Trail/ desert project "heavystroker" f-250hd build. - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2013, 10:19 PM   #126 (permalink)
Member # 64440
Looking good buddy!!!
Ready for TDS?
bigredkacy is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 01:04 AM   #127 (permalink)
dieselboy740's Avatar
Member # 168108
Ready for TDS?
Doubt it. I have a lot more to do and low funds.
'97 f-250 7.3, project, 3 link front, 4 link rear, back halved, fox co/bypasses/bumps, etc....
'08 f350 cclb 4x v10
'93 Volvo 940 fake rally car #trophyvo
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 06:21 PM   #128 (permalink)
Member # 202878
Originally Posted by kris97ranger View Post
Dont see the point of a doubler in a diesel. As is my zf5 speed in single low is already too low for anything that isnt a high traction deal. Need to be in 2nd or 3rd to bump anything
i never got a chance to try a doubler in my truck but i know it wouldve worked way better. anxious to see how this one turns out. i do miss my old truck.
423-883-2456 Donovan
[COLOR="Lime"][FONT="Comic Sans MS"]<----Click here to see our full line 4x4 products![/FONT][/COLOR]
[FONT="Century Gothic"][SIZE="4"][COLOR="Silver"]full inventory of Advance Adapter products![/COLOR][/SIZE][/FONT]
[FONT="Impact"][SIZE="4"][COLOR="Red"]your premier source for RCV Performance products[/COLOR][/SIZE][/FONT]
FordX4-offroad is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 07:40 PM   #129 (permalink)
Member # 222119
Originally Posted by dieselboy740 View Post
Remembered that you can't pull the engine and trans together so I pulled the 4 bolts and took the cab off.
Just FYI it is possible, but you have to pull the transmission crossmember (or cut it).
rjjp is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 07:58 PM   #130 (permalink)
Member # 168108
With a diesel? I've tried and you can't rock them back because the turbo/ heads hits the firewall and the oil pan binds on the crossmember.
I gutted the valley and cut the head off a dt466 piston to use it as a mount for my fuel pressure regulator and to hold the plug in the old fuel pump hole.
I also got everything to convert to a van turbo so when I got the funds I can bolt a gtp38r in place.
Old 06-18-2013, 11:21 PM   #131 (permalink)
Member # 222119
I've done it multiple times, I cut the motor mount bolts, 3 cuts on the crossmember, and put the hood through the windshield with the loader, then hooked the chains and lifted it with the loader while backing away from the truck.
Old 06-21-2013, 12:44 PM   #132 (permalink)
Member # 168108
Ordered a set of fox 2.0 bumpstops and waiting till the 4th sales start to order front links.
Old 06-21-2013, 11:02 PM   #133 (permalink)
Member # 168108
Picked up my bump cans today.
Old 06-22-2013, 09:44 PM   #134 (permalink)
Member # 172772
Awesome build... Making me think about cutting my truck up haha
85 K10: 350/Th350/205, steel wheels w/32x11.50s
Level_B is offline   Reply With Quote Quick reply to this message
Old 06-23-2013, 10:20 PM   #135 (permalink)
Member # 175411
What did your old leaf spring suspension consist of? Any interest in selling it or parts of it?
Big dumb old ford with a cummins and some 42s
Joecochrane is offline   Reply With Quote Quick reply to this message
Old 06-24-2013, 10:45 AM   #136 (permalink)
Member # 168108
They were bronco springs that are no good anymore. The front had profender shocks 2.0x14". I think I might sell them
Old 06-27-2013, 08:43 PM   #137 (permalink)
Member # 168108
I need a set of 3" intakes.
Made the 1/4" in to 1/8" x2 piece myself as I couldn't find anything I liked that kept it tidy.
Once I get the 3" intakes ill sort this out.
Old 06-28-2013, 06:58 PM   #138 (permalink)
Newbie
Member # 242585
is that a homemade regulated return system or did you buy a kit? looks nice either way.
TacosGrande is offline   Reply With Quote Quick reply to this message
Old 06-28-2013, 09:55 PM   #139 (permalink)
Member # 168108
I built it all.
Got my bumpstops today. It almost like I know someone that works at fox.
Old 06-29-2013, 12:05 AM   #140 (permalink)
Member # 175411
Do you still have the profenders how did they work with the bronco springs. How did the bronco springs do trying to decide on a spring pack to use on the front of my truck. Sorry to be a lil off topic.
Old 06-29-2013, 07:25 AM   #141 (permalink)
brandon_halter's Avatar
Member # 145505
lots of shinny parts, im jealous.
yupp!!
brandon_halter is offline   Reply With Quote Quick reply to this message
Old 07-02-2013, 01:25 PM   #142 (permalink)
Member # 168108
My time was up at the shop so I had to take the truck home. I welded the front axle to the crossmember and trailered it home.
I cleaned up the van turbo but the pedestal I got with it isn't correct so I have to order a no ebv one for it to fit.
Old 07-29-2013, 07:56 AM   #143 (permalink)
Wh1t3NuKle's Avatar
Member # 200856
Specs on the shocks and bumps (2")?
I'm considering Fox as well. Are you going with these based on experience? Possible to get in touch with your contact for a potential order?
I built it all.
Wh1t3NuKle is offline   Reply With Quote Quick reply to this message
Old 07-29-2013, 10:41 AM   #144 (permalink)
Member # 168108
Fronts are 16" 2.5" 90/90 rears are 210/90. The bumps are 2" std valving 4" stroke.
As for ordering ill see what I can do. The vendors here have decent pricing too.
The truck hasn't been worked on much but I did manage to get my '97 donor cab stripped of what I needed and I should have the engine assembled this week.
I bought another truck that I'm going to build as a service truck so that's taking my time too.
Old 07-29-2013, 04:42 PM   #145 (permalink)
black01edge's Avatar
Member # 119614
Send a message via AIM to black01edge
what did you end up doing to make the steering double sheer? and are you going to run hydro assist?
yamaha motorcycle buggy
black01edge is offline   Reply With Quote Quick reply to this message
Old 07-29-2013, 10:04 PM   #146 (permalink)
Member # 168108
Haven't done that yet lol. I'm going to plate the stock knuckles in.
Don't know about hydro yet. I may in the future but as of now no.
Oh and got my turbo pedestal.
Old 07-30-2013, 06:30 PM   #147 (permalink)
Member # 219307
Location: Land of 10,000 lakes and lots of rusty trucks.
Don't forget about those red shop rags still sitting in the intake passages.
66CC is offline   Reply With Quote Quick reply to this message
Old 07-30-2013, 08:28 PM   #148 (permalink)
Member # 192237
rofl
good catch
Old 07-30-2013, 09:47 PM   #149 (permalink)
Member # 168108
Yeah yeah I know. Ill button it up sometime.
Old 08-06-2013, 01:06 AM   #150 (permalink)
Member # 81619
I built it all.
Can you go into more detail on the fuel system?
Thanks.
1st Recline Bn is offline   Reply With Quote Quick reply to this message
