bearing question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-25-2012, 01:50 PM   #1 (permalink)
the frog's Avatar
Member # 10471
bearing question
a pinion bearing usualy revolves 7-8,000 rpm at the most.
if such a pinion is made to revolve at about 25,000 rpm(for example - if the drive shaft is attached to the axle side of the diff instead of to the pinion side),will the bearing hold? will it burn? will it hold but will not last very long?
are there special bearings that are made to hold such rpm??
thanks to those who can answer based on real knowledge and experience.
[SIZE="4"][COLOR="Navy"]NOTHING[/COLOR][/SIZE] matters
the frog is offline   Reply With Quote Quick reply to this message
Old 03-25-2012, 03:41 PM   #2 (permalink)
Member # 10736
All I can offer is that there is a thread on here somewhere about an axle that was found in the junkyard with two pinion gears. The cover had been modified to have a pinion bearing and support a rear drive pinion shaft.
That's all I got.
masonmachines is offline   Reply With Quote Quick reply to this message
Old 03-25-2012, 03:50 PM   #3 (permalink)
X-Rated's Avatar
Member # 72707
A pinion bearing would only see 8000 rpm in a vehicle going turning 6500 RPM in over drive, basically doing 150mph plus. Realistically, it is designed to turn at 1500-3000 rpm normal highway speeds....
X-Rated is offline   Reply With Quote Quick reply to this message
Old 03-25-2012, 04:19 PM   #4 (permalink)
onetoncv's Avatar
Member # 2160
you have my attention -what are you making ? I am thinking to have these kinds of rpms a ball bearing maybe even a swiss one would be needed . Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 03-25-2012, 04:29 PM   #5 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Ceramic bearing?
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 03-25-2012, 10:37 PM   #6 (permalink)
In the Dark
cnagpilot's Avatar
Member # 128178
Many turbine engines runs those RPMs and higher, Very dangerous at those speeds when something comes loose though...
." Dude... I can't help it! I'm an IDIOT! "
cnagpilot is offline   Reply With Quote Quick reply to this message
Old 03-26-2012, 03:09 PM   #7 (permalink)
the frog's Avatar
Member # 10471
i'm building something which involves two diffs mated together - the first gets power from a transmision to the axle side of the diff and puts the power out through the pinion and from there to another pinion of another diff which exits the power via the second diff's axle side.
that means reasonable rpm in/high rpm out/high rpm in/reasonable rpm out.
so there's no problem with both ends but ther is a speed issue in the middle where the two pinions see very high speeds which seems to be problematic.
Old 03-27-2012, 12:33 AM   #8 (permalink)
the frog's Avatar
Member # 10471
Originally Posted by trkklr77 View Post
turbine motors have zero lateral load on the bearings, fwiw.
pinion bearings get side loaded perportionaly to restance and shock load.
in what i'm building there's no lateral load at all.
