1968 Ford F100 1400 Race Truck Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 09-12-2014, 10:21 PM   #1 (permalink)
Member # 37016
Well it's really a F250 but who cares.
So i got this truck a few months back in trade. Needless to say the truck needed a complete rebuild.
Only1Mikey and Myself will be doing the full build on this truck. With help for many other friends I am sure. We plan on racing it and using it as much as possible. Just a overall fun play/race truck. Some creature comforts but able to hopefully keep up at the big races.
Wouldn't be possible without help from company's like
Poly Performance Inc
Synergy MFG
4130 Clothing
FOX Racing Shox
Trail Ready Wheels
So here it is. Specs are as follows
1968 Ford F250
2" Score Legal Cage and Backhalf
3 Twisted Stitch Seats
Crow Belts
Front Suspension:
Equal length beams w/custom spindles D60 hubs
Convert to front steer
2.5 FOX coilovers and 3.5 FOX Bypasses
2.0 FOX air Bumps
May do center mounted radius arms, will see when I mock up
Rear Suspension
Rearend is D70 Full Floater
Full truss with removable diff cover
10.5" ring gear. 5.86 gears. Locker
4 Link. w/TT Motorsports Lower Links
2.5 FOX coilovers and 4.4 FOX Bypasses
2.5 FOX air Bumps
Custom 50 Gallon Harmon Racing Fuel Cell
Sway a Way Sway Bar
Dixon Bros Front Glass
Custom Rear Glass or McQueen if his are done
39" BFG projects on Trail Ready Beadlocks
Hydroboost Brakes
AC
CBR Radiator
Motor:
6.0L warmed up
4L80e Trans Full manual Valve Body
CBR Trans Coolers
Follow on Instagram for pics as well @TTMotorsports #MURDERBUMPSIDE
Any questions ask away. Happy to help and answer whatever I can.
How it was when I got it. custom "backhalf" with Black Pipe instead of tubing. Broken upper link mount.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 09-12-2014, 10:22 PM   #2 (permalink)
Member # 37016
Starting off with cab cage and backhalf.
[COLOR="Silver"]
Old 09-12-2014, 10:22 PM   #3 (permalink)
Member # 37016
Link mounts and cycling rear.
Old 09-12-2014, 10:22 PM   #4 (permalink)
Member # 37016
Start of backhalf and Cage. Going to try and do some things a little different and use some plate bulkheads throughout to make fab work look a little different.
Old 09-14-2014, 06:05 PM   #5 (permalink)
Member # 102591
Great to see you back into another one. Looking forward to this :smoking:
-Dex- is offline   Reply With Quote Quick reply to this message
Old 10-03-2014, 11:25 PM   #6 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Are you keeping the dynamat?
& Blaine
:tank:
Old 10-06-2014, 10:53 AM   #7 (permalink)
Member # 37016
A lot of it will stay since it is a bitch to remove. I want to put carpet and sound deadening in it once it's up and going and bugs are worked out.
Old 12-01-2014, 04:54 PM   #8 (permalink)
Valley Auto's Avatar
Member # 78079
Any progress on this thing.
Master of the wire Wheel!
Valley Auto is offline   Reply With Quote Quick reply to this message
Old 12-02-2014, 08:42 AM   #9 (permalink)
skullver's Avatar
Member # 60364
I'm really liking that truss work and the bulkhead idea, going to turn out bitchen!
:flipoff2::flipoff2::flipoff2::flipoff2::flipoff2:
skullver is offline   Reply With Quote Quick reply to this message
Old 12-02-2014, 02:10 PM   #10 (permalink)
Member # 37016
Moved into a new shop. 4 linked a dodge for a friend and will get back on this hopefully this week. Have a quick deaver/14 bolt/bedcage swap to do on a silverado then back on this after that again.
Old 12-03-2014, 07:02 PM   #11 (permalink)
Member # 57592
Looking forward to seeing progress. I like that bulkhead. How much travel are you anticipating? Swing set steering?
toten is offline   Reply With Quote Quick reply to this message
Old 12-04-2014, 09:32 AM   #12 (permalink)
Member # 37016
Front travel should be around 22" strapped easily. Rear cycles 30" but will be strapped around 26 or so
Old 01-19-2015, 03:39 PM   #13 (permalink)
Member # 37016
Got some more tube thrown at it this past week and weekend. Coming along.
Old 01-20-2015, 06:46 PM   #14 (permalink)
Member # 93071
Amazing work man. This is going to be a cool project.
"those who mind don't matter and those who matter don't mind" -Dr. Seuss"
redline61 is offline   Reply With Quote Quick reply to this message
Old 01-21-2015, 07:28 AM   #15 (permalink)
Member # 205023
LQ4,216/220, 14B FF,80E
Dirtmafia is offline   Reply With Quote Quick reply to this message
Old 04-03-2015, 05:07 PM   #16 (permalink)
Member # 232327
Any updates? Just picked up a 1970 F100 with 250 running gear myself.
sokoloka is offline   Reply With Quote Quick reply to this message
Old 04-06-2015, 11:26 AM   #17 (permalink)
Member # 37016
Should have updates soon. Just finished a 5.3L chevy swap in a bronco. Picked up a new mill i need to get into shop and some 3.0 bypasses for the rear. Will post up pics in next week or two.
Old 04-06-2015, 07:40 PM   #18 (permalink)
Member # 232327
Looking forward to the details of the 6.0 swap. Looking to put something LS based in my truck as well.
Old 12-02-2015, 10:00 PM   #19 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Updates?
& Blaine
:tank:
Old 12-03-2015, 03:17 PM   #20 (permalink)
Member # 37016
Just finished up a Silverado build. Going to be linking/backhalfing my tacoma then back on this fulltime till it's done. Currently trying to source some beffier axle components for my D70 rear. As well as buy some more parts for the front suspension/motor. Fuel cell is now built as well and got the new 3.0 Rear Fox coilovers so i can finish up the backhalf.
Old 12-03-2015, 04:20 PM   #21 (permalink)
Member # 232327
Look forward to seeing some updates. Finally getting around to doing something with the power steering setup I picked up from you.
