Coil over spring rates for a ranger or explorer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-09-2018, 09:02 PM   #1 (permalink)
Member # 43820
Looking at picking up a set of coil overs for my 92 explorer 4.0, not that the axles matter much, but it's on tons and 40s. Looking for a good place to start, on spring rates. Probably 14 inch 2.0 I'm super uneducated about all this shit but FOA I can get a complete set up for about 800 bones.
Sent from my SM-G955U using Tapatalk
99 ford ranger 4.0 4x4 with some 33s workin on the SAS swap.
ben10 is offline   Reply With Quote Quick reply to this message
Old 06-09-2018, 09:04 PM   #2 (permalink)
Member # 43820
Oh and it's for the rocks, just driving to and from the trails. And the back will stay leaf srung.
Old 06-09-2018, 09:30 PM   #3 (permalink)
BDK
BDK's Avatar
Member # 295498
I have a set of Radflo 14" 2.0's on my Explorer. I have 300/250 springs, which are a little stiff, so I added a triple rate spring. I like the ride with the stiffer springs as it helps with body roll on the highway.
Don't waste your money on those POS FOA's, they suck. I had them, got fed up with rebuilding them every six months.
There are a bunch of coil over'd Explorers and Rangers on the explorer forum.
In politics, stupidity is not a handicap.-- Napoleon Bonaparte
BDK is offline   Reply With Quote Quick reply to this message
Old 06-09-2018, 10:02 PM   #4 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
@Josh40601
Old 06-09-2018, 10:25 PM   #5 (permalink)
Member # 43820
I have heard mixed reviews on them. I dont get to wheel too much so hopefully they will last a few years between rebuilds. The next step up from FOA is several hundred dollars more from what I have found. I am in the middle of buying a house so I have to keep my expenses down.
Old 06-09-2018, 10:52 PM   #6 (permalink)
BDK
BDK's Avatar
Member # 295498
Look through here for ideas
Solid Axle Swap Registry | Ford Explorer and Ford Ranger Forums - Serious Explorations
Old 06-10-2018, 06:03 AM   #7 (permalink)
jimbo74's Avatar
Member # 53319
Check out Rick's Pumpkin
84 22R 4x4 X-Cab G52 4.10s SR5
jimbo74 is offline   Reply With Quote Quick reply to this message
Old 06-10-2018, 04:28 PM   #8 (permalink)
BDK
BDK's Avatar
Member # 295498
I have known Rick for over 20 years, his Explorer is awesome, but won't help you with spring rates. His coil overs are set back on the lower arms and his spring rates are very high (5-600 if I remember right). What would help you the best are TurboExplorer http://www.explorerforum.com/forums/...thread.348656/ , who has a full-width 4 link on 14" coil overs or mine Bkennedy's SAS and Rebuild Thread | Ford Explorer and Ford Ranger Forums - Serious Explorations, which is a Duff radius arm narrowed 76 F-150 D44 on 14" coil overs. My thread also has the FOA saga and my issues with them over the short time I had them. They are both long reads.
Old 06-10-2018, 04:33 PM   #9 (permalink)
BDK
BDK's Avatar
Member # 295498
Email [email protected] for shock prices, or any other stuff you need for your build. His customer service and prices are unmatched. I felt the same way you did about the FOA's and learned the hard way. You would be better off purchasing a used set of good shocks off pirate than a new set of FOA's.
Old 06-10-2018, 10:13 PM   #10 (permalink)
dieselboy740's Avatar
Member # 168108
Id run profenders before foa. Also I think on a 14 shock a 200x14 upper and a 250x16 lower would be a decent guess.
'97 f-250 7.3, project, 3 link front, 4 link rear, back halved, fox co/bypasses/bumps, etc....
'08 f350 cclb 4x v10
'93 Volvo 940 fake rally car #trophyvo
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 06-11-2018, 08:53 AM   #11 (permalink)
The Brawler's Avatar
Member # 329665
Wouldn't run FOA's. ([email protected] On Arrival)
As far as rates and lenghts. I have a fullsoze Bronco on tons and I went with 14" 250lbs over 16" 350 lbs for lengths and rates on FOX 14" 2.5's. It is offroad only and flexes great.
The Brawler is offline   Reply With Quote Quick reply to this message
Old 06-12-2018, 06:23 PM   #12 (permalink)
grunizzle's Avatar
Member # 167342
I run 200/200 on the front of my ranger
grunizzle is offline   Reply With Quote Quick reply to this message
Old 06-12-2018, 07:04 PM   #13 (permalink)
BDK
BDK's Avatar
Member # 295498
I think you would be happy with 14" 200 over 16" 250. Also depends on how much weight you have on the front, plate bumper, winch, etc..
Old 06-13-2018, 04:29 AM   #14 (permalink)
jimbo74's Avatar
Member # 53319
Ha, BDK, I know you too
