My Diesel Build - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-31-2013, 12:46 PM   #76 (permalink)
69DieselLover's Avatar
Member # 210244
I lifted the body off so I could work on building my new transfercase crossmember. I had to modify the transmission crossmember after changing the tailshaft housing too.
Humboldt Hillbilly
My Diesel Sport Trac Build
69DieselLover is offline   Reply With Quote Quick reply to this message
Old 03-31-2013, 12:55 PM   #77 (permalink)
Member # 210244
I didn't get as far as I wanted... I got the transfercase in position but that's about it. Took a lot longer than I expected to get everything square. I was hoping to get both the front and rear drivelines at the same length but there was just no way. My intermediate shaft was as short as I could get it but it was just to long.
Humboldt Hillbilly
Old 03-31-2013, 01:05 PM   #78 (permalink)
Member # 210244
I also worked on my front shock mounts a little... until I ran out of gas for my welder. And it was to late to get any more, so I'll have to wait till Monday now.
Humboldt Hillbilly
Old 04-01-2013, 02:29 PM   #79 (permalink)
Member # 95468
Damn fine build man, you work for cat?
If you can't fix it with a hammer... it must be an electrical problem.
Beat it till it works or beat it till it squirts!
oldblue05 is offline   Reply With Quote Quick reply to this message
Old 04-01-2013, 03:30 PM   #80 (permalink)
espy59lc's Avatar
Member # 235922
Awesome build! I just bought my fiancee's dads old truck. He passed away Dec of '11 and his trucks just been sitting. I paid her mom $900 for it. It's a '93 F-350 CC Long Bed 4x4 with the 7.3 IDI non-turbo. I'm going to turn it into a mud truck.
I don't have the fab skills to do what you're doing so I'm going to run it off the original frame. Looking for some 2.5 ton Rocks and I'll probably go with some 46" military tires. The lift will probably just be leaf springs for now.
But I'm glad to see I'm not the only crazy person turning a heavy ass old diesel into a mud truck lol. Hows the 6.9 do power wise in the mud?
espy59lc is offline   Reply With Quote Quick reply to this message
Old 04-01-2013, 07:05 PM   #81 (permalink)
Member # 210244
I work for Pape' Machinery. It is a John Deere Construction and Forestry dealer in N. Cal, Oregon, Nevada, and Washington. It's a good company and I love my job.
Humboldt Hillbilly
Old 04-01-2013, 07:16 PM   #82 (permalink)
Member # 210244
It's been rebuilt, but with all factory parts. I also had it balanced and had the heads done. It has a non waste gated Banks Sidewinder Turbo. It has good power but it sucked in the mud with the manual transmission. If I tried to up shift it would fall off the boost and lug and then you couldn't get it back without downshifting. I plan on doing some head studs, a new IP, and injectors before it's on the road. That and the C6 should help a lot. May also change out the turbo but I havn't decided yet.
Humboldt Hillbilly
Old 04-01-2013, 10:19 PM   #83 (permalink)
Member # 210244
I had a little free time tonight so I built this bulkhead to run my steering hoses through the firewall. Just some scrap aluminum and some bulkhead fittings I got from work. I got lots of #6 JIC Parker hose fittings and 2 wire hose free when one of the local mills went from Parker to some other brand.
Humboldt Hillbilly
Old 04-07-2013, 08:06 PM   #84 (permalink)
Member # 210244
Had some time Saturday so I finished my transfer case crossmember.
Humboldt Hillbilly
Old 04-07-2013, 08:23 PM   #85 (permalink)
Member # 210244
Also had to add an additional mount on the side of the 205. Without it the transfercase assembly wanted to rock back and forth and I'm sure that would have been bad. Also had to make some minor modifications to the parking brake linkage and bracket to fit the other mount.
Humboldt Hillbilly
Old 04-21-2013, 05:15 PM   #86 (permalink)
Member # 210244
So I didn't get any real work done this weekend. Saturday I drove 6+ hours to Salinas to buy some Sport Trac parts I need. I found someone selling some headlights on CL and when I called them they said they also had the header panel I need and, more importantly, the drivers door I need. Got all the way there and the door was wrong. It was too long. I'm guessing it was from a two door Explorer. Anybody know what the difference between a four door Explorer front door and a Sport Trac front door is? I have not been able to put them side by side but they look the same to me. Any info would be great.
Humboldt Hillbilly
Old 04-21-2013, 05:56 PM   #87 (permalink)
Member # 130105
Dumb question but why the parking brake? This thing cant be street legal.
"TO BE OLD AND WISE YOU MUST FIRST BE YOUNG AND STUPID"
Midget28 is offline   Reply With Quote Quick reply to this message
Old 04-21-2013, 06:19 PM   #88 (permalink)
Member # 99619
One time a friend of mine got stuck halfway up a hill. He had to get out got a moment to plug in his winch controller while another guy was pulling cable. A snap ring in his transfer case broke and caused the transfer case shaft to slide, which took the t case from 4wl to neutral and his rig took a nasty tumble down the very long hill he was climbing. An e brake would have prevented this.
XJAbuzer is offline   Reply With Quote Quick reply to this message
Old 04-21-2013, 07:37 PM   #89 (permalink)
Member # 166808
Awesome build man. Digging the fab work. Keep up the good work.
When all else fails, get more beer and a bigger hammer.
Fullsizeford38 is offline   Reply With Quote Quick reply to this message
Old 04-22-2013, 07:32 AM   #90 (permalink)
Member # 210244
I find that sometimes while winching and such I need to be out of the cab, but I don't want to pull against the park pawl.
Humboldt Hillbilly
Old 04-22-2013, 07:42 AM   #91 (permalink)
Member # 208624
Pissin' it...excellence, that is.
Mountain Havoc Alum - '16
3rd place passenger seat ballast and pointer of rocks
93_Fummins is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 11:24 PM   #92 (permalink)
HouseofDiesel's Avatar
Member # 106654
Awesome direction. Lover the SportTrac body as well.
YouTube
thehouseofdiesel.com
Facebook
HouseofDiesel is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 11:55 PM   #93 (permalink)
Member # 210244
Thanks for the compliments everyone. Hopefully I will get some more work done this weekend.
Humboldt Hillbilly
Old 04-27-2013, 03:28 PM   #94 (permalink)
Member # 210244
So I spent some time packing my old Sport Trac door around the junk yard and after being told by everyone at the yard and every online parts recycling page that an Explorer door won't fit on a Sport Trac I bought one for a $100 and bolted it on. Good gamble, fits perfectly.
Humboldt Hillbilly
Old 05-09-2013, 10:42 PM   #95 (permalink)
Member # 210244
So, got a little done, not a lot... got the rear upper links in and dropped the frame to full bump. Just enough room for the fuel line and fitting. Also suprised at how close the angles are on the fuel tank sump and the link bracket. I didn't even have the brackets when I built the tank. Still need to install the rear shock brackets and flex out the suspension. Really looking forward to that step.
Humboldt Hillbilly
Old 05-09-2013, 10:56 PM   #96 (permalink)
Member # 210244
I also put my "new to me" header panel on with the bumper cover and head lights. I never had head lights before and it's getting easier to see how it will look... now I just need some fenders and marker lights.
Humboldt Hillbilly
Old 05-10-2013, 12:03 AM   #97 (permalink)
VAZ
Member # 165311
Fantastic work. You are a very skilled fabricator. I can't wait to see it done.
VAZ is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 11:11 AM   #98 (permalink)
Member # 216720
Holy big truck...Jesus that is a monster. I dig that it isn't just a pinion brake setup, and that it's a diesel...badass.
kfgk14 is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 06:07 PM   #99 (permalink)
Member # 175411
I'm guessing you already sold the zf5 set up but if you didn't I'm looking for one to swap out the c6 gear vendors combo in my tow rig
Big dumb old ford with a cummins and some 42s
Joecochrane is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 10:25 PM   #100 (permalink)
Member # 210244
I did sell it actually, sorry. $600 for trans with LUK heavy duty clutch and flywheel. Used that money towards my tires. If you are having a hard time finding a trans I can look around locally and see what I can find.
Humboldt Hillbilly
