Just cant get my idis plugs to glow - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-05-2019, 04:58 PM   #1 (permalink)
ANGELO190471's Avatar
Member # 798001
so far I have 8 new motorcraft glow plugs, 6.0 harness and a new motorcraft controller. the controller has 12v on the main and ignition side of the solenoid, and has a good ground. when i turn the key my wait to start light comes on like it normally should, but the solenoid isnt actually activating. if i take my power probe and ground the solenoid out all the plugs will get power and the truck fires right up. what would be telling the controller to not activate the solenoid?
my last controller would was similar, except the light wouldn't be on quite as long and sometimes the light wouldn't turn on.
also not impressed with this 6.0 harness. the plugs are to long so it doesnt really sit right and they feel loose. think im going to make my own. i dont think this is my problem though, original harness did the same thing.
ANGELO190471 is offline   Reply With Quote Quick reply to this message
Old 12-05-2019, 05:57 PM   #2 (permalink)
bobbywalter's Avatar
Member # 15473
Send a message via AIM to bobbywalter
are you using the whole 6.0 setup or the old school drx 01001 or 003 style?
if it is an old style.... does the glow plug light come up and wait 10 seconds and go out or does it just stay on?
sounds like you have some wires switched around.
just hook the jumper to a momentary and run it manual like the rest of us.
if only
88 ranger ext cab p.o.s. hackjob powered by a 6.5 diesel clattering against a 4l80 thats punishing a f208 that is turning ford 60's rolling on 33-44 inch tires depending on the mission at hand
how ya like me now??
bobbywalter is offline   Reply With Quote Quick reply to this message
Old 12-05-2019, 06:30 PM   #3 (permalink)
Member # 798001
its a 92 so it has the new style controller. i am just using the 6.0 glow plug harness.
i dont think its wires switches, my glow plugs were fine for a couple years, then just started to get hard to start.
Old 12-05-2019, 07:02 PM   #4 (permalink)
Member # 15473
temperature is the only thing that stops it, but almost always strokes it for a second.
so if the wiring is correct i would assume you have brand new out of the box junk controller.
if only
Old 12-05-2019, 07:26 PM   #5 (permalink)
Member # 192237
just switch the solenoid with a button in the cab
[486] is online now   Reply With Quote Quick reply to this message
Old 12-05-2019, 07:38 PM   #6 (permalink)
Member # 798001
relay doesnt even click for a second. but my wts light is on for atleast 10...
im thinking it has to be the controller. just weird my other one was doing the same thing. keep reading how rare it is for the controllers to fail
or fix the problem
Old 12-05-2019, 07:39 PM   #7 (permalink)
clb 017's Avatar
Member # 166307
you been here yet?
https://www.oilburners.net
The best site for idi info
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 12-05-2019, 08:33 PM   #8 (permalink)
Member # 15473
or fix the problem
if it dont click at all....then its dead.
it should click just a hit at least at full temp. at full temp the glow plug light ma not turn on at all...but the relay should at least bump.
so...its junk....
i assume its the little home made bomb looking unit...those are usually potted. the other style screws into the block and runs the relay.
if only
Old 12-06-2019, 04:46 AM   #9 (permalink)
Member # 798001
so...its junk....
Yeah it's the bomb looking one lol. Is there anyway to test the controller other then with a known good one?
Old 12-06-2019, 05:53 AM   #10 (permalink)
today
fredycruger's Avatar
Member # 225557
is the relay grounded good?
fredycruger is offline   Reply With Quote Quick reply to this message
Old 12-06-2019, 06:44 AM   #11 (permalink)
Member # 798001
so...its junk....
Yes. I've even tried a jumper straight to the battery
Old 12-06-2019, 07:47 AM   #12 (permalink)
Member # 192237
or fix the problem
eh, the problem imo is trying to automate things that shouldn't be automated, then doing it with 1980s computer technology
Old 12-06-2019, 10:35 AM   #13 (permalink)
AllGoNoShow's Avatar
Member # 46318
Like everyone said, just push button it. Simplifies the system for future diagnosing.
Vote Trump 2016.
AllGoNoShow is offline   Reply With Quote Quick reply to this message
Old 12-06-2019, 05:26 PM   #14 (permalink)
Member # 798001
idk, its worked just fine since 92, and its a pretty simple and cheap system.. no reason not to keep on letting it work
Old 12-06-2019, 10:37 PM   #15 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Another vote for push button.
If you're using the IDI glow plugs still just remember they are a 6V plug and you can only hold the button down for like 10 seconds max, and then wait a minute before you try again if it doesn't start.
If you hold the button down for much longer than that it will burn them right out.
The one, the only, the Dane.
billybob_81067 is online now   Reply With Quote Quick reply to this message
Old 12-07-2019, 08:48 PM   #16 (permalink)
Member # 15473
said he had motorcrafts....all the modern ones should be self limiting..
i like the beru or 60g's....
no voltage issues.
if only
Old 12-08-2019, 10:26 AM   #17 (permalink)
Member # 798001
motorcrafts are berus.
when i disconnect the plug on the driver fender and test continuity between the two ignition wires on the relay, one of the wire has higher resistance. then on the other side of the harness it has only 5.4 volts, when the other wire has 12. that sound normal?
Old 12-09-2019, 01:16 AM   #18 (permalink)
Member # 4243
+1
Done this on every diesel I've had any glowplug issues on, ever.
Dodge cobbler... (1stgen cummins theme)
u2slow is online now   Reply With Quote Quick reply to this message
Old 12-09-2019, 07:21 PM   #19 (permalink)
Member # 15473
i dont know if i am following you correctly. but if its sub 10 at the gpr...no
if only
Old 12-10-2019, 09:28 AM   #20 (permalink)
Member # 798001
no the relay has 12v. but the ignition side of the relay has 2 wires. i was testing where the engine harness plugs into the truck harness.
Old 12-11-2019, 09:11 AM   #21 (permalink)
Member # 46318
No not normal, should have 12 on other side, bad connection there.
Vote Trump 2016.
Old 12-11-2019, 09:12 AM   #22 (permalink)
Member # 46318
Your glow plug timer could be bad, or not getting power.
Vote Trump 2016.
