Ford Ranger TTB build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-19-2012, 04:19 PM   #1 (permalink)
Member # 197879
Ford Ranger budget build
Thought I'd share my build with you folks. I understand it's not that "extreme" but it works beautifully for me.
Enjoy:
I originally bought this truck for $400. Mismatched body panels, cracked heads, no exhaust, broken front diff, etc.
Got it running, played with leveling coils and got bored quickly enough.
Swapped in an expo 8.8 with 4.56s and an Aussie locker. Front Dana 35 got the same minus the locker.
I noticed awhile back that there was not much information about adapting EB (Early Bronco) coils onto the TTB suspensions. I figured I would pass on my knowledge from my build.
I started my build by grabbing a set of stock Dana 35 TTB radius arms. I ordered up 6 feet of 2" O.D. square tubing 1/4" wall. I cleaned up my radius arms and cut measured where 2" would fit snugly inside them. I incorp. 4 degrees of caster into the beams when I welded them up. I also welded new shock tabs onto the arms to eliminate the stud design. Im sure most of you have replaced their fare share of them. It's a good idea to drill 2 or 3 holes in the arm and plug weld them back shut. I also ended up plating the bend in my arms with 1/8" plate. I used rod ends for the end of my arms. Ended up using Ballistic Fab rod ends with a 1.25" thread and 9/16" through bolt. Here's where I got creative. Everyone I talked to said they hated the tires rubbing on their arms. So, I got the bright Idea to put a bend in them. Doing some measuring, I came up with 18 degrees. That angle is perfect for eliminating any tire rub within reason and still keep proper suspension geometry throughout the suspension cycling.
Here are my mounts. Everything is 1/4" plate welded with a 220 Mig welder. I also welded washers to the rod end mounting point for extra strength.
With the amount of suspension travel I'm creating, I had to remake my transmission crossmember. I ran into trouble with clearance having an auto transmission. Here's my finished product.
Last edited by brinker88; 11-23-2012 at 05:21 AM. Reason: Build took a different direction
brinker88 is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 04:19 PM   #2 (permalink)
Member # 197879
I had to get skyjacker beam drop brackets due to clearance problems with the "ever popular" drop plate drive side bracket.
To adapt EB coils to the ranger TTB you need to do 2 things. Make an adapter plate for the bottom of the coil spring, and cut the FRONT tabs off the coil bucket. I used BC Bronco's 3.5" coils. Looking back, I should have gotten their 3.5 coil with winch due to having to add 5/8" spacer to level the truck.
For the upper coil retainer, I used a piece of 1/8" flat stock and bent it up around the coil and bolted it together, acting as a clamp
Here you an see the difference between a stock extended cab coil, a 4" TTB coil, and a 3.5" EB coil
To properly use the flex you've now created, you need to have a shock long enough to not limit it. My solution was cut the stock coil bucket, plate it, and bolt an F250 shock tower next to it. I ended up using a BDS shock with 35.5" extended and 20.4" collapsed length.
Steering is another thing that DEFINITELY needs to be addressed when using flexy coils. TRE binding WILL occur with stock steering and suspension traveling while driving WILL occur. I used a modified stonecrusher steering setup with 3/4 ton GM T.R.E's but you could also use Superunner steering. I later modified this setup with some bends for clearance issues and swapped out the FA600 for an FA400
* DO NOT FORGET TO CHECK FOR CLEARANCE ISSUES!!!!* I ended up trimming my passenger side axle shaft due to binding as well as opening up the passenger side window for the shaft.
Final Product:
:icon_thumby:
Full droop:
Old 09-19-2012, 04:20 PM   #3 (permalink)
Member # 197879
Steering at ride height:
Radius Arms:
Truck.
Old 09-19-2012, 04:47 PM   #4 (permalink)
Member # 127442
Pretty cool!!
77 F-250
Ford rules is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 05:42 PM   #5 (permalink)
Member # 202878
x2
looks way more hardcore than some of the other ttb threads on here.
i like it
423-883-2456 Donovan
[COLOR="Lime"][FONT="Comic Sans MS"]<----Click here to see our full line 4x4 products![/FONT][/COLOR]
[FONT="Century Gothic"][SIZE="4"][COLOR="Silver"]full inventory of Advance Adapter products![/COLOR][/SIZE][/FONT]
[FONT="Impact"][SIZE="4"][COLOR="Red"]your premier source for RCV Performance products[/COLOR][/SIZE][/FONT]
FordX4-offroad is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 07:32 PM   #6 (permalink)
bobbywalter's Avatar
Member # 15473
Send a message via AIM to bobbywalter
well you know i am on this train
if only
88 ranger ext cab p.o.s. hackjob powered by a 6.5 diesel clattering against a 4l80 thats punishing a f208 that is turning ford 60's rolling on 33-44 inch tires depending on the mission at hand
how ya like me now??
bobbywalter is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 07:35 PM   #7 (permalink)
Member # 197879
Lol bobby. Of course you are.
And everyone else, Thanks for the compliments. I've been dreaming of building a decent TTB suspension for awhile now. I'm glad that I did.
Old 09-19-2012, 08:01 PM   #8 (permalink)
Member # 152532
Fucking Sick.
Edit: I think your HF engine crane needs some reinforcement.
f350n4.6ranger is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 08:05 PM   #9 (permalink)
Member # 197879
Originally Posted by f350n4.6ranger View Post
Fucking Sick.
Ya think? POS thing. It's gettting gusseted and welded. Guess that's what you get for $150 though.
Thanks for the compliment dude!
Old 09-19-2012, 08:16 PM   #10 (permalink)
SAY789's Avatar
Member # 88573
Send a message via AIM to SAY789 Send a message via MSN to SAY789
Nice! Always loved a properly setup ttb
'94 F350 CC .030 460 Auto 4x4 "Tow Rig"
'78 F350 Sittin Pretty On 39.5 Boggers R.I.P.
'94 Ranger 3/4 ton 5.8L 38.5 Boggers
Taylor
I think I heard that the model with the rear blocks and neg arched fronts was the super rare model called a Medium Boy.
SAY789 is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 08:38 PM   #11 (permalink)
Member # 83430
Thats pretty good droop on that thing. Heres my old F-150 maxed out with extended radius arms with regular old bushings for comparison.
I speak duck. Call me a quack, it's right on target.
InDaRed2 is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 08:41 PM   #12 (permalink)
Member # 15473
thats pretty good for a every day all around work tool
if only
Old 09-20-2012, 06:46 AM   #13 (permalink)
mjlogan88's Avatar
Member # 23553
Nice man, thats a lot of travel for a coil bucket setup. Never thought about doing the steering that way. How does it look at full bump? Geometry isnt perfect, but way better than stock.
Box in the back of that passenger side beam before it cracks. And that upper coil retainer clip you made can be found stock on F150s.
mjlogan88 is offline   Reply With Quote Quick reply to this message
Old 09-20-2012, 07:30 AM   #14 (permalink)
Member # 192237
This, the joints look to be nice and close to the beam pivots. I'll likely go this way if my other ideas don't work out.
Old 09-20-2012, 08:39 AM   #15 (permalink)
Member # 197879
The steering is called StoneCrusher steering. I found some examples online and elaborated on it a little bit.
So for, the truck tracks great.
The beams are only in there temp. Im building a set of trussed beams.
Old 09-20-2012, 09:47 AM   #16 (permalink)
mjlogan88's Avatar
Member # 23553
My only problem with it is as the passenger side cycles it drags the driver tire around with it more than a factory setup would. But that would only be at extreme travel. Anywhere near ride height his setup looks to be much more ideal than stock. Only way you could do it better would be with swingers.
Old 09-24-2012, 08:24 AM   #17 (permalink)
Member # 197879
No real updates lately. Been too busy winterizing the house.
Have to do a waterpump here this weekend and will take it on some trails around the house. Will get photos ( I know y'all are photo whores! )
Old 09-24-2012, 06:29 PM   #18 (permalink)
Member # 123663
I LOVE your steering setup
1966Tbird is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 06:37 PM   #19 (permalink)
Member # 197879
Thanks. It's the simplest, cheapest and strongest I could come up with. I couldnt do swingset steering due to not having cut/turned beams.
Old 09-24-2012, 06:50 PM   #20 (permalink)
EricsGreen98Tj's Avatar
Member # 187456
Dam im impressed. Seriously. Good job man, I'd shake your hand if you were around here.
Have you broken anything in the front end since you've "lifted" it?
Man, the expedition forum is
'r than gcc
If you fuckers actually took a second to read the words rather than knee jerk reacting to the pics, you might have a clue what his plan is.
EricsGreen98Tj is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 06:58 PM   #21 (permalink)
Member # 197879
Thanks dude! And no, Havent taken it out on it's maiden voyage yet. Still need to do a water pump. All I've done is a quick shakedown test on the road and stretching the suspension out a little to check for clearance issues. So far, so good. The truck rides amazing with the sway bar hooked up.
Old 09-24-2012, 07:15 PM   #22 (permalink)
Member # 202878
hey post up some more pictures/tech of your swaybar setup. ive been looking through the junk yard at different swaybars to mount to mine for hiway driving.
Old 09-25-2012, 04:15 AM   #23 (permalink)
Member # 197879
Im using the stock 7/8" sway bar with heim joints
Old 09-25-2012, 03:20 PM   #24 (permalink)
Member # 10063
WTF did you hear that BS from?
C&T beams have no relation whatsoever to the steering, other than it simply needing to be built to match up to where your beam pivots are. What might be tough however is packaging it up in such a way to where everything clears the 4WD front diff (a K-link setup does wonderful here).
Nice work on what you have though, regardless.
One of these years I need to get to puttin' the 1-ton TREs on mine too...
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
Old 09-25-2012, 03:32 PM   #25 (permalink)
Hyde's Avatar
Member # 53554
Pretty nice setup. If I hadnt had a set of already narrowed 1/2 tons thrown in my lap for the Explorer this would have been good inspiration
A pile of parts 94 Explorer, 5.0, t18, np205, narrowed D44 and 9". Will never be finished
Hyde is offline   Reply With Quote Quick reply to this message
