Trail/ desert project "heavystroker" f-250hd build. - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-05-2013, 11:01 AM   #101 (permalink)
dieselboy740's Avatar
Member # 168108
Originally Posted by FordX4-offroad View Post
is the steering box area usually a weak spot?
Actually all the ones I've seen crack start down low at where the cross member ties into the frame rail. It then works its way up. I decided to plate it in because overkill is better errrrr. I also welded the engine cross member in all the way.
Next weekend ill tear apart the donor truck.
'97 f-250 7.3, project, 3 link front, 4 link rear, back halved, fox co/bypasses/bumps, etc....
'08 f350 cclb 4x v10
'93 Volvo 940 fake rally car #trophyvo
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 05-05-2013, 03:48 PM   #102 (permalink)
Member # 168108
Originally Posted by reklund5 View Post
Great looking build! Any chance you can still read the part numbers on those floor reinforcement plates? I put some buckets in my '92 and they're leaning bad- I'm curious if those might fit the later cab and solve my issue.
Ryan
That led me to this
1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net
Old 05-05-2013, 03:51 PM   #103 (permalink)
Member # 168108
Old 05-06-2013, 05:04 AM   #104 (permalink)
Josh40601's Avatar
Member # 171332
Looks good brother
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 05-06-2013, 05:17 AM   #105 (permalink)
Member # 182723
Could sleeve it and use a few hitch pins?
kris97ranger is offline   Reply With Quote Quick reply to this message
Old 05-06-2013, 02:22 PM   #106 (permalink)
CLF
Member # 186919
I like where this is going
CLF is offline   Reply With Quote Quick reply to this message
Old 05-07-2013, 08:43 AM   #107 (permalink)
Member # 224153
This is cool. I prefer the brick nose though. I miss my '90 F250 SC
I don't collect guns (or vehicles), I accumulate them!
bigghoss is offline   Reply With Quote Quick reply to this message
Old 05-07-2013, 03:07 PM   #108 (permalink)
150
Member # 167647
So I see the cutout along the interior of the roof. are you gonna be running an interior and exterior cage?
this just for added safety?
1989 f-150 dana 60 front, 10.25 rear. 3 link with coil overs out front. chevy 63s double shackled out back. bobbed bed. rollin on 37s
the build up of ^ truck
150 is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 10:00 PM   #109 (permalink)
Member # 168108
Yeah it's going to be around 6500+ lbs when going on trail runs. I want to feel safe.
I cut out a area in my back yard to disassemble the old truck and steal its parts that I need.
Old 06-04-2013, 05:56 PM   #110 (permalink)
Newbie
Member # 242585
why no B pillar exo tube?
TacosGrande is offline   Reply With Quote Quick reply to this message
Old 06-04-2013, 09:17 PM   #111 (permalink)
Member # 168108
I might.
Pulled the d60 from the donor
Old 06-05-2013, 09:42 PM   #112 (permalink)
Member # 168108
Artec kingpin truss fits the 94-97 balljoint trucks too.
Old 06-09-2013, 04:43 PM   #113 (permalink)
Member # 168108
Welded the truss on
Going to use some 3/8" to make the steering double shear and brace the knuckle a little too.
Pull the front clip
Remembered that you can't pull the engine and trans together so I pulled the 4 bolts and took the cab off.
Going to make my own regulated return electric fuel system. Also going to make my own bellowed up pipes to fix the small leak.
Old 06-10-2013, 06:41 AM   #114 (permalink)
BadAssEddie's Avatar
Member # 147534
Send a message via Skype™ to BadAssEddie
Sweet project man. It's coming along nicely
BadAssEddie is offline   Reply With Quote Quick reply to this message
Old 06-10-2013, 12:13 PM   #115 (permalink)
Member # 104270
This build is moving along nicely, can't wait to see it done!
Fueled by Hate, caffeine, and sometimes whiskey.
[COLOR="Red"][SIZE="5"]WTB pulley cover for 1959 Homelite 9-23[/SIZE][/COLOR]
[COLOR="Red"][SIZE="5"]Semper Fi[/SIZE][/COLOR]
br0nc0xrapt0r is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 12:42 AM   #116 (permalink)
Member # 217775
This thread is relative to future plans, subbed
OutlawedRacing is offline   Reply With Quote Quick reply to this message
Old 06-12-2013, 08:24 AM   #117 (permalink)
Member # 120478
Nice progress, I just did one of those artec 60 trusses too, shit ton of welding! Whats your front suspension plan, 3 link?
Wheeler ->
90 Bronco with stuff
Dan90FSB is offline   Reply With Quote Quick reply to this message
Old 06-15-2013, 02:34 PM   #118 (permalink)
Newbie
Member # 242585
or just find the T444E bellowed up pipes?
Old 06-15-2013, 04:05 PM   #119 (permalink)
Member # 168108
Lol yeah for 8-900$
Pulled the engine and trans. (I love my crane) then pressure washed the crap out of them (not pictured)
This was the main oil leak I had
Cast iron tail housing/ tcase adapter from a 02 f350
Old 06-15-2013, 09:15 PM   #120 (permalink)
107096's Avatar
Member # 107096
Ya gonna double up the cases?
107096 is offline   Reply With Quote Quick reply to this message
Old 06-16-2013, 11:38 AM   #121 (permalink)
Banned
Member # 91791
Send a message via AIM to g-wizz
instead of bellows you might want to try stainless pipes with a slip fit, or even with out. small to big in regards to exhaust flow to the turbine for the slip fit.
prob a piece of stainless sch40 pipe would be your best bet.
g-wizz is offline   Reply With Quote Quick reply to this message
Old 06-16-2013, 06:01 PM   #122 (permalink)
Member # 168108
Not at this time.
Old 06-16-2013, 07:30 PM   #123 (permalink)
Member # 182723
Dont see the point of a doubler in a diesel. As is my zf5 speed in single low is already too low for anything that isnt a high traction deal. Need to be in 2nd or 3rd to bump anything
Old 06-16-2013, 08:56 PM   #124 (permalink)
brandon_halter's Avatar
Member # 145505
[QUOTE=dieselboy740;19008074]Lol yeah for 8-900$
this^ imagine pulling it out with an engine hoist and moving around by yourself. sweet build, im digging the boatside cage idea. I plan on something similar on my crew cab.
yupp!!
brandon_halter is offline   Reply With Quote Quick reply to this message
Old 06-17-2013, 11:07 AM   #125 (permalink)
Wh1t3NuKle's Avatar
Member # 200856
Nice that is some good info on the truss. Happy with how it sits on there? Did you set it relative to caster angle or other? Did you stitch to the diff housing (I can't tell from your pic)?
As someone else asked, what link setup you going to run?
Looks like it's this truss: Artec Industries Ford 81-91.5 Dana 60 Front Truss
Thanks!
Welded the truss on
Wh1t3NuKle is offline   Reply With Quote Quick reply to this message
