Electrical and Wiring Forum FAQ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-09-2012, 08:01 AM   #1 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Send a message via AIM to steveh
Lets get a FAQ going. Feel free to add your tips, hints and tricks in this thread. If there are other threads that have good info, pm me the link, and i will merge them in here.
Lots of good info in this forum.
85 Toy Xtracab
"I DON'T want to understand !!"
"Wow this is unbelievable"
steveh is offline   Reply With Quote Quick reply to this message
Old 09-09-2012, 08:03 AM   #2 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Ohm's law: use it to calculate electrical characteristics.
Common use in 12vdc wiring is to calculate Power and Current, to size wires correctly, and choose batteries and Alt upgrades based on predicted loads.
Takes the guess work out of it.
V=Voltage (Sometimes referred to as E=Energy)
I=Current (Sometimes referred to as A=Amps)
R=Resistance
P=Power (Watts)
Calculating with Voltage
V=IxR
I=V/R
R=V/I
Calculating with Power:
P=IxV
I=P/V
V=P/I
Google it for examples.
Originally Posted by PAToyota View Post
Not to mention for calculators too: http://www.ohmslawcalculator.com/ohm...calculator.php
85 Toy Xtracab
Old 09-09-2012, 08:04 AM   #3 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Wiring tech:
85 Toy Xtracab
Old 03-13-2013, 12:31 PM   #4 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Cheapass Wireless Winch Remotes That Work AWESOME!!!
Good stuff!!!
85 Toy Xtracab
Old 03-13-2013, 02:08 PM   #5 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Long read but good stuff in here from gen 4x4.
https://www.pirate4x4.com/forum/gener...ng-tricks.html
Links to good places to buy wiring stuff.
Welcome to Waytek
Del City - Wiring Products and Professional Electrical Supplies
Automotive Wire Terminals - Battery Cable & Electrical Supplies
Automotive Wiring Supplies
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 03-26-2013, 08:05 AM   #6 (permalink)
Member # 141351
Been trying to find fuzes/fuze holders and breakers for use in wiring my buggy.
it's a scooter site, but many parts & pieces seem like they would be usefull;
TNC Scooters
prices don't look too bad, will update on the quality when I put an order in.
insert something witty here...
beakie is offline   Reply With Quote Quick reply to this message
Old 08-23-2013, 07:11 PM   #7 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
some basic info
JK Wiring basics!! - JKowners.com : Jeep Wrangler JK Forum
http://www.jkowners.com/tech/electrical/
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 01-06-2014, 10:59 PM   #8 (permalink)
Member # 122979
I've been using these for a while and they are awesome.
they are compatible with ATC/ATO fuse blocks, reset manually and can quickly be identified as tripped by visual inspection.
Name:  Screen shot 2014-01-06 at 10.39.35 PM.png
Low Profile Bussman Series 227 ATC Circuit Breakers - theelectricaldepot.com
good for diagnosis too
rocklobster87 is offline   Reply With Quote Quick reply to this message
Old 04-26-2014, 09:57 AM   #9 (permalink)
1980toyota4x4's Avatar
Member # 153757
Free download on wiring relays.
BOSCH RELAY GUIDE by: DLC - DLCparts.com - DLC Parts - David Levy
1985 EX CAB Just try to get it together to go wheelin... 2004 GMC Dmax tow rig
1980toyota4x4 is offline   Reply With Quote Quick reply to this message
Old 09-21-2016, 07:52 AM   #10 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
https://www.pirate4x4.com/forum/elect...-isolator.html
some good information and a solid post with links from Steve83 on wiring dual batteries, some isolator vs relay vs straight parallel information as well. Adding to the FAQ because I couldn't find this info with a search on here
I just want to build cars, collect watches and get tattoos.
The largest tax modification in 30 years, check it out!
