'82 Bronco Buildup - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2006, 11:37 PM   #1 (permalink)
SquattyD's Avatar
Member # 25062
Send a message via AIM to SquattyD
'82 Bronco Buildup
Been workin on this for the past month.
SquattyD is offline   Reply With Quote Quick reply to this message
Old 03-23-2006, 11:37 PM   #2 (permalink)
SquattyD's Avatar
Member # 25062
Old 03-23-2006, 11:39 PM   #3 (permalink)
SquattyD's Avatar
Member # 25062
parts
3/4" x 3/4" fk rod end, 9/16" x 1 1/4" currie jonny joint, 3/4" x 1 1/4" evolution machine heim joint, and yes, thats newcastle in a can.
Old 03-23-2006, 11:40 PM   #4 (permalink)
SquattyD's Avatar
Member # 25062
Frame is done.
front suspension still needs a trac bar
rear suspension
another
Old 03-23-2006, 11:40 PM   #5 (permalink)
SquattyD's Avatar
Member # 25062
Old 03-23-2006, 11:42 PM   #6 (permalink)
SquattyD's Avatar
Member # 25062
daytime shots
still have a shit load to do. basically, i just had to get it so it could be a rolling chassis. theres a ton of stuff i have to add, and stuff i have to change.
Old 03-23-2006, 11:48 PM   #7 (permalink)
Andy351's Avatar
Member # 22290
Send a message via AIM to Andy351
i like where this is going.....
[CENTER]
[B]USE CODE: PIRATE10 FOR 10% SAVINGS ON YOUR NEXT ORDER!!![/B]
[/CENTER]
Andy351 is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 01:00 AM   #8 (permalink)
Member # 68967
what will you suspend it with?
On My Way to Impact... Taste the High Speed Dirt!
Captain Air Time is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 06:09 AM   #9 (permalink)
Call a Wrecker!
Aces'n'8s's Avatar
Member # 48097
Are you going to replace any of the OEM drivetrain components, besides the axles? Also, what are you going to do with that tailgate?
Aces'n'8s is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 06:53 AM   #10 (permalink)
Member # 28529
Looking Good!!!!
Earlybronco42 is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 10:27 AM   #11 (permalink)
SquattyD's Avatar
Member # 25062
coilovers and air shocks
300 is staying, getting rid of the trans and tcase, going to an np435 and a 203/205 doubler.
cut a section out of it so it fits. i will prob make it swing to the side rather than drop down like a normal tailgate.
Old 03-24-2006, 05:56 PM   #12 (permalink)
Member # 48178
what size are the Iroks
bigjakesxj is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 06:36 PM   #13 (permalink)
Member # 27040
Send a message via AIM to HickTrucksRus Send a message via MSN to HickTrucksRus
looks awesome man. I wish i got to see it. I just graduated today. Im off to cali to go The Fab School since i couldnt get in to chassis fab.
Keep the pictures comming!
btw where did you get new castle in a can!? and your room looks like my house did before my landlord made me throw away all the bottles
HickTrucksRus is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 07:15 PM   #14 (permalink)
dblue351's Avatar
Member # 1001
Send a message via AIM to dblue351 Send a message via Yahoo to dblue351
looking damn good!
71 Bronco with stuff.....
dblue351 is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 07:17 PM   #15 (permalink)
Member # 16680
sweet, but that cage needs some more support.
havent you finished the other one yet?
oh, more shots of the taper job please, floor board and inner fenders in particular.
plug ugly is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 02:13 AM   #16 (permalink)
SquattyD's Avatar
Member # 25062
haha, the back support tube for that cage isnt even tacked in, just wedged in there. it should hold, the curbs arent going to knock it loose.
iroks are 39.5 on 17" cragars with DIY4X locks tig'd on. the actual lock rings arent on there, they are just mounted normally. i didnt have time to mount all of them with the lock rings.
the 78 is pretty much done. a bunch of small stuff left.
i dont have any pictures of the dovetail, and im in CT for the next week or so. but it was pretty easy. i cut out the inner fender wells. marked at the rear how far in i wanted to move em. decided where to start the taper (right where the floor kicks up). i drew a straight line that connected the start to the new location of the bedsides. i then made 2 more cuts, one along that line, and one parallel with the bedsides, so i took a wedge shape out of the floor. i tried to push the sides in, but it didnt want to move that much. so we sawzalled a wedge out of the top of the bedrail right where the taper starts, and they pulled right in. right now, the sides are just tacked on. I am going to start finishing that in 2 months or so. at the same time, i also have to cut out more of the floor to fit the taller kick ups of the new frame. the body is just on there temp, once its on the final body mounts, it should be 4-6" lower. the axles and frame are at the correct ride height.
Old 03-25-2006, 09:23 AM   #17 (permalink)
Member # 45125
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Motor? Tranny?
08/02/74/66 F-250s, 97/79 F150s, 79/71 F100s
92/88/84 Broncos, 96/96 Exploders, 85 M1009
adrianspeeder is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 10:55 AM   #18 (permalink)
Banned
Member # 28375
Originally Posted by adrianspeeder
Motor? Tranny?
No one knows
badkarma88 is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 02:13 PM   #19 (permalink)
Member # 45125
Missed that, thanks.
What tranny was in there? SROD?
Old 03-25-2006, 09:14 PM   #20 (permalink)
SquattyD's Avatar
Member # 25062
i believe so, yes.
Old 03-25-2006, 11:35 PM   #21 (permalink)
Member # 7932
I like the dovetail!
1985 EFI longbed 4x4
2003 Tacoma 4x4
halfxspaid is offline   Reply With Quote Quick reply to this message
Old 03-31-2006, 02:29 PM   #22 (permalink)
Member # 62678
ok a couple q's
how did you do the rear panles to come in like that.
and what kind of tubing are you useing
way sick bronco, cant wait to start mine
bones2 is offline   Reply With Quote Quick reply to this message
Old 03-31-2006, 04:04 PM   #23 (permalink)
JJS
Member # 28835
nice. my buddy should take a hint from you on the '84 bronco he has.
2012 JK. Stock as hell for now.
JJS is offline   Reply With Quote Quick reply to this message
Old 04-01-2006, 10:03 AM   #24 (permalink)
SquattyD's Avatar
Member # 25062
Originally Posted by bones2
ok a couple q's
what I did to the rear panels is called a dovetail. plug ugly asked about, and i told him what i did. you just have to scroll up a bit. i dont have any pictures of it right now, but i can get some later.
i used 1.75" x .120" EW for the cage
2.0" x .120" EW for the frame backhalf
0.875" x .156" DOM for link mounts
1.0" x .125" DOM for link mounts
'82 Bronco Buildup thread
Old 04-01-2006, 09:09 PM   #25 (permalink)
Member # 29213
Send a message via AIM to msuforeman
Nice work so far Squatty
Brian
95 Bronco-rear arb,hs9500i,oba and some goodies
74 EB--302,c-4,4.88's,f/r arbs,ps,power disks,3.5" Duff w/arms,2"bl,warn axles,ctms,38" sx's,warn 8274,stonecrusher steering
96 PSD w/ a couple of goodies
msuforeman is offline   Reply With Quote Quick reply to this message
