V8 swap question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2016, 01:03 PM   #1 (permalink)
Pistolwhip0809's Avatar
Member # 715202
V8 swap question
I have a 2.8 currently wanting to know if I should go with a 5.0efi or a 302 and need to know what I should do to go along with the swap
Pistolwhip0809 is offline   Reply With Quote Quick reply to this message
Old 11-12-2016, 08:52 PM   #2 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Location: My little kingdom of awesome. Near Olympia, Thurston county, Wa
https://www.pirate4x4.com/forum/login...ac522d90e85edb
Tarped lawn art: 1985 BroncoII Eddie Bauer. V8/Automagic/Locked/MTRs.
I want everyone to have everything. I want gays to be able to fuck each other in the ass, in the middle of a field of weed while shooting pistols in the air like yosemite sam shouting that there is no god.
Totalled is offline   Reply With Quote Quick reply to this message
Old 11-12-2016, 09:26 PM   #3 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Someone who can do the swap for you.
Old 11-13-2016, 04:04 AM   #4 (permalink)
Member # 715202
Thanks I guess ranger rod but I can do this myself I was curious to see what other people may have done about the suspension since it will be carrying the heavier motor
Old 11-13-2016, 04:06 AM   #5 (permalink)
Member # 715202
I've done this so far myself
Old 11-13-2016, 08:16 AM   #6 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
If you want EFI, you'll need to swap in the fuel system from a later rig with EFI since the 2.8 is carb'd, and doesn't have a return line or high pressure supply line.
Carb'd 302 is easy, and I did that first. Now I'm going 5.0 EFI.
My ride height went up 1/4" when I went from 2.8 to 302. I was using explorer front coils though. A 302 isn't much heavier than a 2.8, and is real close to a 4.0.
Go research on therangerstation.com
Old 11-13-2016, 10:11 AM   #7 (permalink)
Member # 715202
Ok that's more what I was looking for because I've found a 1994 f150 auto 4x4 for 500 so I would have most of what I need for the swap. I have a picture of my "creation" on therangerstation.com if you'd like to take a look at it my profile is has the same name but if you have any ideas on what I should do I'm all ears or eyes....whatever you know what I mean
Old 11-13-2016, 11:42 AM   #8 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
EFI rocks but changing over has a lot of little expenses involved. If you like simplicity and don't really need a lot of extra power, a Motorcraft 2150 is a solid carburetor for offroading.
I would have likely stayed with a carb on my truck if they made something that could feed 473 cubic inches and not flood every time you tried to climb a hill or go off camber. 5.0s make it pretty easy though, so there's not much of a reason to not use the stuff from that F-150. Part the rest out and you can probably pay for the whole thing.
-Dave
By the way, Irregardless does pass spell check and it is a word. The meaning is exactly the same, you just want to play games
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 11-13-2016, 09:52 PM   #9 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
He'll have to swap to a car EFI intake unless he wants to run no hood.
Old 11-14-2016, 09:25 AM   #10 (permalink)
Member # 715202
With my setup now it basically all ready has a body lift
Old 11-14-2016, 05:38 PM   #11 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Won't be enough to clear the truck intake.
