Jeepspeed 1749 Build - Baja 1K or Bust! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Desert Racing
Old 07-26-2007, 11:30 PM   #1 (permalink)
Member # 3191
OK, Here is a quick shot of the new Jeepspeed 1749 currently being built for this years Baja 1K. This is how it stands now, still a ton of work to do for this years race!
Dusty Booger is offline   Reply With Quote Quick reply to this message
Old 07-26-2007, 11:31 PM   #2 (permalink)
Member # 3191
Door Panel
Old 07-26-2007, 11:34 PM   #3 (permalink)
Member # 3191
A-pillar node. Majority of the cage is all 1 3/4 DOM.
Old 07-26-2007, 11:35 PM   #4 (permalink)
Member # 3191
B-Pillar. (Obviously one tube still needs to be welded.)
Old 07-26-2007, 11:39 PM   #5 (permalink)
Member # 3191
Cage passing through firewall. I was meticulous and used a 2" holesaw and careful measuring to pass them through. This took more time upfront, but is much cleaner quicker in the long run than repairing large holes cut for easy fitment.
Old 07-27-2007, 12:06 AM   #6 (permalink)
Member # 67882
Like the cage work
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 12:18 AM   #7 (permalink)
Member # 37016
looks great. I wish I had the tools and patience to do work that nice. I guess i'll stick with my straight corner gussets. Looks great so far, lots of planning went into it, and it shows.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 12:19 AM   #8 (permalink)
Member # 3191
Here is a sneak peak at the new Polyperformance XJ Suspension kit. It includes replacement rear leaf spring mounts & channels that stiffen the from from the link mounts to the spring mount. There is also a plate is used for the cage mount. The exterior plate comes with a hole that is used to drop the cage through and get the 360 weld. A large gusset (Not shown) is welded from the exterior plate to the link mount bracket once the cage is done.
Old 07-27-2007, 12:23 AM   #9 (permalink)
Member # 3191
Here is the spring mount. The plate with the large hole is for the cage b-pillar.
Old 07-27-2007, 12:23 AM   #10 (permalink)
Member # 5110
How much is it going to weigh when you are done?
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 12:24 AM   #11 (permalink)
Member # 3191
One more quick shot of the link mount....
Old 07-27-2007, 12:29 AM   #12 (permalink)
Member # 3191
Not sure exactly, but we will keep it under the SCORE requirement for 2" tubing. We removed as much as we could to save weight and still be Jeepspeed legal. All the glass is out, no window cranks or mechanisms, no AC, no Heater box, stock dash removed, etc. I will get it weighed as soon as it is all done.
Old 07-27-2007, 12:32 AM   #13 (permalink)
Member # 3191
Here is a shot of the cage before install. We mocked it all up and then removed it. It was then re-installed in one day and most of the welding was done.
Old 07-27-2007, 01:53 AM   #14 (permalink)
Bigburlynakedguy's Avatar
Member # 11961
Did you read the SCORE rules about chromoly?
[QUOTE=MT4Runner;36844945]If you died tomorrow, are you ok with the life you've lived up until today?[/QUOTE]
Bigburlynakedguy is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 06:09 AM   #15 (permalink)
Member # 47179
Send a message via AIM to TotalImmortal
what?
Brice
TotalImmortal is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 08:37 AM   #16 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
What happened to the other wheels?
And what blind woodsman welded that thing together...
& Blaine
:tank:
Old 07-27-2007, 08:49 AM   #17 (permalink)
Member # 3135
Looks good man... Where did you get the door panels?
Peak Empire Racing
Peak ZJ is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 09:07 AM   #18 (permalink)
Whitewater's Avatar
Member # 89
Send a message via MSN to Whitewater Send a message via Yahoo to Whitewater
Where will you put your quick access tools now that you've blocked off your door storage?
Looks good, hope to pass you, er see you there.
[SIZE="2"][COLOR="SeaGreen"]
"Having too many 'things', American's spend their hours and money on the couch searching for a soul. A strange species we are... If I wanted to destroy a nation, I would give it too much and I would have it on it's knees, miserable, greedy and sick." -John Steinbeck
[/SIZE][/COLOR]
Whitewater is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 10:08 AM   #19 (permalink)
Member # 95018
Looks great! Any more pics of cage (engine & rear)?
xjs4jeremy is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 11:19 AM   #20 (permalink)
Member # 3191
Yes, and it can be 1026 DOM or Chromoly. Is there another rule you were referring to?
Old 07-27-2007, 11:20 AM   #21 (permalink)
Member # 3191
Thanks. I made them
Old 07-27-2007, 11:23 AM   #22 (permalink)
Member # 3191
The American Racing rims that I was boring out and spot facing down at Poly are on the rear as the 9" is 5 on 5.5. I still have the D30 up front. The HPD44 is not done yet, and Drew wanted to design the suspension so that it would work on the stock D30.
Old 07-27-2007, 11:43 AM   #23 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
1020 DOM is also acceptable.
& Blaine
:tank:
Old 07-27-2007, 11:46 AM   #24 (permalink)
Blase's Avatar
Member # 63692
What did you use to weld that cage? I would think Tig but not sure. Those are some bad Ass welds!!
[QUOTE=JR;13666387]:laughing: You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.[/QUOTE]
Blase is offline   Reply With Quote Quick reply to this message
Old 07-27-2007, 12:48 PM   #25 (permalink)
Wish it was my job!
foley's Avatar
Member # 2134
Send a message via AIM to foley
those are obviously MIG welds. Look at the stop / starts on the curved gusset.
I swear hell is full of cedar, scorpions and flat hot non-alcoholic beer.
foley is offline   Reply With Quote Quick reply to this message
