#176 (permalink) | ||
Member # 141697
even after the box broke he was able to still steer if went full lock as would make the ram move. said he drove it off the course and onto the trailer
we talked last night night and will probably just get another used box and put the spare knuckle on for now. i took a look last night and the knuckle is broken at the stock steering mount and just the weld on the back side of the artec kit is whats holding it all together right now. what he wants to do is send the spare knuckles out and get TMR arms and machined to fit them then go full hydro. just not in the budget right now as has some other parts to fix as well to get it back on the trail
PLAN-B F250 on 44s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by snowracer; 01-16-2019 at 09:57 AM. |
#177 (permalink) |
finally fuckin in
Member # 232666
That's what racin does, cost money. It's fuckin fun though. Glad he did as well as he did, and glad nothing major is destroyed.
Originally Posted by 03f350 ... Well first off FUCK JEEPS.. |
Sponsored Links |
#181 (permalink) |
Member # 141697
small update as truck is kinda back together
after the race and seeing what the truck needed to be back on the trail it sat for a bit while he collected parts. sent his spare knuckles to TMR to get hi steer arms, sent the one tire out for repair, ordered 4340 inner shafts. tossed a new steering box in but did not drill it for the assist, plan now is to go full hydro. to get by till his knuckles get back (been at tmr for almost 3 months now) he found a used knuckle and cut the steering arm off the broken one and welded it up. so plans for next little bit it so get the new knuckles on and full hydro and just do more cage work that we did not have time to do. pics the broken knuckle getting a new steering box the night before we planned on going wheeling fresh sheet metal to beat up he took it across the scales and the fat bitch weighed in just under 7500 pounds
PLAN-B F250 on 44s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by snowracer; 03-28-2019 at 09:53 AM. |
#183 (permalink) |
E-Locker or Bust!
Member # 163019
Me too, I'd have guessed damn near 6000lbs.
2001 Z71 Silverado, Ext. Cab, 5.3L V8 -
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Shortened 17" w/Bed, AAM 14B FF / Grizzly, Dana 60 HP / Chromos, Anti-Wrap Bar 4L80e, EcoBox/205 Doubler, 40" Mickey's, Rock Sliders, Hidden Winch, Hydro Assist Last edited by DMANbluesfreak; 03-28-2019 at 10:30 AM. |
#184 (permalink) |
Member # 141697
everything about the superduty trucks is just bigger and heavier. just his doors are almost double that of my old obs doors, there is a big ass crash bar in the middle of them. frame is bigger and thicker, and i way overkilled that flat deck when i built it. i took my rig across the scales the same day but did it on the trailer as knew the weigh of truck/trailer. not quite as accurate but planb came in at 6000, was really hoping to be closer to 5500 but oh well
PLAN-B F250 on 44s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by snowracer; 03-28-2019 at 11:51 AM. |
#185 (permalink) | |
Safety third!
Member # 168243
My 1983 F-250 is I think around 6500. Maybe a bit more now with the 203/205. It was 5500 as a 2wd with a 460 and C6.
The CCLB 2018 Powerstroke I rented the other day was 7700. ![]() ![]() On the other end of the spectrum, my long bed 1967 F-100 was a whopping 3900 lbs. 240 inline 6, C6 transmission, 9" rear. Trucks got fat. The brakes should tell you everything.
-Dave Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. For the best deal on 8 lug disc brakes click here--> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Dr.Danger; 03-28-2019 at 02:05 PM. |
#186 (permalink) | |
Member # 25632
#187 (permalink) |
Member # 177092
Damn, 7,500Lbs.
![]() ![]() My 2000 7.3L 6 speed 4x4 ECSB F250 "only" weighs 6,680Lbs according to the local scrapyard. I can't believe you added that much weight to a regular cab 5.4L. Just to add to the new trucks are fat discussion, my '84 6.9L 4 speed 4x4 RCLB F250 weighs 5,500-5,600 at the same scrap yard. Last edited by '84 Bronco II; 03-28-2019 at 08:26 PM. |
#188 (permalink) | |
Safety third!
Member # 168243
We didn't get a before weight but after was 10,100. Scale isn't super accurate since it also weighs train cars, but I figured since Ford literature has that truck at 7700, I was carrying 2400-2500 lbs of cement. Take it up with them or your local scale owner. 200 lbs less doesn't make them any less massive compared to the older trucks.
-Dave Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. For the best deal on 8 lug disc brakes click here--> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#190 (permalink) |
Member # 141697
a bunch of guys he works with went out on their sxs for a sunday cruise so he tagged along and managed to flop the truck again
![]() was side hilling and found a soft spot and dug in front fender is nicely formed around the front tube work now
PLAN-B F250 on 44s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#191 (permalink) | |
Member # 25632
I guess I heard him wrong or something, he said it was 8200 ![]() |
#192 (permalink) | ||
Safety third!
Member # 168243
![]() That's a big bitch.
-Dave Quote:
#194 (permalink) |
Member # 141697
hes been back working on the truck again
its getting all new doors and front fenders so should be nice and straight for the first wheeling trip ![]() new rear bump stops, limiting strap and changed the rear springs out for a set that is a little more firm. the set he had where too soft and sat low in the ass and shackle angle was crap still flexes up pretty good with the stiffer rear springs
#197 (permalink) |
Member # 141697
the new doors will be getting some decals pretty soon as he picked up some sponsors for racing this year
#198 (permalink) |
Member # 141697
he picked up some new seats and added some tube work so now they are mounted to the sliders/cage
#199 (permalink) |
Member # 141697
update time
he platted in the lower section of the double b pillar moved his shifter closer so can reach all gears when have the 5 points on used the sissy bar out of my old truggy, the superduty has a nice big crash bar behind the dash to weld it to new body panels and coat of black paint and sponsor decals then we hit up the Fathers day show and shine
PLAN-B F250 on 44s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by snowracer; 07-04-2019 at 12:51 PM. |
#200 (permalink) |
Member # 141697
headed out to Houston BC to run the obstacle course
Welfare is the unofficial recovery rig he was laying it down with solid runs all weekend till his last one when rear brake hoses blew out and he had to call it quits on last run
PLAN-B F250 on 44s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by snowracer; 07-04-2019 at 01:56 PM. |
Thread Tools | |
Display Modes | |
