MY '99 RANGER BUILD - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2019, 03:29 PM   #51 (permalink)
Gozuki's Avatar
Member # 3088
Originally Posted by 6gun View Post
Second question, I've been looking at/thinking of using 1" .313 wall DOM or 1" solid aluminum and tap it to fit the 3/4" heims. Would this be sufficient?
With 1" material the wall thickness will be an 1/8" with stress risers from the threading. I would not use the solid Al.
Most 9 ' s are capable of firing 380 and if push really came to shove, you can fire .357 and 38 special through one.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 09-05-2019, 07:49 PM   #52 (permalink)
6gun's Avatar
Member # 95448
Now that someone else says it, it makes sense. After my 8 day road trip to Colorado I have a laundry list of stuff and the track bar has slid way down the list.
'99 Ford Ranger 4.0/5R55E/BW1356E/5.13 gears/'06 D60 F/99 Sterling R/ 39X12.50 Kanati
6gun is offline   Reply With Quote Quick reply to this message
Old 09-11-2019, 11:07 AM   #53 (permalink)
Gozuki's Avatar
Member # 3088
The Duff spring mounts were an amazing time saver. They will be welded in since I have no bolt holes anyway (Torsion bar front previously) but they were almost perfect spacing for the SD axle. Another 1/2"-3/4" and they would have been dead on. As it is I have a tiny bit of spring lean but I'm not worried about it.
At the top, are the tops leaned out or in? And did you get the buckets as part of a kit, or by themselves?
Old 09-12-2019, 04:37 AM   #54 (permalink)
6gun's Avatar
Member # 95448
Springs lean in by about 1"at the top. Buckets are available by themselves and come with upper retainers so no need to order another set like I did!
Similar Threads
Project Build ups: dog walker Toyota - Land Cruiser 87 02-14-2017 06:09 AM
1991 Ford Ranger build broncoformudv Mud 15 12-18-2016 03:30 AM
Just Differentials 99 Land Cruiser UZJ100 Build Thread justdifferentials Toyota - Land Cruiser 10 12-28-2014 12:28 PM
Low and Slow ranger build (project Stubble) icalbert101 Ford 29 08-22-2013 07:40 PM
