Crossing committee 7/1/2017 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Fordyce Creek
Old 07-03-2017, 10:26 PM   #1 (permalink)
Member # 343769
Committee crossing 7/1/2017
It was moving pretty good, chart said 350 cfs
Good thing I brought my Home Depot made snorkel!
https://youtu.be/ljyP6b-oheM
brknsht is offline   Reply With Quote Quick reply to this message
Old 07-04-2017, 08:26 AM   #2 (permalink)
Member # 125922
Commitee Crossing July 2017.340 cfs
https://youtu.be/din4hIxL0yA
scouttanks is offline   Reply With Quote Quick reply to this message
Old 07-04-2017, 09:21 AM   #3 (permalink)
YotaAtieToo's Avatar
Member # 25632
So glad I went in through Medow lake side.
Old 07-04-2017, 09:25 AM   #4 (permalink)
Member # 25632
Originally Posted by scouttanks View Post
Why were they all trying to go before the guy in front was out of the way?
Old 07-04-2017, 11:31 AM   #5 (permalink)
Member # 53528
this is the line you should take when its deep
https://www.youtube.com/watch?v=GMnnzKnuv-o
Old 07-04-2017, 11:34 AM   #6 (permalink)
Member # 53528
better question is why go through the deepest hole
Old 07-04-2017, 12:44 PM   #7 (permalink)
Member # 429
Because they were concerned for other people down river and wanted to create a dam so the water level would be lower for them...
Jack
2007 2500hd max/ali with stuff.
2008 FWC Hawk
1985 4Runner 4.3, R151 on tons
locrwln is offline   Reply With Quote Quick reply to this message
Old 07-04-2017, 01:07 PM   #8 (permalink)
Member # 343769
I went first because I'm pretty well waterproofed. The 4 rigs after me all hooked themselves together because I guess they figured if one guy got screwed they could either back out or tug forward. It didnt work very well as you can see.
I took the deep line because I didn't want to drive up river. It would have pushed me around even more and definitely been coming over the hood.
Good times! Two hydrolocked rigs one completely tacoed rim.
Old 07-04-2017, 01:30 PM   #9 (permalink)
Member # 53528
fwiw if you take the line i posted video of it works fine going the other way across, i dont have video but we all went back across that same way and all made it just fine, also that red toy is on 37s and doesnt sit very high, and that was at 430cfs. when you cross a fast moving river at an angle youre giving the rushing water angles to flow around you, when you cross straight the entire side of your vehicle is exposed and you get pushed around much more doing it that way, which is why you ended up pushed down into the rock.
good times though thanks for the video
Old 07-04-2017, 01:31 PM   #10 (permalink)
Member # 343769
I took that line going across the first time. You can see the water come over the side of my rig in the deep hole. Definitely didn't want to drive against the current.
Video below
https://youtu.be/aIixA6zzQQE
Old 07-04-2017, 01:34 PM   #11 (permalink)
Member # 53528
Video below
too far right fwiw
Old 07-04-2017, 01:43 PM   #12 (permalink)
Member # 343769
Ok I'll give that a shot next time for sure. Thanks for the pointers! That's definitely they fastest and highest I've crossed. Chart said 350 or close to it but from watching other videos and talking to a local guy (red fj40 who said he believed it To be closer to 450) probably moving faster.
Old 07-04-2017, 01:56 PM   #13 (permalink)
Member # 53528
i agree thats more than 350 with the run off
Old 07-04-2017, 02:01 PM   #14 (permalink)
jeepfamily's Avatar
Member # 19879
Wow
Dreamflow now
2016 jk chromo 40s daily, 06 dodge 351/480 efi on meth, 2011 mid engine buggy
jeepfamily is offline   Reply With Quote Quick reply to this message
Old 07-04-2017, 02:20 PM   #15 (permalink)
Member # 343769
Ha! Dropped down to a trickle. I was surprised by how low Fordyce lake was and they were still letting 350 out.
Old 07-04-2017, 06:26 PM   #16 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
Dropping in from Committee between the 2 trees, you need to go 45* left (downstream) once you hit the water. (basically like was said before, more to the left than in the video).
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 07-04-2017, 06:27 PM   #17 (permalink)
Member # 25632
Proper way is to drive up stream at an angle, its supposed to make an air bubble in your engine compartment (not always going to happen with our chopped up rigs) as well as what rockota said about helping the water flow around.
Old 07-04-2017, 06:28 PM   #18 (permalink)
Member # 25632
Originally Posted by jeepfamily View Post
Dreamflow now
Seems wrong.... Look how perfectly flat the line is.
Old 07-05-2017, 10:18 AM   #19 (permalink)
Member # 343769
I NEED to go straight and grab second gear. Works great, tons of fun. Ain't no body got time for air bubbles and fancy water flow theory's. Fuggin get it!
No really though watching that other video of the red Yota that line looks tits.
Old 07-05-2017, 11:35 AM   #20 (permalink)
Member # 25632
So was anybody up there yesterday to see the water at 40 cfs?
Old 07-05-2017, 09:47 PM   #21 (permalink)
Member # 53528
less flow means less turbulence/waves hitting the sensor so no up and down readings, im betting thats why its flat, i have no idea but my guess is its not wrong.
Old 07-06-2017, 12:51 PM   #22 (permalink)
Member # 25632
Seems like a big coincidence that it dropped on the 4th, maybe they assumed people would be going up this weekend?
Old 07-06-2017, 02:18 PM   #23 (permalink)
djelliott916's Avatar
Member # 134532
Awesome!!
"Thanks for polluting our water with your gear, motor and transmission oil along with all greasable locations douchebags... Lets see what the authorities say about your crossing. Video and channel info has been sent."
djelliott916 is offline   Reply With Quote Quick reply to this message
Old 07-06-2017, 05:05 PM   #24 (permalink)
Member # 25632
Anyone heading up there this weekend? Was thinking about taking my boy up there but can't find anyone else who wants to go.
Old 07-07-2017, 06:53 AM   #25 (permalink)
Member # 343769
I wish I could go back up, I'm curious to see what the flow looks like. Work is a boner blocker.
