Driveline rotational torque - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2011, 06:54 AM   #1 (permalink)
Member # 24300
How important is it to control the driveline rotational torque on a buggy: big block, auto, use to have the 203-205, now mounting an atlas. There's poly mounts on the motor (2), trans back (2), and planning on putting an atlas support ring on the back. I liked how the 205 could be mounted on the side too, is this something that I need to look at for the atlas too? Perhaps making an extra side mount by using the bolts off of the front output, any ideas or help on this topic?
Thanks.
BlueAngel is offline   Reply With Quote Quick reply to this message
Old 09-22-2011, 06:59 AM   #2 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
You could but I don't think you need it. Just got with the support ring.
DOUG38S is offline   Reply With Quote Quick reply to this message
Old 09-22-2011, 07:07 AM   #3 (permalink)
Member # 72504
Support ring should be enough support george but having said that I had my second mount off the front output bolts on mine just for this reason.
Throttle Happy is offline   Reply With Quote Quick reply to this message
Old 09-22-2011, 08:06 AM   #4 (permalink)
dobsogj's Avatar
Member # 16561
I dont think the support ring clamping to the tail housing is designed to help with rotational forces. Its purpose is to support the weight of the case, but Im sure you know that. I had one on my 4 speed atlas, cause it was so long, I was concerned about all of that weight being supported by the adapter. The drawback to the ASR is that if you belly out and bend either of your cross members supporting the front or back of the atlas, something will have to give. Either the adapter or tranny case. My opinion is they arent needed on the 2 speed atlas. But if you do use it, overbuild your cross members and mounts. One option would be mounting them from above if there is room. Depending on what transmission you are running, you may be able to flip the adapter over.
As far as aditional torque control, I have seen some nice mounts on here that have been built off of the front output housing, or the pan bolts on the bottom.
4 seat FJ40 buggy. Alum 5.3 - Th400 - Atlas 4 speed - 60/14 - 42" stickies...etc...
Gone but not forgotten: 81 toyota truggy - LT1 - Th400+203+atlas3.0 - 60 / 14 - 42s.
dobsogj is offline   Reply With Quote Quick reply to this message
Old 09-22-2011, 08:10 AM   #5 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Unless you're doing some kinda midplate or head mount...two good motor mounts and a good trans mount in the middle will be fine; use the atlas support to save the trans tailhousing, not to help with torque.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is online now   Reply With Quote Quick reply to this message
Old 09-22-2011, 09:19 AM   #6 (permalink)
Member # 24300
OK thanks guys, it's an atlas 4sp, and that's why I got the support ring. I'm going to try to mount it from the top down, but I will see if it fits that way. I'll search for pictures of atlas side mounts.
