FJ80-based 4-seater truggy build at Pacific Fabrication - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-05-2011, 02:04 PM   #126 (permalink)
Member # 30721
Awesome! Love to hear that other people are building on this platform.
Think I've already posted pictures that pretty much cover what you're asking about? The rocker tubes are welded to a 2x3" crossmember that spans the framerails at the B-pillar, and there are a multitude of tubes that are tie the rocker into the A-pillars. Not sure how helpful it might be to you, but can ask the owner how he would feel about me sharing some of the CAD files?
Just curious, why would you ditch these axles?
gatosbros.com cruxstudio.com trailslesstraveled.com
JESSE_at_TLT is offline   Reply With Quote Quick reply to this message
Old 11-05-2011, 08:07 PM   #127 (permalink)
Member # 3937
Originally Posted by hellataco View Post
I rolled my 98 4Runner last Saturday.
He's not ditching the Cruiser axles, he has a 4skinner!
"Those who hammer their guns into plows will plow for those who do not..." - Thomas Jefferson.
mrboyle is offline   Reply With Quote Quick reply to this message
Old 11-06-2011, 12:07 AM   #128 (permalink)
Member # 30721
Ah, missed that. Started with a 3rd ten 4Runner the 1st time too, but that project never really got off the ground.
Old 11-06-2011, 08:53 AM   #129 (permalink)
Member # 108345
well not to hijack but this is where i am at right now. now sure wheather i should just hack the whole rocker structure off or just run tube through it with a hole saw. but ill admit i havent got much of a plan, other than i'd love to get it to try and look similar to what you've got going on. how did you determine where to start your measurements? would it be a good idea to get the axles under the truck before i do too much else also?
hellataco is offline   Reply With Quote Quick reply to this message
Old 11-06-2011, 11:43 AM   #130 (permalink)
Member # 30721
Personally, would cut away all that sheet metal. At least back to the seam in the floorpan where it transitions from the floorpan to the rockers. Look where we cut the FJ. Will make the chassis narrower (where you don't need the width anyway) and will make fabrication easier. When it comes to taking measurements, have found the most important things to be, 1) level the chassis. 2) create a zero-point, and make all measurements relative to that zero-point (or at least use the zero-point to verify measurements). 3) create a center-line (easiest to use something like a laser-level to do this). For more information about taking measurements, take a look at this thread. Axles under the truck? Yes! Would absolutely be the first thing I'd work on. Get the axles in there, figure out the suspension linkage, and think about where the shock mounts will need to be located. Then cycle the suspension to figure out what kind of dimensions you're working with, as far as clearance for things like wheels/tires, etc. That is what should drive the chassis design/layout as far as I'm concerned. You know, instead of building something, and then adding things like shock mounts and shit like that as an afterthought.
Old 01-10-2012, 03:08 PM   #131 (permalink)
Member # 198573
And then???
I didn't plan on going for a run this morning, but those Cops came out of nowhere!
Necromancer_tat is offline   Reply With Quote Quick reply to this message
Old 01-10-2012, 07:19 PM   #132 (permalink)
Member # 41764
Originally Posted by Necromancer_tat View Post
And then???
It's still sitting in the machine shop in exactly the same state as the last update.
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 12-15-2012, 08:01 PM   #133 (permalink)
Wilson's Avatar
Member # 7233
Updates?
Old 12-15-2012, 08:10 PM   #134 (permalink)
Member # 30721
No, not really. Ran into the owner a while ago and he's been busy racing motorcycles.
Old 01-26-2013, 01:26 AM   #135 (permalink)
Member # 30721
Stopped by pacfab earlier this week and the FJ80 is back in the shop! Guess the owner decided that he wanted to finish it up and take it down to KOH. Only snapped a couple quick pics on my cellphone, but Kyle had finished the seat mounts and was working on mounting the fuel tank mounts, and it looks like they'be been working through a lot of the lingering little details, like capping those front shock mounts and all that fun stuff.
Old 01-26-2013, 08:50 AM   #136 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Well it's official, I am going to do basically the same thing you did here. I'm currently sitting with a rig on tons and a firewall and not really knowing how I wanted to set it up until I read through this build, I like it nice build dude.
COMBAT VET - USMC 01-05
FRIENDS OF FORDYCE
kdub0013 is offline   Reply With Quote Quick reply to this message
Old 01-27-2013, 05:27 PM   #137 (permalink)
Member # 41764
As of Thursday it runs and drives. All 4 seat mounts and harness mounts are in and Jason mounted the air tank and ARB compressor. Lots of finish work to go, going to be tight getting it wheelable for KOH.
Old 01-27-2013, 09:15 PM   #138 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
no good pics of the progress but I did pull it out into the parking lot on friday to get a side by side shot of a stocker. Nice little before and after.
Current build-2002 Chevy truck buggy, 06 front clip tube-coilovers,bypasses-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
2006 dodge 3500 dually tow rig
1967 chevy K10, d60 14bff detroit, 37 mtrs, lq4, sm465, np205
jays68yak is offline   Reply With Quote Quick reply to this message
Old 02-04-2013, 11:32 AM   #139 (permalink)
YotaAtieToo's Avatar
Member # 25632
The pacfab guys are all up at the Rubicon right now, so the owner decided to take the rig over to his shop, where he's going to do some wiring and sort-out some of the smaller details over the weekend.
Can someone at the shop show the owner how to properly tie down a rig so this sweet project doesn't end up tumbling down the freeway
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 02-04-2013, 12:18 PM   #140 (permalink)
Member # 30721
Was such a short tow we could have pushed it there. Literally around the corner.
Old 02-04-2013, 02:45 PM   #141 (permalink)
jays68yak's Avatar
Member # 19015
Yeah what he said. I'll post a picture of it strapped down behind my motorhome on the way to koh.
Old 02-13-2013, 08:46 PM   #142 (permalink)
jays68yak's Avatar
Member # 19015
Ok got super busy trying to get it to a point to drive it around at KOH. But heres some pics from the week leading up to KOH.
Old 02-13-2013, 08:48 PM   #143 (permalink)
jays68yak's Avatar
Member # 19015
A few more.
Old 02-13-2013, 09:36 PM   #144 (permalink)
Member # 95025
Pretty awesome build!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 02-13-2013, 10:16 PM   #145 (permalink)
Member # 73963
Was camped next to the 80 buggy at koh. Its cool. Well executed. Just needs a 3 link in front....
IFS build
turbod the Lexus
Tons and 42's on the Lexus
laproscopic is offline   Reply With Quote Quick reply to this message
Old 02-13-2013, 11:02 PM   #146 (permalink)
Member # 30721
Yeah, that was the next thing on the list (3-link). Just stoked to see that thing out of the shop!
Old 11-08-2013, 08:28 AM   #147 (permalink)
Member # 83301
bumpity!
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 04-07-2014, 10:21 AM   #148 (permalink)
Member # 30721
This was such a cool project. Had told the owner to give me a call if he ever wanted to sell it...
...and now it's sitting in my driveway! He'd been too busy with other things to do much with it, so we made a deal, and now I'm finally going to have a chance to finish it. Already up to my ass in other projects, but couldn't be any more excited. Have a things I need to wrap-up, then I'm going to put this thing back on the road. That just means finishing up a few details, like adding a windshield, lights, mudflaps, smog equipment, etc. Then it'll get stripped, sandblasted, and painted.
Old 04-07-2014, 10:37 AM   #149 (permalink)
Member # 3007
Always liked this build. can't wait to see more on it.
Bones is offline   Reply With Quote Quick reply to this message
Old 04-07-2014, 11:08 AM   #150 (permalink)
Member # 41764
I wondered where he was going to store that thing considering the building changes. I guess that was an option I hadn't considered, get rid of it
