Flipping a Ford t-case - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-17-2018, 12:39 PM   #1 (permalink)
snowracer's Avatar
Member # 141697
ok i know its not Tuesday and this is a very Tuesday question
the 6 bolt round on the ford tcases, am i able to flip a tcase and bolt it up or is the pattern different and wont line up? what im wanting to do is run my 203 doubler range box upside down. how my link/trans crossmember is set up i can not fit the 203 range box in the truck like normal. so can i just flip it over and cut a hole in the cab floor and call it a day?
and yes ive looked and seen people running the 203 upside down just fine, im just not sure it it will bolt up to the stock holes or do i need to redrill the trans flange ect
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 12-17-2018, 02:56 PM   #2 (permalink)
Member # 38200
The pattern isn't symmetric. You're going to have to adjust some holes.
This is looking forward at the trans adapter.
The dimensions are from an adapter I measured on a CMM. I'd guess angle nominals are 59.2 and 64.
Quick & Dirty is offline   Reply With Quote Quick reply to this message
Old 12-17-2018, 03:48 PM   #3 (permalink)
snowracer's Avatar
Member # 141697
thanks man that kinda what i figured
i did grab a pair of trans to tcase gaskets and matched them up and flipped one over and could see that all but one match up, real accurate over here so wonder if i can just oval the one hole in the back of the trans and be fine or better off re-drilling the trans then use my clocking ring to get the range box upright
PLAN-B F250 on 44s
Old 12-17-2018, 05:16 PM   #4 (permalink)
El Conquistador
Valley Rock's Avatar
Member # 208306
NWF makes an adapter plate to run the Ford or GM 203 in 4 different positions, including upside down .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 12-17-2018, 05:24 PM   #5 (permalink)
snowracer's Avatar
Member # 141697
all i see is the clocking rings and i already have one from them, but dont think it will let me run the case upside down
PLAN-B F250 on 44s
Old 12-17-2018, 06:17 PM   #6 (permalink)
El Conquistador
Member # 208306
From their website:
Old 12-17-2018, 10:23 PM   #7 (permalink)
1975f100's Avatar
Member # 716946
Where did you find the gaskets ? Ive been half assed looking for one so I can clearance the zf. No luck at lordco or Napa
1975f100 is offline   Reply With Quote Quick reply to this message
Old 12-17-2018, 11:18 PM   #8 (permalink)
snowracer's Avatar
Member # 141697
From their website:
was that listed under the doubler kits? as didnt see that when looking at the clocking rings. wheni got home tonight i pulled the tail housing adapter off my parts c6 and put it on the 203 range box. if i flip the tail housing 180 degrees only the 3 of the bolt holes line up. the other 3 are off by half or more of the bolt hole. so might just be able to pull the tail housing off my trans in the truck and weld up those holes and redrill them and be ok
edit: found what you showed on the web site and its with their doubler kit, emailed them this morning about it and he said my best bet is redrilling
Originally Posted by 1975f100 View Post
Where did you find the gaskets ? I’ve been half assed looking for one so I can clearance the zf. No luck at lordco or Napa
im in parts at Ford dealership and we stock them. if needed let me know i can grab you a part number
PLAN-B F250 on 44s
Old 12-18-2018, 09:33 AM   #9 (permalink)
1975f100's Avatar
Member # 716946
That would be great. The dealership here wont bother looking for anything without a part number
Old 12-18-2018, 09:45 AM   #10 (permalink)
snowracer's Avatar
Member # 141697
#E7TZ-7086-A
PLAN-B F250 on 44s
Old 12-19-2018, 09:00 PM   #11 (permalink)
1975f100's Avatar
Member # 716946
#E7TZ-7086-A
Thanks. Ill give them a call in the am
