The Welfare Duty - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-29-2016, 03:59 PM   #1 (permalink)
snowracer's Avatar
Member # 141697
The Welfare Duty
figured id do a build for buddys rig as know he wont and have had a few people ask about it.
it all started when he was looking for a rig to build as was thinking of doing a first gen explorer on tons but needed diffs so started looking for some 1tons and found this truck for parts as was in an accident. but after thinking about it just make more sense to fix it and build it as already had some parts for a SD laying around. like said truck was in an accident and driver side front end was pushed over and driver side rear of the box was messed up too. he picked up the truck for $800 and brought it home and started the build with budget and simplicity the main goals. he had about month and half to get it built and out of my shop while i recovered from surgery.
the name Welfare Duty came from a friend as truck is a no dollar budget build with used or donated parts and we figure its made up of 7 trucks buy now.
specs
2000 F250 with a 5.4 that had a tune up before and accident, sct tuner and a purple horny glass pack with a turn down
shortened frame
dana 50 front and 10.50 rear with 4.10s and welded
used 6inch deaver springs but with pulled springs so about 4inchs of lift
dirt logic shocks that cost more then the truck
military XML tires on stock rims
dont have a pic before going in the shop but was just another white work truck
box gone and the frame cut
deaver springs in and donated flat deck
military tires
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 04:02 PM   #2 (permalink)
snowracer's Avatar
Member # 141697
getting the frame closer to stock as was pretty bad after the accident
can see the S in the rad, was still holding and he got almost a year out of it
front dirt logic shocks in and ubolt flip
on the back the shocks attach to the deck and deck is welded to the frame
used the stock fuel tank on the deck but had to modify the fuel lines on the sender to work
PLAN-B F250 on 44s
Old 12-29-2016, 04:05 PM   #3 (permalink)
snowracer's Avatar
Member # 141697
a friend gave him a old forestry bumper that got cut up and winch added
took it out and wheeled it and on the 3rd trip the Dana 50 struck and busted an inner axle shaft
figured that the shaft broke when the tire hit the leaf springs so had a friend build some 3/4 wheel spacers to fix that issue
PLAN-B F250 on 44s
Old 12-29-2016, 04:08 PM   #4 (permalink)
snowracer's Avatar
Member # 141697
with the 50 back together and truck working well got it ready for our week long trip down to the states
first stop was Moses lake to play in the dunes
then the Dana 50 struck again but this time blew one outer and the other side inner, so towed it back to camp and got to do a front end rebuild in the dunes
carrier was damaged so had some issues getting it out
once back together we moved on to Elbe and truck worked well other then some steering issues and lots of body damage
PLAN-B F250 on 44s
Old 12-29-2016, 04:11 PM   #5 (permalink)
snowracer's Avatar
Member # 141697
once back home and a once over and a new door the welfare was ready for another beat down, this time at a friends mud bogs and obstacle course
nice part of being a white work truck is body parts are easy to get even if you have to rock some company logos
truck worked and placed 3rd in the bogs and 2nd in obstacle course
after all the dana 50 issues that we had been having we brought an extra diff with us just incase but it held up
PLAN-B F250 on 44s
Old 12-29-2016, 04:13 PM   #6 (permalink)
snowracer's Avatar
Member # 141697
after the mud bogs the Welfare got some steering upgrades with a new bigger pump, cooler and resi and made a world of differance
headed to another close to home town for the mud bogs and Hill and hole. truck did well but did not place this time and messed up the rad support, rad and trans cooler when nose dived in the hill and hole
with a newish rad and cooler truck was ready for another beat down this time up Baldy. And the 50 struck again, this time with a blown hub then later in the day a ujoint and inner shaft
around this time we stared running low on spare 50 parts but slapped the diff back together and headed back to Houston to do some early snow wheeling. truck did well and 50 lived but the XMLs just suck in the snow
PLAN-B F250 on 44s
Old 12-29-2016, 04:15 PM   #7 (permalink)
snowracer's Avatar
Member # 141697
that gets us up to date for wheeling but he has been working on it and getting ready for the some upgrades.
first up is to finally swap to a 60, picked this one up this summer for him for $100 and came with an extra set of shaft too. will run it stock and see how the the outers hold and upgrade once run out of stock ones
after running the XMLs for a year in everything from mud to sand to snow they have done an ok job but not great plus being so heavy has not helped with the axle braekage issues so time for some new boots. 40x16x16 LTBs and he picked up some used 16x10 aluminum rims as well for them
also has the parts laying around to do onboard air with a large tank, heim joints to upgrade the steering to dom links as have bent the crap out of the stock ones.
future plans are hydo assist steering and add some tube work to the deck that would tie into a cage of some kind as well. some sliders and possibly small boat sides when doing the sliders
PLAN-B F250 on 44s
Old 12-29-2016, 08:10 PM   #8 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Location: My little kingdom of awesome. Near Olympia, Thurston county, Wa
1rst, you guys took fullsize rigs through Elbe?!?
Second, fuck yeah.
Tarped lawn art: 1985 BroncoII Eddie Bauer. V8/Automagic/Locked/MTRs.
I want everyone to have everything. I want gays to be able to fuck each other in the ass, in the middle of a field of weed while shooting pistols in the air like yosemite sam shouting that there is no god.
Totalled is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 10:01 PM   #9 (permalink)
CLF
Member # 186919
Subscribed! Good simple fun!
CLF is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 10:52 PM   #10 (permalink)
Member # 213911
I was hoping there would be a thread on this.
ironfist is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 11:14 PM   #11 (permalink)
snowracer's Avatar
Member # 141697
Second, fuck yeah.
hells ya but we got shit kicked buy elbe so have to go back in 2017 and try again
figured it was time as truck flat out works and always takes a beating, plus should really be some fun after the planned up grades
PLAN-B F250 on 44s
Old 12-30-2016, 10:22 AM   #12 (permalink)
snowracer's Avatar
Member # 141697
few vids
https://youtu.be/pYJZr7VJero
https://youtu.be/b2cMnL340hU
https://youtu.be/rOg_R5NuYbA
PLAN-B F250 on 44s
Old 12-30-2016, 11:28 AM   #13 (permalink)
Member # 84361
Originally Posted by snowracer View Post
You need to come run elbe in january.
Toy, 4.3, 4l60, d300, tons, 38's, Trail Slut
JHF GB Chassis in progress.
crazybluerider is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 11:30 AM   #14 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
Sweet truck, but you need some sliders.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
FordFascist is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 02:16 PM   #15 (permalink)
Idaho4x4Bronco's Avatar
Member # 139619
Let's see it on the LTBs.
Roof height on the LTBs would be nice to know, wink wink
Fuck It Sums It Up
Idaho4x4Bronco is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 03:16 PM   #16 (permalink)
snowracer's Avatar
Member # 141697
our group has been talking and we are thinking end of summer to head back down across the boarder and try Elbe again
he has the steel to do it and after the tires and 60 swap thats the next thing to happen
he plans on having 1 mounted up this weekend and see how much more fender he has to trim. ill make him measure once all 4 are on
PLAN-B F250 on 44s
Old 12-30-2016, 03:45 PM   #17 (permalink)
Member # 612066
Thanks for posting bud
[QUOTE=rockbuggy84;38753298]You gonna fuck this thread up too?[/QUOTE]
DUMMAGE RAPES 2017
JimLahey is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 07:14 PM   #18 (permalink)
Member # 84361
Wait until the wet season gets rolling, that trail is a whole different experience when it gets slick. Give me a heads up when you're coming our 4wd club would be glad to show you the good stuff there.
Old 12-30-2016, 07:36 PM   #19 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Elbe does that to EVERYONE.
November.
Negatory... That's the easiest time of year.
This.
Old 12-30-2016, 11:39 PM   #20 (permalink)
Member # 67823
Love me some foolsize ferd. Subscribbled.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is offline   Reply With Quote Quick reply to this message
Old 12-31-2016, 06:47 PM   #21 (permalink)
hi-steer ninja
FORDTECHGURU's Avatar
Member # 104639
Hell ya'
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 12-31-2016, 09:18 PM   #22 (permalink)
Member # 156216
Awesome.
Buggies are boring. Jeeps are generic. Full size are more fun. Because size matters.
hasteranger is offline   Reply With Quote Quick reply to this message
Old 01-01-2017, 12:56 PM   #23 (permalink)
snowracer's Avatar
Member # 141697
buddy got one LTB mounted up
PLAN-B F250 on 44s
Old 01-02-2017, 05:05 PM   #24 (permalink)
Member # 156216
Maybe I missed it. What's wheelbase on that thing?
Old 01-02-2017, 05:37 PM   #25 (permalink)
oneofakind97's Avatar
Member # 127719
Elbe hills is one of my dream wheeling trips. Awesome to see a full size smashing through those trails
85 F250 on locked tons and 44's. Teetering on BGTL territory
Tow Pig: 86 F350 Turbo 6.9/ZF5 4x4 converted dually
old Chevy vs new Chevy ? nobody gives a fuck
please kick yourself in the cunt,
oneofakind97 is offline   Reply With Quote Quick reply to this message
