Another Allroad C5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Expedition Vehicles
Old 10-30-2019, 08:18 AM   #1 (permalink)
Mr. Mindless's Avatar
Member # 24238
Another Allroad C5
I don't know if Expedition is the right place to put this, but it's sure as hell not hardcore 4x4... And maybe someday it'll get a rooftop tent that costs as much as the car did 😂
Back in February of 2012, I drove an AMC Eagle back from Colorado Springs that I found during a work trip to Denver. I sold it in October 2015 after daily driving it at 13 mpg and 100 horsepower through a 3 speed slushbox and I'd loved it. I did almost 12,000 miles on it. It never gave me any significant issues. It was the last daily driven 4x4 I had. I've missed that for fooling around, exploring, wintertime fun, and yes - just repping myself on the road. I love my Mk4 Volkswagens, but it's been time for a change for a while.
Something reminded my that C5 Allroads exist and I started looking. I looked at one locally that had some issues. I messaged and chatted on a couple more in the northeast. I'd much rather put sweat equity into a vehicle than buy something nice because I'm an idiot.
They all had some issues. Un-trustable automatics, drivers door rust, oil leaks, coil spring conversions...
I settled on one that hopefully wouldn't have rust issues, that does have oil leaks and suspension issues, and I bought it sight unseen with a one way ticket to fly & drive back ~2500 miles from Salt Lake City.
I knew it had some sort of halfassed steel spring conversion done, and that it had rear alignment issues. Seller said he quit driving it when rear cords were showing, both rears looked like this after I put about a hundred more miles on it and finally got to take them off.
I found a cheap set of Audi tires on KSL and intended to slap them on, but the 18s it had mounted had both wheel spacers and hub ring adaptors. The lug bolts were too long to run no spacers, and the rings didn't want to come off. I got a hand from JT from Nemesis introducing me to Captain Rob, and we got those aluminum rings off the aluminum spacers and I was on my way home via Moab and Arches NP. I've been around St. George and Sand Hollow but this was my first time beyond the core of SLC.
Mr. Mindless is offline   Reply With Quote Quick reply to this message
Old 10-30-2019, 08:20 AM   #2 (permalink)
Member # 24238
I made it up and over Ike and had no issues crossing all the way on 70 to 271 to 90 and home.
The first thing I did was get a used air suspension set on the way, and I've got the rear slapped in.
It leaks down in an hour right now because of not having a proper o-ring in, but it validated what vag-com told me about the system: it's present and still working.
I've got aluminum in stock to turn spacers for the front, and I've got some Delrin on the way for a 1" spacer in the rear.
New front upper control arms are on the way, one on the passenger side is really bad. It's loose in the knuckle with the pinch bolt scary tight, hopefully it's the rod end that's worn and not the knuckle casting, but I'll find out next week when I tear it down.
I'm picking up some tires tonight. 225/70r16 on some Sparco wheels that I think are just the look I'm after.
Then I'll figure out proper spacing and adaptor to get them on there.
The rear suspension toe adjuster is seized on one side, have to deal with that as well.
I just got delivery notification on timing belt kit & tools, and valve cover and cam seals. Looking forward to no more oil leak on headers stink.
Once the suspension is happy, I'll be thinking about power upgrades. When I remember it's not a diesel and I need to spin it faster than 3k I'm quite pleased with it, and I know nothing I do with e85 or K04 turbos is gonna increase power at 2200, so I may just back burner that. But I think a friend of mine has a set of turbos and I know he has a tuned computer from his RS4 2.7T, and I've got another friend who worked at Street Tuned Motorsports for years and knows how to make power on these things with boost and corn, so stupidity may come when I decide to spend more an this than on the real toys.
Old 10-30-2019, 07:13 PM   #3 (permalink)
Member # 24238
Looks so good it was hard to take them off, but I donít have proper rings OR good bolt figments so setting down on them was as much as I was willing to do. Trash wheels are back on now.
Current spacers are 0.610Ē (15mm)
Little cozy without some shifting of things on the front of the front at full lock. Unsurprising.
EDIT to fix retarded image size.
Old 11-04-2019, 11:21 PM   #4 (permalink)
Member # 24238
Didnít wrap up timing job tonight as expected. Had some issues on first start, which I did at 90% assembly like a confident idiot.
I did chain guides and got bank 1 intake and exhaust off by 1 tooth. The cam chain tensioner is a fooler. I have a photo of it when I was putting it together and it looks right. It threw codes and didnít run right and I took the cover off and it was off by a tooth. Managed to pull the slave cam and tensioner and fix it without tearing the front of the motor off again. I considered that an accomplishment until I finished it up, filled coolant, and had a gross leak.
Couldnít find. Looked for about 2 hours. It was appearing at the bottom back corner of the block. Iíd accidentally pulled one of two bolts on the crossover tube between the backs of the heads but that wasnít the leak. It HAD to be the thermostat housing. Makes no sense - wrong place for it to dribble. And definitive check means FULL tear down since thatís behind the timing belt.
I pressurized the system in hopes of speeding the leak to better locate, and it sealed up. Weíll see if that lasts but it was leaking with an open cap as I was filling, and it went up to temp sealed now without issue. As for when it cools? Iíll find out.
But worse yet: itís still not running right. Didnít clear up with idle time nor a couple miles driven. Bank 1 is collecting misfires and sounds like a gross exhaust leak. Doesnít sound any different than when cam to cam timing was off. This is the same bank that I was off by a tooth earlier.
Might check compression, but I have zero indication that anything touched. Did 3-4 full revolutions before firing both times, and never had any noises of disaster.
I did have to R&R the ďcombiĒ (EGR If I understand right) valve twice Ė valve cover doesnít clear, and removing tensioner requires full removal Ė but it passes visually, and I canít feel any exhaust leak when idling. And I do hear it. Stethoscope doesnít seem like the exhaust-like sound is coming from that valve either.
Itís even loud in the car under acceleration. It _really_ sounds like an exhaust leak. I donít get it.
Not giving up, but may have to throw to the Audi forums.
Definitely know it intimately now.
The tires are on too. Had to trim 20 bolts
Found that out after bottoming 10 of them in the front knuckles. Hope I didnít take too many miles off the bearings with that dumbassery.
Really was hoping to move on to suspension now and be done with the motor! I did notice that all the front bushings are wasted, so it should really get all arms. Not just the uppers I ordered.
Money pit!
Old 11-04-2019, 11:25 PM   #5 (permalink)
Member # 24238
I was proud of this finangle until it didnít fully solve my issue.
If the cams are indeed in time with each other now, since it was assembled and tensioner with the lock bar in place and isnít throwing codes other than misfire, Iím not sure whatís up.
I could swap coil packs around, but theyíre not original. I really doubt they are the issue. New plugs are same as the old plugs. I didnít touch that turbo at all.
Old 11-05-2019, 08:59 AM   #6 (permalink)
Member # 24238
I realized can check chain tensioner with 2 bolts and the cam position sensor. Pull that cap in 45 seconds, if the intake cam can rock back and forth the tensioner isn't working right in spite of not setting a code. If the cam seems tight, it's almost got to be a combi valve exhaust leak in spite of not being able to feel it.
Old 11-07-2019, 05:55 AM   #7 (permalink)
Member # 192237
on the exhaust leak on those, there's a post-turbine EGT sensor that likes to get loose
right next to the o2 sensor, iirc so it can suck air and make the fuel trims get stupid
Old 11-07-2019, 06:19 AM   #8 (permalink)
Member # 24238
Cam was tight on that test, I'm driving it with the exhaust leak. Seal is on order, it was days out for anyone local anyway so it'll be here next week from rockauto.
I'm thinking back to when scangauge was cool and how it would be nice to monitor those EGTs since the sensors are right there.
When I threw the rear air struts in I didn't have proper replacement o-rings in hand, I put oversized ones on and face-sealed. It worked but leaked down fast (hours). I replaced the audible leaker right away but ignored the other. Finally did that last night and the rear held air all night, no visible sag.
One of the rear air struts has a nice rattle to it. ebay seller doesn't seems super excited to make it right even though the set of 4 used take outs were "tested" with a 30 day warranty. It's not worth the hit to me to lose 2 way shipping on that deal to come out with nothing. I'll probably just put new rear struts in those bags sometime.
Haven't put the front on air yet. I did just get the new front upper link set, but I noticed while I was working on it that all the lower arm bushings are looking pretty bad too, I've got a bad left axle inner boot, and the boots are bad on the tie rod ends too. Typical 15 year old 200k car stuff. I'll probably deal with all that in the spring. Weather is turning and I've got other things to worry about.
Old 11-07-2019, 12:57 PM   #9 (permalink)
Member # 24238
Partial refund on the way for that bad strut.
Thinking about the wasted bushings on the front lower arms, and whether I should think about fabricating tubular arms with heims, or replace with molded in bushings. For a road car I'm thinking factory replacements are the way to go. Any nay-sayers?
Old 11-07-2019, 04:56 PM   #10 (permalink)
Member # 192237
pyro on a gas motor is totally irrelevent except for catalyst heating concerns
the only thing it is used for in airplanes and old racing cars is for a very crude AFR (adjust mixture for peak EGT)
I love the polyurethane LCA bushings on mk4 A chassis cars, bet they're just as drastic an improvement on the B platform
wouldn't go heims in the salt
Old 11-15-2019, 10:13 AM   #11 (permalink)
Member # 24238
This chassis is a C5 platform. A4 Audi and Passat are B chassis, A6 is a C. And of course the shit we're both used to in Golfs and Jettas is A chassis.
I have all new control arms in, lowers are all Delphi. Only thing still orginal will be swaybar links and bushings.
new left front axle is in.
4 sets of pads in.
Supposed to be warmish on Sunday, might do it all then. Front air struts will go in, too. See if the shocks on them are as blown as the rears are. At least then I'll be able to set it a bit higher for better spring rate and more uptravel to keep from bottoming out in back until I put fresh shocks in.
If I never play with ride height I'll probably set it up with proper height steel springs around its current height, or maybe half an inch higher. It's a good stance and if it's rubbing anywhere I haven't noticed. Front fender liners are back in, got that before snow.
Love this car every time I look at it.
Driving dynamics when it slides around are absolutely on point - it just feels SO. HEAVY. compared to all my A4 chassis cars in all other circumstances.
Old 11-19-2019, 11:22 AM   #12 (permalink)
DT75FLH's Avatar
Member # 101209
looks like a cool project.....
now update your hauler thread
[COLOR="DarkRed"]Difficulty is the excuse history never accepts.
A Nation of sheep will beget a Government of wolves.[/COLOR]
Edward Murrow
DT75FLH is offline   Reply With Quote Quick reply to this message
Old 11-19-2019, 01:20 PM   #13 (permalink)
Member # 24238
Gotta do something with it to update!
I think. I should look how out of date it is...
Double occupancy is the box is super close, just need to shorten some crossbeams and add some tiedowns. Need to do that and swap power steering pump in the brolite so I can free up the garage!
I don't think I'll get shower/shitter done this winter, but I should get the cab trim put back up with some slight insulation improvement.
Old 11-27-2019, 06:15 PM   #14 (permalink)
Member # 24238
Another Allroad C5
All new front suspension links in and fresh brake pads all around. Air struts are in the front now and replaced left front axle shaft that had no inner boot. Took me a while to dial in ride height adjustments with the ď402 modĒ* since it wasnít really working as expected but I think that was due to vag-com sessions getting interrupted and settings not sticking. Took a bit but I got that settled. Have level 1 just a hair lower than standard level 2 (397 front 400 rear). Everything seems to be working as it should. Front shocks are in much better shape than the rears so no ride complaints. No issues with the bags. Hopefully a donít see a bunch of settling overnight.
I definitely want to put strut spacers in the front, my tires are touching fender liner all the way around without any air in the bags. Zero limp-home capability right now. But for $3/mo I do have towing and recovery without needing to carry full coverage so Į\\_(ツ)_/Į
Itíll be fine! (In the short term)
Ride is mushy shit on 1, good on 2, and downright firm on 3. Hard to judge on 4 staying under 20mph.
Level 3:
Ride heights with the Allroad are based on 402mm from centerline to fender flare on level 2. L1 is -20mm, l3 is +20 and l4 is +40 - limited to 20mph.
In vag-com, the suspension height is calibrated by measuring actual, entering that for each corner, and the suspension compensates. So if youíre actually at 402 but you tell it youíre at 392, itíll raise ride height by 1cm. I should have been able to get to where I got by just putting in 387 for all 4 but I think my heights were previously fiddled with, and I had some connection interruptions that got real frustrating. So it took longer than it shouldíve.
Old 11-28-2019, 10:45 AM   #15 (permalink)
Member # 86724
it's perfect.
I probably just would have bought an x3 though and saved myself a lot of headache.
here's my daily driven awd krautwagon on it's freshly rustoleumed craigslist oversized winter tires/wheels.
Old 11-29-2019, 06:31 PM   #16 (permalink)
Member # 24238
I like an X1/X3 or a GLA from outside. Never been in any of them, and both exceed my price range of ~4 car payment purchase price for a daily.
Front air suspension is leaking down overnight
No leaks at the air spring air line that show from a soapwater spraydown. Didnít try changing o rings again to see if that helps.
Old 11-30-2019, 06:48 AM   #17 (permalink)
Member # 86724
the first generation x3 is essentially my car,taller and heavier.
which is why it's dumb.
I always thought the allroads were cool as shit, but I have a deeeeeeeep hatred for all things VAG.
I see people are making puck spacer lifts for the xc70/90's and I've considered lifting my wifes volvo, but then that's just a bad idea because it works and it's reliable as a hammer.
Old 12-03-2019, 04:22 AM   #18 (permalink)
Member # 82644
Never stopped you before.
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE]
hadfield4wd is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 07:21 AM   #19 (permalink)
Member # 86724
lessons learned man.
lessons learned.
I think we'll keep it riding nice and maintenance free. I just put new struts/balljoints/contrl arms up front.
Old 12-04-2019, 07:54 AM   #20 (permalink)
Member # 24238
you must be getting old.
Old 12-04-2019, 08:27 AM   #21 (permalink)
Member # 86724
yes.
I've also come to realize that sometimes I am not capable of improving upon millions of dollars of corporate engineering of suspension parts.
I know, blasphemy around here.
Old 12-14-2019, 04:15 PM   #22 (permalink)
Member # 24238
Did a seasonal road poker run today. Just what this is supposed to be for and it was nearly flawless. 80mph for 2 hours there and back through a blizzard, bunch of ice and ruts and mud and rain and great traction clearance and stability throughout while down there.
Suspension errors on the way home though. Gotta pull codes tomorrow. Had to key cycle a few times on the way home.
Old 12-19-2019, 10:09 AM   #23 (permalink)
DMG
Member # 8145
That is such a cool platform, it almost makes me want to toss all the problem parts and build a drivetrain and a mid travel suspension
DMG is online now   Reply With Quote Quick reply to this message
Old 12-19-2019, 01:25 PM   #24 (permalink)
Member # 24238
suspension codes were because one rear corner decided it was 1" low. I just let it level out and then re-zero'd them via "402 mod" process. Didn't investigate or measure actual but eyeball looks fine.
Haven't found the left front leak yet.
Old 12-30-2019, 02:01 PM   #25 (permalink)
Member # 86724
parts car?
https://www.facebook.com/marketplace...4713688082185/
