Restored Suzuki LJ10/LJ20 Divorced Transfer Case (lightweight buggy?) - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 08-02-2019, 07:30 AM   #1 (permalink)
Member # 39799
*SOLD* Restored Suzuki LJ10/LJ20 Divorced Transfer Case (lightweight buggy?)
Refurbished Suzuki LJ20 Transfer Case (1972). Convertible LJ20 model divorced transfer case with 1.714:1 (High) and 3.013:1 (Low) gear ratios. Pinion-mounted emergency/parking brake. New seals, shifter seat, hardware, and (4) NEW OEM Suzuki transfer case mounts only available in Japan (these aren't cheap, and cost $40 ea. x 4). I also upgraded the clog-prone prone vent to a 90-degree NPT fitting designed to use 8mm or 5/16" vent tubing. I meticulously cleaned/degreased the housing, which was then painted with a combination of restoration-quality Eastwood Aluma Blast, Diamond Clear and Extreme Chassis Black (Satin) paint. Filled with Redline 75W/80 MTL GL-4 (0.7 liter).
This transfer case is ready to bolt in to your LJ10/LJ20 and give you decades of service. This would also be ideal for a lightweight adult or child crawler/buggy. I have a couple extra sets of ultra-lightweight LJ20 axles I could pair with this (listed separately here on Pirate).
I also have two (2) other LJ10/LJ20 transfer cases that are in good-functioning condition, but need new seals. One is an LJ20 case, and the other is an LJ20V (van) case with slightly higher gearing.
$450 for the restored one. $225 each for the non-restored by good-functioning ones needing seals. Located in Grand Rapids, Michigan (49503).
Craig
1x1_Speed_Craig is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 07:10 PM   #2 (permalink)
adamwende's Avatar
Member # 193461
Iíll take it since itís free.
AZ Undertaker
adamwende is offline   Reply With Quote Quick reply to this message
Old 08-04-2019, 08:51 AM   #3 (permalink)
Member # 39799
There's always one smart ass... . Thanks for the heads-up. I updated my original post with prices.
Craig
Old 09-08-2019, 06:14 PM   #4 (permalink)
Member # 39799
Bump for Bueller...Bueller...Bueller.
Old 09-11-2019, 09:12 AM   #5 (permalink)
Member # 39799
SOLD
