🚨 NEW 🚨 2019+ Ford Ranger LED Lighting Upgrades! | Diode Dynamics - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Diode Dynamics
Old 08-27-2019, 11:42 AM   #1 (permalink)
P4x4 Vendors
Diode Dynamics's Avatar
Member # 451658
Diode Dynamics LED Lighting Upgrades for 2019+ Ford Ranger
One of America’s most beloved mid-sized trucks, the mighty Ford Ranger, has returned! Though it shares a nameplate with the Rangers of yesteryear, that’s where the similarities end. A new body, frame, suspension, and powertrain have all been designed to make this the most capable, efficient version ever!
However, there is still room for improvement. Specifically, with the Ranger’s factory lighting! Despite all the new technology of the 2019 Ranger, outdated yellowish incandescent bulbs are still present in the 2019 Ranger’s sidemarker lights, front turn signals, fog lights, cargo lights, third brake lights, and license plate lights.
Fortunately, these are all easily replaceable with Diode Dynamics LED upgrades! In just a few minutes using basic hand tools, you can install brighter, more modern looking lighting on your 2019 Ford Ranger. Check out all the LED upgrades we offer for the 2019 Ford Ranger below!
Diode Dynamics SLF Fog Light LED Bulbs
Our SLF LED Fog Light Bulbs are the perfect solution for increasing visibility on the 2019 Ranger. Designed, tested, and manufactured at our facility in St. Louis, the SLF Fog Light Bulb drops right into place of the factory H11 bulbs. The advanced optical design of the SLF means you’ll have maximum focused light output, with zero glare!
Available in both cool white and yellow color temperatures, these LED fog light bulbs can be installed in less than 20 minutes! And with 780 lab-verified lumens, the SLF Fog Light LED Bulbs provide FAR better visibility at night!
Diode Dynamics Switchback Turn Signal LEDs
The perfect combination of form and function, Diode Dynamics Switchback Turn Signal LED Bulbs enable a unique dual-color effect on your Ranger! The brilliant 6000K cool white running light alternates with a crisp amber flasher any time your turn signals are activated.
Our 7443 size turn signal bulbs are a direct replacement for your Ranger’s stock bulbs, and come backed by our 3-year worry-free warranty. Additionally, these LED bulbs produce 410 lumens of light output, making your Ranger much easier to spot by other drivers!
Diode Dynamics Sidemarker LED Bulbs
Diode Dynamics Sidemarker LED Bulbs are a great way to improve the function and longevity of the sidemarkers on your Ford Ranger. They'll provide modern illumination with long lifespan compared to the original incandescent bulbs. The installation is straightforward, with just a bulb swap - making it a simple upgrade for the Ranger's lighting setup.
You can choose from three distinct brightness levels. As with all Diode Dynamics lighting upgrades, our 194-size Sidemarker LED Bulbs were designed and tested right here in the USA!
Diode Dynamics Cargo Light LED Bulbs
Loading and unloading your 2019 Ford Ranger shouldn’t be done in the dark! Diode Dynamics Cargo Light LED Bulbs are a drop-in upgrade for the yellowish stock bulbs that provide dramatically better visibility!
Our brightest 921-size bulb, the XP50, packs 410 proven lumens of light output. With Diode Dynamics Cargo Light LED Bulbs installed, you’ll enjoy better visibility at night, and a fresh, modern look!
Diode Dynamics Third Brake Light LED Bulbs
The factory incandescent 3rd brake light bulb on the 2019 Ford Ranger lights up in a glow, which takes a moment to turn on. Diode Dynamics LED upgrades provide an instant response, which can alert other drivers on the road earlier, while also providing a modern LED appearance!
Best of all, our 921 size Third Brake Light Bulbs are 100% plug-and-play, no splicing or wiring required! You’ll simply remove the stock bulb, and drop in your Diode Dynamics LED replacement!
Diode Dynamics LED Tail Light Bulbs
When it comes to brake lights, brighter is better! Diode Dynamics 7443-sized LED Backup Light Bulbs are a must-have lighting upgrade for your 2019+ Ford Ranger.
Our brightest option, the XP80, packs 510 lab-proven lumens of light output, making it one of the brightest LED tail lights for the 2019+ Ranger on the market!
Diode Dynamics LED Backup Light Bulbs
Don't reverse in the dark! Diode Dynamics 7443-sized LED Tail Light Bulbs for the 2019+ Ford Ranger are plug-and-play upgrades that can make you FAR more visible to other drivers when braking.
At 510 test-verified lumens of light output, our XP80 LED Backup Lights provide drastically better rear-facing visibility than the 2019+ Ranger's factory reverse lights.
Diode Dynamics LED Rear Turn Signal Bulbs
Just like our LED tail lights for the 2019+ Ford Ranger, our 7443-size LED Rear Turn Signal Bulbs can make it much easier for others on the road to spot you when turning or using your hazards. Additionally, the crisp on/off of the LEDs gives your Ranger a much more modern appearance.
With 510 lumens of brilliant amber light, our XP80 LED Rear Turn Signal Bulbs are dramatically brighter than the 2019+ Rangers OEM halogen turn signal bulbs. Get yours today!
Diode Dynamics License Plate Light LED Bulbs
Add a clean, modern look to your Ford Ranger with our License Plate LED Bulbs! These bright LEDs are available in a number of colors including cool white, to replace the factory yellowish incandescent bulbs.
These 194-size License Plate LED Bulbs install in less than 10 minutes, and require zero modification. Upgrading the appearance of your 2019 Ford Ranger simply doesn’t get any easier!
Fitment:
Diode Dynamics LED lighting is proudly engineered and tested right here in the USA, and is backed by our 3-year worry-free warranty! Want to check out more LED lighting upgrades for your 2019+ Ford Ranger? Click here!
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
/ (314) 205-3033
Lighting Experts
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 03:38 PM   #2 (permalink)
P4x4 Vendors
Member # 451658
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
/ (314) 205-3033
Lighting Experts
