Ring gear bolts backing out after using red locktite - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2016, 11:40 PM   #1 (permalink)
nvrstuk@elltel.net's Avatar
Member # 63366
Running a 9" w/ARB
Story is, new ring gear w/ARB. Used red locktite and the ring gear bolts eventually backed out. Local buddy had the same issue. Heat cycles must be causing this but to prevent this can one find pre-drilled safety wire bolts somewhere and or a bendable metal tab (All Seasons supposedly makes them?) that would lock two bolts together to keep the bolts from backing out?
thanks-yes, the threaded holes were properly cleaned, yes, the loctite was new, yes the bolts were torqued correctly... 3rd different ring gear with ARB that this has happened to btw myself and one buddy.
thanks
nvrstuk@elltel.net is offline   Reply With Quote Quick reply to this message
Old 08-17-2016, 11:52 PM   #2 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Check the race forum, this has been a common issue with high hp ultra trucks and 9".
Ive put literaly thousands of dd ring gears on with red lock tight and never had an issue.
Old 08-18-2016, 09:11 AM   #3 (permalink)
Member # 63366
Thanks for the tip. I searched for 1/2 hour "all" over Pirate but not that forum....
I used new bolts, new ring gear, cleaned the *&#%)&( off of both before install...more diff guys I've talked to the more I find out this is more common than anyone thought
Ever used "Izzy" locks?
Old 08-18-2016, 09:20 AM   #4 (permalink)
Member # 86797
Make sure your prep is good too. Bolt and hole both antiseptically clean and dry. Brake clean and compressed air.
Turn your bolts into wirable bolts....
https://www.google.com/search?q=safe...msg=NCSR&noj=1
1983 CJ-8 "Gossamer" FULLY POLISHED LS1, TH-400, Atlas 3.8:1 32 spline, 4" 0.375 wall driveshafts, Avalanche Titan axles, 2 1/2 ton third members, CTM axle shafts and Ujoints, ARB's, 15k Warn, Onboard welder and CO2, Halon and Coldfire extinguishers. CB, HF, PA, Sirens, Etc.
Threadkiller
thordehr is offline   Reply With Quote Quick reply to this message
Old 08-18-2016, 10:19 AM   #5 (permalink)
Member # 137726
Lockwire will keep a bolt from falling out of a hole, it won't keep it torqued. If all your bolts loosen up bad things will happen even if they're lockwired in place.
I'd try a high temp Loctite, maybe #272 (450F) or #2620 (Rated to 650F) vs normal Red Loctite #263 (360F)
Loctite Sourcebook, Page 140: https://www.ellsworth.com/globalasse...ebook-2015.pdf
MotoDave is offline   Reply With Quote Quick reply to this message
Old 08-18-2016, 10:38 AM   #6 (permalink)
Member # 228758
Why not throw a lockwasher on the bolts?
Sent from my 0PJA2 using Tapatalk
An xj that doesn't belong on pirate.
09 Chevy 1500 5.3 six speed.
Luke95 is offline   Reply With Quote Quick reply to this message
Old 08-18-2016, 11:34 AM   #7 (permalink)
CutterN55's Avatar
Member # 155394
True, it may not keep them torqued, but it will keep them tight when properly executed in the backwards "S" pattern. I work on heavy lift helicopters brother where major vibrations and stresses occur constantly. Safety wire or lockwire holds our rotor heads together just fine. you gotta do it right.
**SEMPER FI** '86 CJ7 258/Np435/D300/Waggy D44's
'02 F250 7.3L/ZF6/tuned/lifted/35's
CutterN55 is offline   Reply With Quote Quick reply to this message
Old 08-18-2016, 10:06 PM   #8 (permalink)
Member # 192237
blast em on there and tack weld them in place
edit: if it's an iron carrier, weld in whatever shit's at hand between bolts to tie them together
Old 08-19-2016, 12:40 AM   #9 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
Step up to grey Loctite?
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 08-19-2016, 08:25 AM   #10 (permalink)
69DieselLover's Avatar
Member # 210244
Are you sure you're using the correct Lok-Tite for your bolt size and are you using anaerobic primer? I find the primer makes a huge difference.
Humboldt Hillbilly
My Diesel Sport Trac Build
69DieselLover is offline   Reply With Quote Quick reply to this message
Old 08-19-2016, 02:33 PM   #11 (permalink)
Member # 10063
Originally Posted by [email protected] View Post
Running a 9" w/ARB
thanks
What are you torquing them to?
I ask because I know there are conflicting resources out there for torque specs on Ford axles.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
Old 08-19-2016, 02:41 PM   #12 (permalink)
Member # 162087
Primer/activator. Makes a huge difference.
Also may try the 290 (green)
jeepin4x4james is offline   Reply With Quote Quick reply to this message
Old 08-19-2016, 04:16 PM   #13 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Wayne israeleson (zukizzy) makes(made?) a solution for the ultra 4 cars. I am not sure if he still sells stuff. Pm mobil1syn or Wayne for help.
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 08-19-2016, 08:01 PM   #14 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
No good w ARB, unless he has newer ones:
https://www.pirate4x4.com/forum/axles...ear-bolts.html
Cool idea.
Old 08-21-2016, 08:53 AM   #15 (permalink)
Member # 63366
Thanks for the tips...I just got back from picking up my replacement ARB and they asked are you using red locktite and I said yes.... they looked like this was the first time it had ever happened.
I will check out the other types of locktite suggested above.
Bolts were new, cleaned, dried, used red locktite...75#'s torque. Read the post on the woes of the 9" posted above and I might be having the issue with the locktite setting up before fininshing the torque sequence.... I'll check this out further
Thanks for the help
Old 08-26-2016, 12:14 AM   #16 (permalink)
Member # 87452
Safety wire, tack or Nord Locks maybe...
'74 Bronco '01 Powerstroke Crew
BRC member
North Idaho Mud and Crawl Owner/Operator
"Wheel to wheel Rock Racing, open wheelin', free camping, North Idaho's best racing venue"
gearhead74 is offline   Reply With Quote Quick reply to this message
Old 08-26-2016, 04:14 PM   #17 (permalink)
Member # 156216
I lol'd
Buggies are boring. Jeeps are generic. Full size are more fun. Because size matters.
hasteranger is offline   Reply With Quote Quick reply to this message
Old 08-26-2016, 04:19 PM   #18 (permalink)
Member # 156216
Thanks for the help
My experience is that the shit that comes in the gel sticks takes longer to harden than the liquid in the toothpaste tube if you need more time.
Old 08-26-2016, 05:19 PM   #19 (permalink)
bobbywalter's Avatar
Member # 15473
Send a message via AIM to bobbywalter
with spools and mini spools i have noticed issues with big tires and 4x4 activity. open or ls and detroits seem trouble free by comparison.
on circle cars we weld key stock from bolt to bolt on trouble cars like already mentioned..
on the bronco i have wiped out 3 carriers....starting to hate them. so i am not sure if i should go with a regular locker or a rear 60.
if only
88 ranger ext cab p.o.s. hackjob powered by a 6.5 diesel clattering against a 4l80 thats punishing a f208 that is turning ford 60's rolling on 33-44 inch tires depending on the mission at hand
how ya like me now??
bobbywalter is offline   Reply With Quote Quick reply to this message
Old 08-26-2016, 07:00 PM   #20 (permalink)
Member # 192237
aren't they only like 3/8-24 or some shit?
Find a friend with a CNC that'll threadmill, hog them fuckers on out to 1/2-20
Old 08-27-2016, 02:54 AM   #21 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
Looks like you could chop Izzy's things in half, brace the stub against the carrier pocket, and they would work. As long as you put them against the correct shoulder...
Or there's these for Toyota (which also wouldn't fit ARB):
bolt retainer plate, ring gear [YSPBLT-032] - $2.73 : Locktup Fabrication, Hardcore Offroad Parts & Accessories
Fastener Data - Tab Washer - WASHERS - DIMENSIONS - Fastener Specifications
"Tab washer" is the term...
Old 08-27-2016, 05:22 AM   #22 (permalink)
Pavement Challenged
71PA_Highboy's Avatar
Member # 73465
I am not sure you cleaned enough... I have never seen a 'dust free' environment in the Yakima valley ...
The Nord locks are an interesting alternative.... I would really think those and the high temp locktite would make a great combination.
Did you use the primer with the red locktite?
Give my best to T .... I will call you soon.
Got Ford?
68 & 69 Bronco, 70 Mustang, 94 Ranger, 71 F250 4x4, 94 Lincoln Mark VIII, MEP-803A - BF NC
This country is trying to childproof the world when they should be worldproofing their children.
71PA_Highboy is offline   Reply With Quote Quick reply to this message
Old 10-07-2016, 06:53 AM   #23 (permalink)
Pavement Challenged
Member # 73465
What did you decide? Any feedback on you decisions?
Got Ford?
