F250 on 40s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2019, 07:55 AM   #1 (permalink)
Member # 847209
F250 on 40s
I have a 2015 f250 6.7L with a pro comp 6 inch lift on 40 inch tires. Anyone have good solid advice on how to beef up the front end?
Sent from my SM-N910P using Tapatalk
ckkphoto is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:17 AM   #2 (permalink)
snowracer's Avatar
Member # 141697
what do you mean by "beef" as to some guys Toy diffs are beef and others think AT4000s are beef
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:23 AM   #3 (permalink)
Member # 847209
I should have been more specific. I have a Dana 60 diff. By front end i was referring to steering components. Sway bar, pittman arm, idler arm. I have broken all of that. I have also replaced inner and outer tie rods. Granted that is because I wheel a 7500 pond vehicle. That alone doesn't mean someone out ther has not addressed this well.
Old 05-17-2019, 08:27 AM   #4 (permalink)
Member # 66173
You can't expect the stock steering box and linkage to deal with 40's on their own. Put in hydro assist.
2000 XJ
jonzer12 is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:28 AM   #5 (permalink)
Member # 847209
Brand?
Old 05-17-2019, 08:35 AM   #6 (permalink)
Member # 95025
F-250 with a Dana 60?
Have you confirmed this?
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:36 AM   #7 (permalink)
Member # 95025
Absolutely agree.
That's what I did with my '99 F-350.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 08:37 AM   #8 (permalink)
Member # 847209
Yep. Dana 60 35 spline. Truetrack differential. 4.88 gearing
Old 05-17-2019, 08:42 AM   #9 (permalink)
Member # 95025
Factory installed/OEM?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 08:43 AM   #10 (permalink)
Member # 95025
Brand?
I put an AGR Steering kit in mine.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 08:44 AM   #11 (permalink)
Member # 847209
Factory dana 60. Aftermarket gearing and diff.
Old 05-17-2019, 08:45 AM   #12 (permalink)
Member # 847209
Thanks. Will look into it.
Old 05-17-2019, 08:49 AM   #13 (permalink)
Member # 143737
05+ are all D60, no D50 bullshit
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 08:50 AM   #14 (permalink)
Member # 95025
Wow; that's the first I've heard of a an F-250 with a factory Dana 60.
And your's is not even a dually, correct?
My '99 F-350 PS had a Dana 50.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 08:52 AM   #15 (permalink)
Member # 95025
Awesome!
That was my concluding assumption.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 09:06 AM   #16 (permalink)
Member # 95025
The reason I got the kit was because I sheered the sector shaft turning 37s.
It took about about 3 years; but one New Years morning after getting off shift I was backing out of a parking space.
Half way through turning while backing out, the steering suddenly got incredibly easy.
Like, grandma's '75 Cadillac easy.
Got out and looked at the steering box; sector shaft was sheered clean off just above the pitman arm.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 09:57 AM   #17 (permalink)
Member # 847209
Got out and looked at the steering box; sector shaft was sheered clean off just above the pitman arm.[/QUOTE]
What are you driving?
Old 05-17-2019, 09:59 AM   #18 (permalink)
Member # 847209
Correct SRW. XLT crew cab
Old 05-17-2019, 10:59 AM   #19 (permalink)
snowracer's Avatar
Member # 141697
take the sway bar off or make disconnects if you want it for street driving. whats wrong with a stock pitman arm? not sure what you mean by idler as truck does not have one. like said in your other post you need to call EMF and get the tie rod/drag link set up the sell and that will be end of those issues. as already posted above add hydro assist to take some load off the steering box. this is all very noob shit that could be found with a little search time
PLAN-B F250 on 44s
Old 05-17-2019, 11:16 AM   #20 (permalink)
Member # 95025
That was my '99 F-350 PS with 37" BFGs.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 05-17-2019, 11:21 AM   #21 (permalink)
Member # 847209
I will absolutely contact EMF!
I am looking at making disconnects for the sway bar. Any downsides offroad?
Thanks for the input!
Not ashamed of being a noob. I dont know another person who is trying to do what i am. AND despite lots of searching I have spent a lot of money on bad advice. Even when I get good advice it sometimes takes a bit more follow up just to confirm it and make a plan.
I appreciate all those folks who are willing to help with their experience.
Old 05-17-2019, 01:16 PM   #22 (permalink)
Member # 177092
As Snoracer mentioned, your truck does't have an idler arm so I am not sure what you mean, and how did you break your pitman arm? I have only ever seen one broken pitman arm... Also, what do you mean by inner and outer tie rods It sounds like you are talking about an IFS Chevy front end instead of a Ford Dana 60.
As others have said, hydro assist will help steering 40s on a big, heavy truck and you can upgrade the steering linkage and joints. The late model Ford tie rod ends are pretty beefy though, so I am surprised you are having major issues with them unless you are putty shitty parts store replacements in it.
Just ditch the swaybar if it is primarily an offroad toy, but if you are worried about sway on the road, disconnects would be a good idea. Just make sure the swaybar doesn't get in the way of the tires or other suspension components throughout the travel and steering range while it is locked out.
Christ, have you been living under a rock?!
Supposedly all Super Duties got Dana 60s starting sometime in the 2003 model year, although the 2005+ Super Duties are definitely all Dana 60s with 35 spline outers. Ford even advertised this fact pretty heavily for the 2005 models when they came out.
Also, no such thing as a 3/4 ton dually from the factory that I am aware of for any year or make (not counting the goofy Jap mini-truck dualies).
'84 Bronco II is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 01:23 PM   #23 (permalink)
Member # 847209
I appreciate your input! It would be a lot easier to just remove the sway bar. Lost a wheel on the highway when my lug nuts sheared off is how i sustained so much steering damage. But still alive and unfurtunately had to go with OEM parts bc i dont yet know the proper aftermatket upgrades sources and vendors. So....will like have to do this again which sucks but that is why i am on the boards...to try to be prepared next time
Old 05-17-2019, 01:31 PM   #24 (permalink)
Member # 177092
Well, if all your stuff got damaged from a wheel coming off at highway speeds, then I don't think I'd blame the stock parts
I'd recommend making sure your lug nuts are properly torqued and running the truck as is. It looks like you are running in the mud instead of rocks based on your other post in the "Super Duty on 42s" thread, so hydro assist may not even be necessary for you unless you are having a lot of difficulty steering and shearing sector shafts in your steering box. The later model Super Duties have much better steering boxes than the earlier ones.
Old 05-17-2019, 01:44 PM   #25 (permalink)
Member # 847209
Wheel came off bc the tire shop used a lug centric spacer on a hub centric wheel. I did not know the difference until afterwards. Needless to say that I won't darken their door again. But i am not gonna quit off roading so....i am learning what i dont know with each experience good and bad. Just hate spending money twice. I will eventually have reliable sources and make fewer stupid (costly and potentially danerous) mistakes.
As far as mud goes...actually I avoid it when i can. Unnecessary wear and tear.
Similar Threads
F250 HP 44 help 1289 Jeep - Non Hardcore 10 08-26-2018 04:05 PM
40's or not to 40's? cjs1031 General 4x4 Discussion 36 11-19-2016 03:39 PM
1967 FORD F250 HIGHBOY WITH 7.3L POWERSTROKE SWAP 67-7THREE Vehicles and Trailers For Sale 5 06-21-2014 11:11 PM
