Recommend a portable heat gun - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-04-2019, 06:31 PM   #1 (permalink)
Member # 278
I'm looking for a non-plug in style heat gun(ie portable)
I found this(Titan Tools 51886):
https://www.amazon.com/Titan-Tools-5...t+guns+propane
Is there something cheaper?
Lighter and matched didn't do the trick And I hate dragging the extension cord through the mud to the car for my current gun
-1971 FJ55(aka Trail55): 6.0L-NV4500-LC split case, SOA, D60s, ARB'd... and cupholders
-1972 FJ55(aka Trail50): Turbo 5.3L-4L80-Blackbox-split case, D60s, ARB'd *stalled*
-1968 Mustang Fastback: not a restore but a refresh
Lil'John is online now   Reply With Quote Quick reply to this message
Old 01-04-2019, 07:23 PM   #2 (permalink)
nate379's Avatar
Member # 20099
I have a M18 cordless one. Works well enough for doing wiring shrink tube.... well... when it's normal temps.
Used it last night at around 10* and took quite a while.
nate379 is offline   Reply With Quote Quick reply to this message
Old 01-07-2019, 06:09 AM   #3 (permalink)
fredycruger's Avatar
Member # 225557
map torch
fredycruger is offline   Reply With Quote Quick reply to this message
Old 01-07-2019, 11:07 AM   #4 (permalink)
Member # 188446
Is this for heat shrink?
If you just have to do a few at a time, these are nice. I have one in my 'trail' toolbox.
https://www.wiringdepot.com/store/p/...tane-1-Pc.aspx
If you need more capacity, use one of these:
https://www.homedepot.com/p/Bernzoma...0194/301134308
Both refill with standard butane bottles.
ManNamedJed is offline   Reply With Quote Quick reply to this message
Old 01-07-2019, 04:57 PM   #5 (permalink)
Member # 278
Correct... just trying to seal up my glue filled heat shrink I've got most of my wiring wrapped up so I'm down to a few at a time.
Both of those look promising.
Old 01-08-2019, 03:19 PM   #6 (permalink)
Member # 86724
I've always used a small butane torch for heatshrink.
https://www.amazon.com/All-Splendid-...s=pencil+torch
just like that but 15 years old. same color even.
Old 01-09-2019, 09:29 AM   #7 (permalink)
Wut?
Overbear's Avatar
Member # 20114
https://www.amazon.com/Milwaukee-Ele...s=m18+heat+gun
But I have all Milwaukee items so tons of batteries and 3 of the 6 battery chargers.
“Christianity neither is, nor ever was a part of the common law.”-Thomas Jefferson, letter to Dr. Thomas Cooper, February 10, 1814,
When I'm the voice of reason, it's a pretty good indication that someone's doing it wrong.
Overbear is offline   Reply With Quote Quick reply to this message
Old 01-09-2019, 10:28 AM   #8 (permalink)
Member # 278
Originally Posted by nate379 View Post
I have a M18 cordless one. <snip>
Good, bad, or indifferent, I'm stuck in the Ryobi ecosystem
It sounds like butane torches might be the way to go. Are they lower temperature than propane or map torches?
Old 01-09-2019, 11:03 AM   #9 (permalink)
Member # 214685
In my experience they shrink the tubing without melting the wire covering too like a propane torch.
I use one from HF, works for the occasional wiring/soldering that I do.
Byro is offline   Reply With Quote Quick reply to this message
Old 01-09-2019, 12:37 PM   #10 (permalink)
Member # 86724
it's pretty much the same temp as propane, it's just a much smaller flame.
it's like a lighter that you can point.
you can still burn things if you're a moron.
Old 01-28-2019, 08:43 AM   #11 (permalink)
Member # 278
I tried the Pocket torch:
It worked well when things weren't tight. Otherwise, I ended up with a crisp area (ie moron)
The deleted reply provided an interesting option:
https://www.amazon.com/BernzOmatic-3...61472+BZ4500HS
Still a bit on the high side but not a bad option.
Old 01-28-2019, 12:07 PM   #12 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
It's probably huge for what you need. There is some other models with an adjustmend knob that you can turn down. They're got smaller tips.
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 01-29-2019, 04:09 PM   #13 (permalink)
Member # 86724
well the other thing I use is a monokote heat gun.
Top Flite MonoKote Heat Gun
but only because I've always had one around. They last near forever and have adjustable heat less than a paint stripper. The cool setting is useful as well.
Old 01-29-2019, 04:09 PM   #14 (permalink)
Member # 86724
Old 01-29-2019, 05:24 PM   #15 (permalink)
tacomamike's Avatar
Member # 6583
I use these little crack pipe torches for heat shrink tubing, works great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Regards,
....Mike
BlueRibbon Coalition Life Member
tacomamike is offline   Reply With Quote Quick reply to this message
Old 01-29-2019, 05:57 PM   #16 (permalink)
Member # 278
That is the equivalent of what I use right now. Mine is probably 40 years old and still can singe my fingers
Old 01-30-2019, 06:55 AM   #17 (permalink)
Member # 206595
I have a couple if these. I primarily use my electric, I prefer it for heat shrink, But in a pinch these small flame ones work.
I would shy away from the large flame ones, they burn surrounding wires.
https://www.amazon.com/Custom-Access...rds=mini+torch
maskale is offline   Reply With Quote Quick reply to this message
