Sprung weight question? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2012, 05:42 PM   #1 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
I used old coils today to measure for sprung corner weights to order new springs for the buggy. They came in at 500 each for the front, 450 each for the rear. Does this mean my total sprung weight is 1900lbs or is there some complex math involved? Just trying to get an idea for the total weight of the rig.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 04-07-2012, 06:14 PM   #2 (permalink)
Member # 55444
If you use a 500lb coil, and it compresses 1", its supporting 500lbs. If you have a 500lb coil on every corner, and it collapses 1" per corner, the sprung weight is 2000lbs. Theres a calculation for angle and distance from center of axle, so thats for a verticle coil, but its pretty close.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 04-07-2012, 07:27 PM   #3 (permalink)
Member # 100827
I was thinking it was that simple but just checking, used 4 100# coil it compressed 5" in front and 4.5" on the rears.
Old 04-07-2012, 08:31 PM   #4 (permalink)
Permanent Newb
Cooter!'s Avatar
Member # 176672
That adds up to 1900# to me, as long as all your shocks are vertical. Light buggy!
If the answer to your diagnostic test is indeterminate, you must enlarge the context of the question.
Peterson's 4 Wheel & Off-road UA2014 Alumni.
Cooter! is offline   Reply With Quote Quick reply to this message
