Frame swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-27-2019, 10:28 AM   #1 (permalink)
Member # 869862
Question Frame swap
Will a frame out of a 92 f250 with a 7.3 fit a 94 f350 with a 7.3. Both 133 wheel base and 4wd
ynotosurac is offline   Reply With Quote Quick reply to this message
Old 06-27-2019, 10:30 AM   #2 (permalink)
Member # 869862
Old 06-27-2019, 10:39 AM   #3 (permalink)
Safety third!
Dr.Danger's Avatar
Member # 168243
Same frames, at least as long as both were same cab configuration.
-Dave
By the way, Irregardless does pass spell check and it is a word. The meaning is exactly the same, you just want to play games
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 06-27-2019, 11:33 AM   #4 (permalink)
Newbie
Member # 861326
if the 94 has an early powerstroke, the engine mount frame horns might be different from the 92 IDI, but they're bolted on so that's easy.
Other than that, I'd say it would be a bolt in swap provided the cab/bed config was the same, AS previously mentioned.
From what I've seen, the only difference in frames between even late 80's trucks and 90's Fords is the front of the frame horns where the bumper bolts on and the front spring shackles mount.
On half tons, they also added the crumple zone to the front in 92+.
Ford Guy
landen300 is offline   Reply With Quote Quick reply to this message
Old 06-27-2019, 01:08 PM   #5 (permalink)
arse_sidewards's Avatar
Member # 256962
These are both correct.
Old 06-28-2019, 01:37 PM   #6 (permalink)
Member # 52361
Frames are the same, but you might need to drill and cut rivets for front suspension if you're swapping bare framed but keeping ttb or your d60
What are you trying to accomplish?
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 07-11-2019, 06:48 PM   #7 (permalink)
bremen242's Avatar
Member # 28687
In 92, they changed the front shackles / bumper configuration. The shackles on the older frames where attached with a riveted 'box'; the newer frames are boxed in and bumper mounts differently.
The engine cross member for the diesels are different than the gas motors. The gas motors have a cutoff for the oil filter, which is where the diesel mount goes.
Originally Posted by fatdan460
i don't like it, i don't understand it, and i don't think it would do good doughnuts and burnouts.
bremen242 is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 11:39 PM   #8 (permalink)
ArTi54N's Avatar
Member # 104539
why are you swapping frames??
just curious..
ArTi54N is offline   Reply With Quote Quick reply to this message
