Pirate4x4.Com : 4x4 and Off-Road Forum (https://www.pirate4x4.com/forum/index.php)
-   Ford (https://www.pirate4x4.com/forum/forumdisplay.php?f=9)
-   -   '05+ SuperDuty aftermarket track bar (https://www.pirate4x4.com/forum/showthread.php?t=2683688)
texastruck 06-11-2019 10:38 PM
I'm swapping in a Dana 60 from an '07 SuperDuty. It came with the track bar and frame mount, but that's not going to work for my application. I plan on just making an adjustable track bar out of DOM and 2 heims and then fabbing up a frame mount, but for the axle side, I really don't want to use the factory ball joint, as I hear those wear out pretty quickly. I saw this kit from ReadyLIFT that replaces the factory ball joint with a clevis so that you can mount a heim. I don't believe they sell just the clevis alone though, and I don't feel like paying $650 for the whole kit. Does anyone know of any other solution or product sold? I know these axles are pretty popular for swaps, so this problem must have been solved already.
https://www.readyliftstore.com/category_s/350.htm
Beat95YJ 06-11-2019 10:59 PM
Plate, drill and a cutoff wheel. Mock your bracket up with card paper and copy to steel.
texastruck 06-12-2019 06:05 AM
I’d like to use the stock mounting location on the axle, I would just like to eliminate the ball joint with something that would allow me to run a heim instead
snowracer 06-12-2019 02:12 PM
so you are willing to make a new trac bar and are installing this diff in something that its not meant for but cant cut the old bracket off and make a new one?
cut, grind, weld and make that shit work :homer:
:flipoff2:
texastruck 06-12-2019 02:27 PM
Yeah that’s what I’m going to have to do, just figured there was already something out there that would save me some time. Didn’t want to reinvent the wheel if I didn’t have to.
Pt_Ranger_V8 06-15-2019 06:29 AM
You're not reinventing the wheel, just a new trac bar mount :flipoff2:
Make sure you brace the shit out of it.
