Water pump gaskets - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-13-2012, 01:29 AM   #1 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
Water pump gaskets
What do you use? If it comes with a paper gasket do you use it? Do you add RTV to it? Do you just use RTV all together?
Did a timing belt/water pump on my parents e30 and the damn thing is leaking. Surface was 100% clean and I scrubbed it with some wheel wool. I'm kicking myself for not adding some RTV to the flimsy, thin paper gasket
NorCalPR is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 01:57 AM   #2 (permalink)
Member # 122979
permatex right stuff, works great in a variety of applications. I've used it in place of hundreds of supplied paper gaskets with 0 issues.
rocklobster87 is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 05:06 AM   #3 (permalink)
Member # 163633
iv always added atleast a thin layer of rtv on either side of the gasket IF i run the gasket. way i see it is it never hurts to run a lil rtv.
have fun redoing it
socal nick is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 05:27 AM   #4 (permalink)
Member # 109289
On water pumps I've just run RTV
fal308 is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 10:28 AM   #5 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
Update: I was told the best shit to use for thin flimsy gaskets is the brush on aviation shit.
Car leaks 2 weeks later.
Wtf, the water pump has gotta be fucked up. I triple checked everything before assembling
Sent from my iThingy using Tapatalk
Old 04-06-2012, 10:31 AM   #6 (permalink)
hurleygo3's Avatar
Member # 80862
Gasgacinch on all paper gaskets.
Biggest problem I see is people over tightening shit.
Mike Johnson #43 7 time EMC KOH finisher, 6 top 5's
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 10:40 AM   #7 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
Used a inch lb torque wrench to torque to 15 ft lb
Old 04-13-2012, 10:04 AM   #8 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
Think I found the problem. Too much belt tension tweaking the wp housing. Only 3 bolts holding it on
Old 04-13-2012, 12:01 PM   #9 (permalink)
Member # 35904
A good question.
If the parts are new, clean and no pitting just a little blue Hylomar. Another replacement is 3-Bond. Sometimes called "Yamabond"
Its used when the surfaces are precision machined and you don't use a gasket. I would have used it in the application you described, and it would not leak)
If the surface is pitted, sees high temps or pressures I "upgrade" to High Temperature Anaerobic Flange Sealant. (Permatex)
Why not to use silicone?
1. It actually does not stick as well as you think it does.
2. Once cured, its "done". Any movement will cause it to "fail"
3. It can "Spit" the gasket under clamping force. (Its "Slippery, and can shear off the sealing surfaces)
4. You don't see silicone used to seal gasket surfaces on aircraft on in anything that "counts"
Do I have a tube of silicone in my trail box? Hell yes.. works great on sidewalls..
"Blue" 86 4Runner Fully Restored Garage Queen
"SandFlea" 93 PU, 22RE. R.I.P, old buddy :(
[B][COLOR="SeaGreen"]Projects[/COLOR][/B]
[B][COLOR="DarkOrchid"]"FireFly" IFS; IRS[/COLOR][/B]
[B][COLOR="Lime"]"Texas Full-Pull"[/COLOR][/B] Winch. Coming to a competition near you soon
Toys
31' Fiver
08 Japanese Market WR-250-X SuperMoto
Tow rig, 03 GMC Sierra, Duramax, Allison
Elvis-n-Texas is offline   Reply With Quote Quick reply to this message
Old 04-13-2012, 12:32 PM   #10 (permalink)
Member # 32437
I do both sides of pretty much any gasket with Permatex non-hardening gasket sealant. I hate leaks & rarely get any gasket surfaces leaking if I do it this way. It is a royal pain to clean up though when you pull things apart....and its pretty much permanently on anything it gets smeared on.
78 CJ-5 (now a CJ-7), 351W, T-18, SOA, etc.
78jeepstang is offline   Reply With Quote Quick reply to this message
Old 04-13-2012, 04:50 PM   #11 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
Yarp, I used aviation form a gasket, it's similar to hylomar.
Sjit works good, it sealed up my drive flanges where the rtv did not
Old 04-13-2012, 04:59 PM   #12 (permalink)
Member # 48682
+1 works much better than regular rtv.
BumpyDodge is offline   Reply With Quote Quick reply to this message
Old 04-13-2012, 06:03 PM   #13 (permalink)
Member # 53528
ultra black rtv, if you prep it right the shit will need a a hammer and pry bar to get it off. any time i have a problematic area that is what i use, works great.
Old 04-14-2012, 05:26 AM   #14 (permalink)
Member # 210335
I use a skim coat on both mating surfaces of the gasket with the Permatex gray stuff meant for anti-freeze, otherwise I usually use the ultra black for everything else.
4x4prepper is offline   Reply With Quote Quick reply to this message
