Ford 460 Rebuild/Rebuilt/Crate? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2018, 09:14 AM   #1 (permalink)
Member # 788153
So pretty sure within the next year I will be replacing the engine on my 1987 Econoline 350.
I would like the switch to be as quick as possible.
I know if I rebuild it it's going to be the slowest way of going about it.
So should I get a crate engine, have a shop rebuild it or just but a rebuilt one?
Any recommendations on who to get it from?
Needs to be CA smog legal too.
Thanks in advance.
tote is offline   Reply With Quote Quick reply to this message
Old 02-10-2018, 09:58 AM   #2 (permalink)
Storing Junk
Lincolnman's Avatar
Member # 257906
Pay a shop to build one for you if you are in any way unsure.
Personally, I usually buy a spare motor and rebuild that.
Crate engines have Lord only knows what parts and work in them.
Electronics work on magic smoke, don't let it out.
Lincolnman is offline   Reply With Quote Quick reply to this message
Old 02-10-2018, 12:46 PM   #3 (permalink)
Member # 52361
If you need a fast turn around, avoid a pull/rebuild/reinstall, too many opportunities for things to go to shit
I'd go crate motor from reputable company, or buy a spare, you could buy a core and do a full rebuild, or buy a good runner, or even a whole truck, you should be able to buy a grandpa f250 with 100k for 1200 if you look around enough
More details on the 30yr old van you're dumping time and $into?
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 02-10-2018, 04:33 PM   #4 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
What's your budget?
Scott Johnston in Tacoma has some pretty nice EFI packages available that will blow the stock one out of the water. He's not cheap, but he delivers a good product and knows what he's doing.
-Dave
By the way, Irregardless does pass spell check and it is a word. The meaning is exactly the same, you just want to play games
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 02-10-2018, 10:18 PM   #5 (permalink)
Storing Junk
Lincolnman's Avatar
Member # 257906
Originally Posted by Dr.Danger View Post
What's your budget?
+1 for Scott. He really knows how to make a motor do what it ought to.
Old 02-10-2018, 10:52 PM   #6 (permalink)
Member # 788153
Looking to keep it under $2500.
It's running great right now, just planning ahead.
I cracked the bell housing so pulled the tranny and had the guts put into a new (to me) bell housing. Put in a new driveline, yokes, U-joints, starter, dist, plugs, wires, fuel pressure regulator, etc.
here's a couple of pics of the rig in question.
https://i.imgur.com/FREpxWE.jpg
https://i.imgur.com/lrxol0P.jpg
Old 02-11-2018, 04:36 PM   #7 (permalink)
Member # 120478
Now this makes more sense. I was envisioning a beat up 87 panel van. Digging the 4x4 class C motorhome!
Wheeler ->
90 Bronco with stuff
Dan90FSB is offline   Reply With Quote Quick reply to this message
Old 02-12-2018, 08:53 PM   #8 (permalink)
Member # 52361
I was hoping it was something worthwhile
I wouldn't freshen it up just to do it, I'd build a better engine, or pull it and reseal it and slam in cam and headers, etc, but I wouldn't let an average "mechanic" into a good running factory engine.
Some efi and bolt ons would be nice
Old 02-13-2018, 08:50 AM   #9 (permalink)
welndmn's Avatar
Member # 398
Ha! Same thing I was thinking, who puts another motor in a Van...
But now I see.
I am a huge Ford fan, but I don't like the 460, I've own stock and built ones and they never made the power they should.
If you're held onto the 460 idea, I'd at least get 1996 460 from a junk that is EFI and mass air. It's a smog legal swap.
Mark
Old 02-13-2018, 12:58 PM   #10 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
I don't even see how that's possible. 1 hp per cubic inch is like the baseline for performance on these things with the right compression, cam, and barely any port work.
It's like a 302, but bigger, stronger and better....
-Dave
Old 02-13-2018, 01:59 PM   #11 (permalink)
welndmn's Avatar
Member # 398
Stock they were 200-220 HP, emissions are a killer.
Mark
Old 02-13-2018, 04:41 PM   #12 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
What I was referring to, is that he also said "built" ones. If he wasn't impressed with it, I wouldn't call it built. I'd call it stock compression with an RV cam. While not much better than stock, is also a hell of a lot more grunt than any small block.
I invite him to read a little more about what people are doing with these engines nowadays. Even without fancy aluminum heads and stroker cranks. It's not 1983 anymore, there's over 30 different aftermarket heads for them and years of proven builds that are actually relatively affordable compared to the competition, if not cheaper in many cases.
-Dave
Old 02-14-2018, 05:48 PM   #13 (permalink)
Member # 788153
Thanks everyone.
I will definitely be doing my homework.
Who knows, I might be able to wait a couple of years or so........maybe by then I'll be ready to look into diesel.
Old 02-19-2018, 06:57 PM   #14 (permalink)
Member # 52361
Since you mentioned it, I'm not a gas v8 hater, but if you compare the expense of building a gas engine "right" compared to pulling a solid 200k mile cummins from a rusty farm truck, the diesel makes sense imo. My old boss put one in his ford class c, and a 4wd conversion at the same time, he's pretty happy with his, emivil put one in his class c, it fits.
I've built some cummins ford trucks, and will be building a e350 at some point.
I strongly suggest buying the correct parts truck and utilizing the engine/trans/tcase, sell leftovers, makes for the best and cheapest build IMO.
If you go that direction, make a thread, maybe I can get some pics of his x member and stuff
Old 02-19-2018, 08:24 PM   #15 (permalink)
Member # 156511
These 460ís were dogs from the factory. Ford put a timing chain set on that kills performance and the pistons donít come near the top of the cylinders. Just putting a new timing chain on is a big improvement.
Plan on most of the exhaust manifold bolts breaking when you try to remove them. I have done a few repair jobs on 80ís ford motor homes.
mavereq is offline   Reply With Quote Quick reply to this message
Old 02-20-2018, 02:14 AM   #16 (permalink)
Member # 788153
Replaced one exhaust manifold already and was lucky that no bolts broke.
Had 3 break on the water pump...that was fun.
New timing gear and chain did make a big difference.
Compression check today yielded between 110 the lowest and 120 the highest.
I was happy with that.
Used some MMO to quiet down one lifter. So far so good.
One rattling noise I think I found today, believe it or not, was the top half of the transmission dipstick rattling. Wondering if putting some sort of dampener where it bolts to the engine will fix that?
The fuel pressure regulator made a world of difference.
I'm happy with how it's running right now, but realistically it's a 31 year old engine moving a lot of weight. It's only a matter of time.
The biggest PITA is it will have to be CA smog legal. Will definitely do my research on diesel before I take the plunge.
For now I'll just dump gas into it and have fun.
But better to be prepared than to be totally caught off guard.
Old 02-20-2018, 04:39 PM   #17 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
87 and up have the straight up timing chain. Most factory engines from any make are somewhat in the hole but there are piston differences from early 80s, to late 80s, to post 1993. Ultimately, new pistons, some RPM rods (can be cheaper than resizing) and a cylinder hone or overbore should be done on a rebuild. If money allows, a zero deck is rarely a ton more money than a simple square up like most machine shops perform. Just depends on the block.
The 87 EFI heads are not as good as the 1993 heads. It really, really depends on how much power you think you need, but with the right cam an EFI build can put out good torque and a solid 350 hp. Stock fuel system runs out as you approach 400.
-Dave
Old 02-25-2018, 10:21 PM   #18 (permalink)
Member # 113567
I love the 460 in my Bronco. I've driven them with a 302, 351, 357, and a 408 stroker. Hands down I would choose a 460 again. Forget HP....its useless in these pigs.
1996 Bronco Sport EFI 466 MAF/OBD-II,D60/D70-2u,38s
1976 Bronco EFI 351,C4,Twin'd 20,5.5",37s
Bronco Logic is offline   Reply With Quote Quick reply to this message
Old 02-26-2018, 08:28 AM   #19 (permalink)
Member # 213911
I agree. Even stock the efi 460 does 400 ft.lb torque @ 2100 rpm (or thereabouts).
ironfist is offline   Reply With Quote Quick reply to this message
