Impco Model E question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-06-2012, 07:25 PM   #1 (permalink)
Member # 63299
at the 6 o'clock position on the front face of an Impco Model "E" regulator there is a gold colored screen. what is the function of this part? i have a model E but the gold screen on mine has been replaced by a pipe nipple and I dont know what goes there. it is definitely pulling a vacuum so I have a hard time believing that nothing goes there otherwise it would fill the regulator up with dust and dirt. I finally got my rig running today and cannot get the idle down to a reasonable RPM and I am wondering if this piece missing is part of my problem. If I block it off with my finger it kills the engine so I suppose it has to see some amount of air flow, but can someone explain? I also have a 300a on top of the engine, if anyone has a good resource for tuning I would appreciate a link or advice. thanks!
SXOR Buggy--The Lone Survivor Foundation buggy
www.Lonesurvivorfoundation.org
Spacecwboy is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 07:31 PM   #2 (permalink)
Member # 94400
That's a port that can be used to connect the regulator to the carb. If you look on the carb it should have one too. On the two pane setups I've built neither had it hooked up.
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
[QUOTE=Blase;15022725]what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster:D[/QUOTE]
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 08:56 PM   #3 (permalink)
mj
Member # 1919
should say "BAL" right beside the port indicating balance line to allow reg to compensate for filter restriction (or boost)
without it hooked up you will run richer as air filter plugs
mj is offline   Reply With Quote Quick reply to this message
Old 04-06-2012, 11:12 PM   #4 (permalink)
Member # 63299
What does it hook to?
Old 04-06-2012, 11:51 PM   #5 (permalink)
mj
Member # 1919
on the 425 there is a port marked 'BAL'
prolley has a pipe plug in it on yours
Old 04-06-2012, 11:54 PM   #6 (permalink)
mj
Member # 1919
wait a sec read the OP a lil closer..its pulling a vacuum?
then the diaphram is toasted and needs a rebuild kit.
should be ambient pressure to reference the reg, the balance is to reference it to what the mixer is actually seeing
Old 04-07-2012, 01:16 PM   #7 (permalink)
Member # 44692
then the diaphragm is toasted and needs a rebuild kit.
if it is a constant vacuum, then yes.
going by my model L, the area inside is sealed. so when vacuum is placed on the propane vapor port, is sucks the diaphragm down, which will cause a lower pressure area inside the evaporator above the diaphragm and will force air into the port until it is equalized. if you plug it up like you say, it will be impossible for the evaporator change the flow of propane vapor either increasing or decreasing without enough force to stretch the diaphragm.
here is how it is hooked up on my setup with model L and 125. red hose is balance hose.
can browse through my account to see images of how the L is assembled and the 125 to get an idea of what happens inside.
http://s5.photobucket.com/albums/y17...cpZZ1QQtppZZ20
use PW pirate.
crimsen is offline   Reply With Quote Quick reply to this message
Old 04-07-2012, 06:08 PM   #8 (permalink)
mj
Member # 1919
I never said to plug it up.
