Pinion angle for Rockwell? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-11-2002, 02:46 PM   #1 (permalink)
Member # 1136
What is the angle on a stock duece? my buddy said he is running them on an angle and the stock perches are built on an angle. I am gonna be running leaves.
Toddy
IROCWEL
Toddy is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 02:50 PM   #2 (permalink)
Member # 2857
front or rear?? In the rear do whatever you need for driveshaft vibration. The front is suppoed to have like 4deg. neg. caster, right Jeeper111????
BTG Rockcrawlers - Phoenix, AZ
Rockwelled FJ40 buggy - slow , 2010 Nissan GTR - fast
elf_cruiser is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 03:17 PM   #3 (permalink)
Member # 1136
Thanks I need front and rear. It wont see much street time but I want to do it right for 1 time in my life. Or atleast get it close.
Todd
IROCWEL
Old 12-11-2002, 03:27 PM   #4 (permalink)
Member # 15220
i think 4 degrees is the stock angle.....
bobo is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 05:22 PM   #5 (permalink)
Member # 6588
what about for rear steering?
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green]
[/COLOR]
BJ On Roids is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 05:26 PM   #6 (permalink)
Member # 2857
well BJ, for rear steer i would say go with whatever you need for the driveshaft. The reason for proper caster is to make the tires return to center when driving at speed on pavement. Most people will only use rear steer on the trail, so the caster on the rear axle is not that important. Now, if you plan on using rear steer when driving around town, then perhaps proper rear caster is something to consider...
Old 12-11-2002, 08:02 PM   #7 (permalink)
Member # 1136
My buddy said it was more he diodnt know for sure but the way hetalked it wa more then 4 deg. Where is Daniel when you need him?
Toddy
IROCWEL
Old 12-11-2002, 09:13 PM   #8 (permalink)
JOHNS351C's Avatar
Member # 8282
Ok this is just a theory but I believe that it can cause a vibration running zero caster on a steering axle (refering to the rear axle in this situation). My thought is that the wheels put a slight amount of tension or compression on the tie rod end when they have something other than zero caster. So if you have zero caster the steering linkage will not have any tension on it, so if it has even a slight amount of slop in the linkage the wheels will kind of teeter for and aft, causing a hammering on the linkage making it more sloppy. does anyone know what I am talking about, or am I just thinking to far into it?
John
[SIZE=4][COLOR=DarkOrange]Stazworks[/COLOR][/SIZE]
[B]The leader in Custom Double Beadlock wheels[/B]
On SALE NOW [COLOR="DarkOrange"][SIZE="2"][I]20x14's[/I][/SIZE][/COLOR]
Due to NEW tooling we can now build std. 1pc 20x14's, and up to a 20x25's without banding!
[COLOR=DarkOrange]
333-RIMS,(7467) shop number
(715) 333-7250 office
John Staszak-owner
JOHNS351C is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 09:15 PM   #9 (permalink)
Member # 5790
Actually all you guys are wrong. your stock caster needs to be between 4 and 6 degrees negative, however, if you run the duece front end as a passenger side drop then you will have 2 degrees positive caster with a flat pinion angle. This means that you will have to tilt the pinioon down 6 degrees in order to achieve 4 degrees negative caster. This is the problem I have recently run into and it is why I will have to have a CV on the pinion of the front rockwell. It is the only way to do it right!!!
"I got the chrome but I couldn't quite afford the moly!"
jeeper111 is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 09:55 PM   #10 (permalink)
Member # 845
Where in the world did you come up with this? No wonder your the only one who needs a $1000 front driveshaft!
I set my pinion angles for the driveshafts, I don't even know what my caster angles are :P
CJ
CJ Lagos is offline   Reply With Quote Quick reply to this message
Old 12-11-2002, 10:53 PM   #11 (permalink)
Member # 15220
2 degrees positive........6 degrees negative..... ......ooook i get it....nope still confused as hell
Old 12-12-2002, 01:41 AM   #12 (permalink)
Member # 2190
You mean run it as a driver side drop?
TTURokToy is offline   Reply With Quote Quick reply to this message
Old 12-12-2002, 08:12 AM   #13 (permalink)
Member # 14953
the rear links?
you are planing on making new ones right? i would think having them like that would put to much strees on the one lower link.
As for the front if it's going to be a off road only set the frount up to were you can get the most flex with out binding your joints. but don't go more then 6deg. i have mine set at 6 front and rear (bouth are front axels) and i think it will work out fine
just my two cent
1964 fj-buggy (grass hopper)
42 tsl, bead locks
chevy 350 propane
2.5 ton rockwells
f/r ram steering
onboard air, onboard welder
onboard attitude.
www.lcspec.com
green grass hopper is offline   Reply With Quote Quick reply to this message
Old 12-12-2002, 04:45 PM   #14 (permalink)
Member # 2511
Send a message via AIM to Rootbass
Re: Pinion angle for Rockwell?
Toddy
The question really is when are you gonna be running leaf springs? 10 years from now. Your piece of shit will never run.
84 4runner
Vortec 4.3 th350 ->Dual cases, arb and Detroit on 35" swampers
Rootbass is offline   Reply With Quote Quick reply to this message
Old 12-13-2002, 02:16 PM   #15 (permalink)
Member # 1136
I think you need to start calling Kenny mommy. Every time your shit is broke you call and say mommy mommy Hel pmy shit is broke. hell you cant even get your junk to his shop without somebody holding your damn hand.
Toddy
IROCWEL
Old 12-13-2002, 04:20 PM   #16 (permalink)
Member # 8813
Send a message via Yahoo to ROCKTOY74
Toddy
BAAAAA HAAAAA HAAA THAT IS FAWKING HILARIUOS TODD! MOMMY MOMMY! THE RAINBOW RUNNER IS BROKE
84' XTRA Cab, 22R, R151, Dual cases W/Marlin Crawler 23 Spline 4.70 Total Spline and 23 spline 2.28 Crawlbox, Alcans, Bilstein 5125's, HP 529, V6 529, HAD Shafts, FROR Full Floater, Old School AllPro Crossmember, Marlin Crawler High Steer, Marlin Crawler Bumpers and Sliders!
ROCKTOY74 is offline   Reply With Quote Quick reply to this message
