WIRING HELP '87 22RE in an '89 4Runner - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2019, 06:48 AM   #1 (permalink)
Member # 864938
Hello! First post here, anywho, I've got an `89 4runner with a blown 22RE, so I found a 22RE out of an `87 pickup, but the previous owner cut the wiring harness at the firewall. I figured I could just swap in the harness from the `89 22RE, but a lot of the connectors are different. Would I be able to just swap all the sensors from the `89 22RE on to the `87 22RE? Or are they different?
HankSinatra is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 06:34 PM   #2 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
use the sensors that match the ECU that you have
https://www.pirate4x4.com/forum/toyo...-diagrams.html
see if this thread helps
I just want to build cars, collect watches and get tattoos.
The largest tax modification in 30 years, check it out!
Old 03-04-2019, 09:15 PM   #3 (permalink)
Member # 98157
connectors
The Toyota connectors are extremely easy to take apart and reinstall a different plug. I know 89 has a different fuel sender.
Dennis Roby is offline   Reply With Quote Quick reply to this message
Old 03-05-2019, 03:35 PM   #4 (permalink)
Member # 864938
Different in what way?
Old 03-08-2019, 08:41 AM   #5 (permalink)
Master Baiter
Provience's Avatar
Member # 138976
as in, if you have a body plug that is L shaped and need a blade shaped one, you can open it up and just swap wires from one plug style to the other
Similar Threads
1st Gen 4Runner 84 85 86 87 88 89 - Auxiliary Gas Tank 14 gal CARB Sticker Approved Spyduh Misc. Stuff For Sale 3 10-03-2017 08:08 PM
89 4Runner 22re backfire through intake Thewizard18269 Toyota - Truck and 4Runner 0 09-25-2016 01:12 PM
NorCal Toyota Parts Lot, 22RE, 22R Carb Wiring harness, Sub, W56, Tcase uniman Misc. Stuff For Sale 10 03-18-2012 02:18 PM
