07-2016, 02:25 PM   #4 (permalink)
David Taylor's Avatar
Member # 11577
High steer arm in Claw EMC race
For all your KOH/Ultra 4 pictures check here.
My Jimmy's build.
David Taylor is offline   Reply With Quote Quick reply to this message
Old 02-07-2016, 02:42 PM   #5 (permalink)
Member # 136981
Bumps in the road, but those took you out of the race?
[B]#feelthejohnson[/B]
biffgnar is offline   Reply With Quote Quick reply to this message
Old 02-07-2016, 07:07 PM   #6 (permalink)
PUjeeper's Avatar
Member # 27231
Send a message via AIM to PUjeeper
Broke our front spool...got it fixed
Rolled bad/dumb on wrecking ball...self recovered
Ran out of fuel on 19/20...borrrowed from another racer
Lost light bar just after 2b...still ran spooners/outerlimits and ran 55mph thru the dessert with rock lights on.
Finally rear diff self imploded 15 miles from the finish. Chucked the driveshaft with 1/2 the pinion still attached and locked up the rear end. All of our tools, spare tire, and jack had fallen off. We had to wait for the pit team to reach us and it was about 10:30 before we got the pinion out so the car would move in FWD.
Team 890 Ultra 4
Driver Jonathan Terhune
FAT HEAD RACING
PUjeeper is offline   Reply With Quote Quick reply to this message
Old 02-07-2016, 08:11 PM   #7 (permalink)
waynehartwig's Avatar
Member # 35700
Hit a large boulder in the desert at about 60 mph, causing the shocks to bottom out severely and pushed them completely through the hood. Busting the mount completely off. Can't say I've seen much 1.5x.25 DOM stretched apart before!
About 10 minutes after we did it, another racer hit the same rock, but not full on, causing a tire failure. So we helped them swap it and get back on the road. ...Our Maxxis Trepador and Trail Gear beadlock look to be still ok.
We pulled the shocks, tied everything down, and then drove out to HWY 247 at 50 mph to meet the trailer/recovery crew. Looks like only damage is shock mounts and ball joints. But I will most likely tear down/change everything on that corner....
Hartwig Motorsports 4516, Team Yukon Gear and Axle
10% PIRATE COUPON CODE (not valid for harnesses and PCM tuning): pirate4x4
Special thanks to: My Family and Friends, Yukon Gear and Axle, DynoMAX Exhaust, AllTech Motorsports, Radflo Shocks, PAC Racing Springs, JM Rigging Supply, Reid Racing, Rugged Radios, Trail-Gear, Life-Time LED Lights, RuffStuff Specialties, Randy's Racing Transmissions, A1 Performance Converters, Maxxis Tires, Jesse Haines Fab, CBR Performance, PRP Seats, Exhaust Solutions, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote Quick reply to this message
Old 02-08-2016, 09:30 AM   #8 (permalink)
LLY Escalade
SierraClassic's Avatar
Member # 41695
4675 in the EMC. Engine failure at RM 73
- Russell
(VA6DSL)
2003 Cadillac Escalade with LLY Duramax / ZF6 / NP241. SAS'd on 1 tons with lockers and 37s
SierraClassic is offline   Reply With Quote Quick reply to this message
Old 02-08-2016, 11:11 AM   #9 (permalink)
Wubsor's Avatar
Member # 308273
EMC race, car 4827. Really long day with 3 flats and repeated electrical issues. Lost the first tire at RM17 trying to pace Brad Lovell, then proceeded to have circuit breakers fail what felt like every 10 miles. Ended up making fused jumpers for those that crapped out on us. I will never cheap out on electrical again. Stay away from Carling breakers if you want to be competitive... I'll be busting out the wallet for Klixon stuff.
Crossed the finish line at 8:30. We timed out, but we'll be back.
-Scott
Afterthought Racing, 4827
Wubsor is offline   Reply With Quote Quick reply to this message
Old 02-08-2016, 01:36 PM   #10 (permalink)
Member # 26797
I know we helped a couple UTV teams continue on, one that we swapped all 4 coilovers on in the pit, one that had a bent driveshaft and crossmember. Our U4 car we retired at the start of lap 3. A transmission line blew, causing a fire, which melted some ECM wires. The decision was made to save the car and not recover it in the middle of the night.
Ryan
96zjlimited is offline   Reply With Quote Quick reply to this message
Old 02-08-2016, 06:37 PM   #11 (permalink)
Member # 177350
Without winch we didn't want to become the car that plugged the trail. Respect for other competitors. Is that so bad?
EMC 4524
Old 02-08-2016, 08:17 PM   #12 (permalink)
Dummer'n Moose Poop
Thump's Avatar
Member # 789
I broke the driver's sun visor on my TJ. Damnit! (Was running pits Wed-Fri for 13 different rigs, total)
Thump is offline   Reply With Quote Quick reply to this message
Old 02-08-2016, 09:37 PM   #13 (permalink)
traxman25's Avatar
Member # 35227
Send a message via Yahoo to traxman25
4437 Sexton Offroad chunked 1st, 2nd, and reverse from the trans between remote pit 1 and the return to RP1. They limped back in 3rd gear, worked to swap it but missed the cutoff time.
traxman25 is offline   Reply With Quote Quick reply to this message
Old 02-08-2016, 09:41 PM   #14 (permalink)
YotaAtieToo's Avatar
Member # 25632
Did you try a square knot?
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 02-09-2016, 08:16 AM   #15 (permalink)
momar's Avatar
Member # 32809
4518 Lost 1st gear right after pit1. Pushed the fender into a power steering line before main pit. Shorted some wiring and had to push start it out of main haha. Turned out it was our compressor ground shorting on the charge wire, so no lockers as we got into the rocks. Fixed all that, then sheared driver side hub studs in wrecking ball. Called it a day at chocolate thunder.
Off Road Lighting Solutions, Recovery Gear, Trail-Gear, Ruff Stuff, Method Race Wheels, Aussie Locker, ARB, G2
#4518
Thanks Trail-Gear, RuffStuff, Fox, Adco, dynomax, Project4x4, Hellfire Fabworks, Maxxis and 4WheelParts
momar is offline   Reply With Quote Quick reply to this message
Old 02-09-2016, 12:05 PM   #16 (permalink)
Member # 110916
power steering cooler shattered from hammering gate of clawhammer. bipassed cooler and filled steering. helped a few other competitors spot and winch, winched my car through.
trans blew right in the sand valley on Sledge bipass. felt like input snapped or something let go quick on impact of the bottom of valley. went from full power assults and good shifts to snap and no forward no reverse to the divorce case input. well experienced 4l60e. fluid good. boo.
Michael Abbatte #572 Ultra4 Class 4400
Lifetime LED Hahn Automotive
smichaelr22 is offline   Reply With Quote Quick reply to this message
Old 02-09-2016, 04:24 PM   #17 (permalink)
Member # 87409
4667 broke right front leaf spring at rm 20 both main and 2nd leaf at front eye
4667 KOH EMC 2014,2015,2016,2017
varokcrwlr is offline   Reply With Quote Quick reply to this message
Old 02-09-2016, 04:36 PM   #18 (permalink)
Stealth 4x4's Avatar
Member # 165390
Sorry to hear that, Ted. We broke our front passenger main leaf at about RM 20 during prerunning, but fixed it up as we had spare main leafs. Breaking it in the whoops at speed made for a sketchy ride though.
In the main event we quickly discovered a new weak link in the build. The third members were freshly rebuilt during race prep and held up through break-in and prerunning just fine, but by the time we got just past RP1 both diffs were shrapnel, and the rear blew a hole right through the casing.
Just another Degenerate rock crawler/racer.
#488 Stock Class Blue 1985 Toyota
Stealth 4x4 is offline   Reply With Quote Quick reply to this message
Old 02-09-2016, 04:39 PM   #19 (permalink)
Member # 175109
Thanks everyone for posting! The picture is also appreciated.
Keep the info coming.
Old 02-09-2016, 06:11 PM   #20 (permalink)
Member # 334825
David
I hated to see you in claw broke. I know the feeling, I shattered my pasanger axle shafts and steering knuckle in the exact same spot Tuesday while pre running. Didn't receive my ne rcv shaft till 6pm wed night. Me and crew was running on 2 hours sleep race day.
Oh and I know it sucks being broke and being a trail plug, but thanks for spotting us through, looked like you were making the best of it.
2015 emc Koh 4553
2016 emc Koh 4553
Victorfont is offline   Reply With Quote Quick reply to this message
Old 02-09-2016, 07:53 PM   #21 (permalink)
Member # 11577
Originally Posted by Victorfont View Post
David
I wanted to do what I could to keep rigs moving. Kevin and I Must have spotted close to 50 rigs through and pulled rope most of the afternoon. Good times
My Jimmy's build.
Old 02-09-2016, 10:05 PM   #22 (permalink)
Member # 39351
Does anyone know what happened to the Guys in the 4wheel parts car? We saw them hit a big rock trying to climb a hill and the driver was transported by helicopter.
I just want to know how he is doing.
Mex-lego is offline   Reply With Quote Quick reply to this message
Old 02-09-2016, 10:11 PM   #23 (permalink)
Member # 39351
This hill.
Old 02-10-2016, 07:14 AM   #24 (permalink)
Member # 101265
Any vids? I've seen updates on FB on everyone (below), but had no idea what happened.
From FB - Brent is going to be in a brace for a while, Rob (Bender) has a fractured back but will be okay.
Kunker is offline   Reply With Quote Quick reply to this message
Old 02-10-2016, 07:48 AM   #25 (permalink)
Member # 157355
" They broke a boulder with the front Diff"(info from a spectator who posted on another forum who knows)
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote Quick reply to this message
