The HayWagon - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2010, 12:13 PM   #51 (permalink)
snowracer's Avatar
Member # 141697
Originally Posted by Loki89t View Post
Me too, to bad I bought a new truck right before I got laid off
ya it kinda sucks becasue i was just about to buy a house but i guess that will have to wait a bit now
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old 03-16-2010, 08:01 PM   #52 (permalink)
SAY789's Avatar
Member # 88573
Send a message via AIM to SAY789 Send a message via MSN to SAY789
i lovre the blacked outness of the truck looks sweet. btw what u hidin under the camo lol? so i have heard of inboarding the rear springs with 63's makes it way more flexy right? and how much lift does it make over stock or compared to ur old springs?
'94 F350 CC .030 460 Auto 4x4 "Tow Rig"
'78 F350 Sittin Pretty On 39.5 Boggers R.I.P.
'94 Ranger 3/4 ton 5.8L 38.5 Boggers
Taylor
I think I heard that the model with the rear blocks and neg arched fronts was the super rare model called a Medium Boy.
SAY789 is offline   Reply With Quote Quick reply to this message
Old 03-16-2010, 10:37 PM   #53 (permalink)
snowracer's Avatar
Member # 141697
thanks man im a all about the blacked out look
and i keep all the dead strippers under the camo tarp no its to help keep the snow and mud of the deck. but soon it will have dove tailed box sides so the camo tarp set up will be gone
and i was running 6inch procomp springs for 80-96 f150s and then a sky shackle flip and a 1inch block in the back so i think thats about 9inches of lift.
now with the 63s im sitting the same with stock chevy springs and my shackles are 7inches from eye to eye and im still running the 1inch block
down the road i will upgrade to some better springs and get rid of the block but on my budget right now this will have to do
PLAN-B F250 on 44s
Old 03-17-2010, 05:34 PM   #54 (permalink)
snowracer's Avatar
Member # 141697
finished up the rear bumper today
tomorrow i will pull the springs back out and change the bushings out for some poly ones and then beef up the rear shackles a bit then it will be flex time
PLAN-B F250 on 44s
Old 03-17-2010, 08:30 PM   #55 (permalink)
Member # 104270
Is there a particular reason you did this? was it for better springs or did you not like the shackle flip?
Fueled by Hate, caffeine, and sometimes whiskey.
[COLOR="Red"][SIZE="5"]WTB pulley cover for 1959 Homelite 9-23[/SIZE][/COLOR]
[COLOR="Red"][SIZE="5"]Semper Fi[/SIZE][/COLOR]
br0nc0xrapt0r is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 08:35 PM   #56 (permalink)
snowracer's Avatar
Member # 141697
it was to get a spring with less arch and the chevy ones are way longer and flex better. plus i was able to cut 12inches off the rear of the frame and keep my wheel base the same as before
PLAN-B F250 on 44s
Old 03-18-2010, 09:35 PM   #57 (permalink)
snowracer's Avatar
Member # 141697
ok finished it all up today
pulled the rear springs back out and changed the bushings for some poly ones and cut the overload spring down so no its a zero rate block
then beefed up the shackles with some left over .25wall dom
then put the winch controller and tail lights back on
tomorrow i will bleed the rear brakes then it will be time for a shake down run
PLAN-B F250 on 44s
Old 03-18-2010, 09:46 PM   #58 (permalink)
Member # 84725
Why aren't you running a turbo? Sorry if it's been covered already. I have been following your build, but I tend to look at pictures more than read.
homelessduck is offline   Reply With Quote Quick reply to this message
Old 03-18-2010, 09:56 PM   #59 (permalink)
snowracer's Avatar
Member # 141697
the truck is a 1990 and they didnt come with turbos till 94. i have an hx40 sitting in my parts room waiting to go on. just need some money to order the last few things i need then i will be putting that on. oh and im going to try and make 550 foot pound out of this old motor
PLAN-B F250 on 44s
Old 03-18-2010, 11:15 PM   #60 (permalink)
Member # 84725
Check out oilburners.net .
They are a ton of turbo kits for the IDI's. You can usually pick one up on CL for about $500 in good condition. You can also turn up the pump very easily if you wanted. IDI's are very good diesels. The aftermarket for them is slim, but there are a few NICE upgrades for them.
Old 03-18-2010, 11:28 PM   #61 (permalink)
snowracer's Avatar
Member # 141697
ya but its kinda hard to find a used turbo kit up in my area, but that is ok with me becasue as i said i am making my own set up that will work better for what i want plus i will have the water meth on there so it will help with the egts. the up side with how i want to set up the turbo i will be able to run a larger down pipe then what comes with the ats or banks kit and if i get some head studs and lower the compresion i will be able to make more boost and that hx40 wont have any problem with that
PLAN-B F250 on 44s
Old 03-18-2010, 11:30 PM   #62 (permalink)
Member # 153100
All that fab work and you just cable-tied the lights on? Surely there is a cooler way to finish those off?
Love the bar work man. Nice solid truck.
Droopz is offline   Reply With Quote Quick reply to this message
Old 03-18-2010, 11:34 PM   #63 (permalink)
snowracer's Avatar
Member # 141697
ya i know the zap straps on the lights is a little red neck but its just for now till get the dove tailed box sides back on then i will but the light back in the fenders, oh and i have new lights so i wont have the one with the tape holding it together
and thanks
PLAN-B F250 on 44s
Old 03-19-2010, 10:00 PM   #64 (permalink)
snowracer's Avatar
Member # 141697
ok got to take it out for a shake down run today and im very happy with it
found a car to ramp on
i think i will leave if for a bit because im going wheeling with the local club next weekend to give it a real run down, so nothing till then
PLAN-B F250 on 44s
Old 03-19-2010, 10:45 PM   #65 (permalink)
Member # 31425
Send a message via AIM to Ramboss429 Send a message via MSN to Ramboss429
Love your build man!
What front springs ya running?
Goodluck on getting to TTC!
Ramboss429 is offline   Reply With Quote Quick reply to this message
Old 03-19-2010, 11:26 PM   #66 (permalink)
snowracer's Avatar
Member # 141697
thanks man
im running 6inch skyjacker springs for the truck but i have taken the bottom leaf out to drop the truck down a bit and to get better flex. i still need to re work my front shackle set up becasue right now i dont get full up travle cause the shackle binds
PLAN-B F250 on 44s
Old 03-21-2010, 01:21 AM   #67 (permalink)
Member # 146998
Hey man, first of all, nice rig! I like it! Secondly, I know i saw your truck in a magazine, maybe a reader's rides section, where did i see it??
ozziemo27 is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 01:23 AM   #68 (permalink)
SAY789's Avatar
Member # 88573
mauybe in ttc voting u saw it
Taylor
Old 03-21-2010, 11:23 AM   #69 (permalink)
snowracer's Avatar
Member # 141697
thanks man and like say789 said im truck number 1 in this years TTC
PLAN-B F250 on 44s
Old 03-27-2010, 06:53 PM   #70 (permalink)
snowracer's Avatar
Member # 141697
well the truck has been sitting since the spring swap but im going out tomorrow so that will be the real test
went out to my buddies place today and cut up my spare truck box for the skins
got the box for free from a customer of mine last year, not the best shape but has no bondo in it so i can work with that
took about a hour to cut the sides off with the grinder but it did a nice job
and whats left of the box
now just got to get the sides back to the shop and start cutting the rust out and then bob the back down. then i can mock them up before paint
PLAN-B F250 on 44s
Old 03-28-2010, 10:14 PM   #71 (permalink)
snowracer's Avatar
Member # 141697
well went out wheeling today and it was great, the new rear springs are awsome and im very happy with them
truck did great today and held up to everthing i did, and i pushed it hard today
other then a few new dent and in need of a wash its all good
PLAN-B F250 on 44s
Old 04-03-2010, 09:15 PM   #72 (permalink)
snowracer's Avatar
Member # 141697
well started to work on my box sides today and im really diggin the look
started with a little trim job
the spot welded the tail light part back on then did a test fit
still have lots more to do and hope to get the sides looking good tomorrow
PLAN-B F250 on 44s
Old 04-04-2010, 11:47 AM   #73 (permalink)
Member # 76552
Send a message via AIM to Loki89t Send a message via MSN to Loki89t
The box sides are looking good.
Loki89t is offline   Reply With Quote Quick reply to this message
Old 04-04-2010, 03:42 PM   #74 (permalink)
SAY789's Avatar
Member # 88573
Awesome so far man lookin great
Old 04-05-2010, 01:28 PM   #75 (permalink)
Member # 154000
Cool
Nice, OBS ford diesel - my fav. I've been lurking around looking for a thread like this for a Fullsize FORD truck for a while now! Good to know what a shortened bed will look like without a wheelbase change.
03 Duramax,
85 K20 - farm truck - needs brakes & tune
SS350 is offline   Reply With Quote Quick reply to this message
