10.25 Carrier preload shims coming out - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2019, 01:46 PM   #1 (permalink)
Member # 436537
I have a zip locker in my rear axle that stopped working, and it looks like the carrier bearing preload shims squeezed out and broke the copper air line going to the air collar. Anyway, what causes this? too much preload? not enough? something else?
Thanks
shredator is offline   Reply With Quote Quick reply to this message
Old 05-31-2019, 04:36 PM   #2 (permalink)
mj
Member # 1919
use a better shim holder.
mj is offline   Reply With Quote Quick reply to this message
Old 06-01-2019, 03:50 PM   #3 (permalink)
Member # 225569
Thanks
Likely not enough preload - I had the same problem with my 8.8 rear on my Bronco. Changed the shim combinations to add 0.005 to each side and the shims stay seated, even without the bearing caps installed.
Sent from my SM-G920P using Tapatalk
'89 Bronco, 5.0, 4" Lift, 33's, GT40 Heads, D44 TTB, 8.8 Rear "Read more books"
66WarPony is offline   Reply With Quote Quick reply to this message
