FJ80-based 4-seater truggy build at Pacific Fabrication - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2014, 01:45 PM   #151 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
Kyle, he has the old fab side of the old shop.
Jesse, that's pretty cool. At least it will get used now. It moved pretty good out at the hammers in 13. Did you change the wheels and he kept the other ones for the other truck?
Current build-2002 Chevy truck buggy, 06 front clip tube-coilovers,bypasses-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
2006 dodge 3500 dually tow rig
1967 chevy K10, d60 14bff detroit, 37 mtrs, lq4, sm465, np205
jays68yak is offline   Reply With Quote Quick reply to this message
Old 04-07-2014, 02:50 PM   #152 (permalink)
Toyoland66's Avatar
Member # 35163
Cool project, can't wait to see more.
1979 FJ40
Toyoland66 is offline   Reply With Quote Quick reply to this message
Old 04-07-2014, 03:21 PM   #153 (permalink)
Member # 41764
I know, but you saw all the machines and tools he had packed at the other bldg right? Add the TT that didn't go with you I figured he'd be out of space for sure.
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 04-07-2014, 06:09 PM   #154 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
Cool deal! My local club buddies have built 2 80 series buggies on the cheap and they work awesome.
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 04-08-2014, 02:23 PM   #155 (permalink)
Member # 30721
Yeah, super stoked to have an opportunity to finish building this thing, and to own it! Nothing else I'd rather build or drive right now. Worked out a trade with my brother for those OMF beadlocked Alcoa wheels that he pulled off our Tacoma a while ago. That little thing didn't handle very well with 35's on 17's, so he re-geared it and went back to 33x10.5's on 15's. But those wheels are perfect for the truggy. Each wheel is over 16lbs lighter than those Centerlines, and they're an inch narrower, with the same backspacing.
gatosbros.com cruxstudio.com trailslesstraveled.com
JESSE_at_TLT is offline   Reply With Quote Quick reply to this message
Old 04-08-2014, 04:05 PM   #156 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Simple version. He's got as much in the tires as in the truck.
Attachment 1278650
Sent from AutoGuide.com Free App
Nolen Grogan
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
Old 04-10-2014, 09:09 AM   #157 (permalink)
Member # 30721
Hey Jason, do you remember what gears are in this thing? Stock rear axleshafts?
Old 04-16-2014, 07:57 AM   #158 (permalink)
jays68yak's Avatar
Member # 19015
I dont remember ratio, kevin doesnt either. Thinks its as low as we could go since it wasnt getting any tcase mods. Stock rear shafts, longs in front.
Old 04-17-2014, 11:08 AM   #159 (permalink)
Member # 450098
This thing is Titties! What kinda travel are you getting?
AssaulT/A is offline   Reply With Quote Quick reply to this message
Old 04-17-2014, 09:29 PM   #160 (permalink)
Member # 18528
Send a message via AIM to BenMara
so tempted to go this route with my FZJ80
Function before Fashion
BenMara is offline   Reply With Quote Quick reply to this message
Old 04-18-2014, 01:41 AM   #161 (permalink)
Member # 30721
Ah, thanks anyway. No big deal. Easy enough to figure out. What do you think about driving this thing on the street with those Longfield shafts up front. Read something about how they might wear-out prematurely?
...they're custom-made short-bodied 17's. Bilstein's 15" coilovers only cycle 14.2" metal-to-metal, so that would have left us with about 13" of usable stroke after bumping and strapping. The stock (slightly modified) suspension is capable of cycling about 15" of pretty clean vertical wheel-travel, so we would have had to limit travel if we used shorter shocks. 15's probably would have been just about right for the stock fronted, which cycles about 13" of vertical wheel-travel, but we had room to fit 17's, and it's convenient to run the same shocks at all four corners.
So these are FZJ80's huh? Just noticed that while I was doing some research last night.
Old 04-18-2014, 06:38 AM   #162 (permalink)
Wilson's Avatar
Member # 7233
There are around 40k on my rcv 80 series shafts. If you are that worried about them you could do a part time conversion. Seems you like to tinker, but personally I wanted to maintain the awd.
Fzj's are '93-97 with the 1fz engine. '91 and '92's are just fj80's
Old 04-18-2014, 09:29 AM   #163 (permalink)
Member # 30721
Yeah, this was a '96 model. Thanks for the feedback on those shafts. Some of the stuff I was reading made it seem like it would be similar to running 300M u-joints on-road. Would definitely prefer to keep it AWD. Removed the selectable hubs from my Tacoma, and that's got an Atlas in it, but run it in 4WD almost all the time. Handles so much better. Do like to tinker though, and was looking into diesel swaps. Was thinking about a 3.3L Cummins with a 5spd, and then found out about the medium-duty Mitsubishi engines and similarities in the transmissions those trucks use. Looks like that would be make for a pretty straightforward swap. Curious to weigh this thing. Know it's lost some weight, but the fuel economy is gonna be abysmal and I'd like to DRIVE this thing. A lot. Runs great for now though. Not going to mess with the drivetrain any time soon.
Old 05-01-2014, 12:36 AM   #164 (permalink)
Member # 30721
Finally satisfied my curiosity and weighed it today at a local rockery. Empty tank and no spare tire, so lost around 500-600lbs? Not too bad considering all the tubing in this thing and the weight of those wheels/tires.
2570: front
1620: rear
4200: total (off by 10lbs)
Old 05-01-2014, 11:33 AM   #165 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
What was the weight? Did you omit that part on purpose?
Hoarder of Land Cruisers, wheeler of none.
Arya Ebrahimi is offline   Reply With Quote Quick reply to this message
Old 05-01-2014, 02:12 PM   #166 (permalink)
Member # 30721
No, that's weird. I put the weights. Must have accidentally clipped them while posting.
Old 05-01-2014, 06:38 PM   #167 (permalink)
Member # 7876
I think the factory curb weight on these is a lie. I've yet to see one scale less than 6k lbs. I'd say you're doing awesome at 4200lbs
Old 05-01-2014, 06:46 PM   #168 (permalink)
Wilson's Avatar
Member # 7233
Pretty sure booger's did
Old 05-01-2014, 07:12 PM   #169 (permalink)
Member # 7876
I didn't see Booger's on the scale my stock 80 with the exception of a bull bar (no winch) weighed in at 6500lbs with me in it and I weigh less than 200lbs.
Old 05-01-2014, 10:38 PM   #170 (permalink)
Member # 30721
Whoa, 6500lbs!?! Forget how much tubing I put into this thing, but would be pretty easy to figure out. Just have to fire-up SolidWorks. Haven't ever driven a stock FZJ80, so I don't have anything to compare it to, and don't even know what gears are in this thing, but it's a blast to drive. Wondering about fuel economy. Might not be too bad around town. Gonna get another set of wheels/tires to run on the street, and minimal bodywork but it's not exactly sleek.
Old 05-13-2014, 03:46 PM   #171 (permalink)
Member # 30721
Anybody have CAD models of the oval insert and/or hood for an FJ40? Also willing to buy those parts to cut-up and modify if the price is right. Located in the bay area, but would be willing to drive a reasonable distance to pick up these parts.
Old 07-07-2014, 12:36 AM   #172 (permalink)
Member # 30721
Haven't had much time to work on the truggy, but I've started modeling the bodywork. This is a good excuse to practice surfacing in Solidworks, but doubt I'll do anything more than re-skin it with sheetmetal anytime soon. Too many other things I need to finish first.
Started the re-registration process at the DMV. Title was surrendered when this thing was totaled, so had to apply for a new salvage title, and of course it's been a pain in the ass. Was able to get the VIN verified, but it's not quite ready for the brake and lamp inspection or smog test. Was planning on wheeling it through the summer with a green sticker, but the DMV shot me down. Told me that I can't get a green sticker until I either finish everything required to re-register it, or junk it. Ugh, fawk that! Don't want to have to start all over again. So think I'm going to try to make some time to finish this thing sooner than later.
The DMV did give me a 60-day temporary operating permit though, and it's expired now, but you can bet I made good use of it! Drove it over to Santa Cruz one afternoon and it handled great over 152. The suspension isn't set-up at all, but it still handles a lot better than a stock Land Cruiser. Also checked the mpg on that trip and burned exactly 5 gallons of fuel in 75 miles, and we were rallying pretty hard. Will be pretty stoked if this thing averages anywhere near 15mpg.
Old 07-18-2014, 09:30 PM   #173 (permalink)
Member # 30721
Anybody want to build something like this? Now that I own it, can share the CAD files...
Old 07-21-2014, 06:27 AM   #174 (permalink)
Member # 18528
only in my dreams....
Old 07-21-2014, 01:57 PM   #175 (permalink)
Member # 30721
krazytoy is selling a stripped FJ80 project for $2000 that would make a great starting point for a project like this. Could turn that into something pretty cool for less than what, $5000-6000?
