#1 (permalink) | |
Member # 198356
ARB compressor & external tank
I've thought about hooking up my ARB Compressor to an external tank, that has more volume then the small tank on the compressor, I did a search here and couldn't find what I was looking for.
What I would like to see is pic's of people that have done this. Is this a good idea? Or will I be taxing the compressor too much. My main goal is to have extra air for airing tires, and for the lockers. I currently have the CKMA12 compressor.
'74 FJ40 '76 FJ55 (New Addition) |
Member # 98722
Its a great idea, I sell arb compressors, so we will have a great relationship!
TTC JUDGE No, I'm the real Dan Black!!!! www.arabiasoverkill.com[/url] |
Sponsored Links |
I thinking airing up tires with an ARB compressor is painfully slow and that's what kills them.
I had a 1 gallon tank on my ARB and loved the fact I could go wheeling for a weekend and after the initial fill up I never had to hear that little thing rattle again. I just put a T on the pressure fitting and ran a line to the tank.
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
#4 (permalink) | ||
Member # 198356
Permanent Newb
Member # 176672
Do NOT try to use your ARB compressor to fill fawking tires
![]() Ever tried to kill an elephant with a BB gun? There is a reason that compressors meant for filling tires are expensive.
If the answer to your diagnostic test is indeterminate, you must enlarge the context of the question. Peterson's 4 Wheel & Off-road UA2014 Alumni. |
#6 (permalink) | ||
Member # 198356
I have the compressor setup now to just run the lockers.
Permanent Newb
Member # 176672
Nice version:
How is using a waaaaaaay too small compressor to fill a tank...then a tire, any different from using the same waaaaaaay too small compressor for filling a tire directly? Not nice version: Oh, never mind then. I didn't realize the compressor filled the empty space inside a tank before it went into an empty space to fill a tire. That should magically solve the problem of the waaaaaay too small compressor? At least (hopefully) you'll be at the end of the trail airing up (and out of my way) when you explode the tiny, ARB compressor and lose your lockers ![]() The size (7mm) of the blue air line should be the first clue. I'm really trying not to be a dick, but seriously? Have you EVER typed "air compressor" in Google? Have you EVER shopped for on-board air of any kind? Have you noticed the size of compressor they use to fill your tires at ANY tire shop? Clue, it's big. Have you ever used the 25 cent machines at a gas station? Clue, it's tiny but still bigger than yours. It would LITERALLY be faster to use a bicycle pump, and the bicycle might even fill all 4, once before dying.
#8 (permalink) | |
Permanent Newb
Member # 176672
#9 (permalink) | ||
Member # 198356
I didn't plan on putting an extra tank in, just a thought I had. Thanks for the great info, no sarcasm, no joke.
#10 (permalink) | |
Member # 10063
Straight from ARB's web page:
I've been using my ARB comp to air up tires for over a decade now (and occasionally buddies who are too lazy to get their own compressor's tires too ![]() I'll concede that I've noticed the thing does get damn hot after a bit though (I put a decent-sized DC computer fan blowing on it wired in with the compressor motor so they both run at the same time). As for the external tank, the only thing that'll get you is not having to hear it run as often like Welndmn mentioned. Unless the tank is huge, it's not going to quicken the filling of your tires by any noticeable amount (but could allow the use of some air tools for short bursts).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s http://www.supermotors.net/22445 |
www.patparts.com
Member # 4821
I used to have my ARB compressor plumbed into an external tank and it worked fine. The compressor is small and slow to fill tires with but faster than not having one at all.
J. J.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#12 (permalink) |
Permanent Newb
Member # 176672
I have a crispy new dollar for you if the OP is using the latest/greatest CKMT Dual headed ARB compressor that is MEANT to fill tires...
If he bought that one, he never would have asked the question. Because it's all over the BOX IT COMES IN. Although he never gave a part #, my assumption was that the OP bought the standard compressor to run the lockers alone, and was asking if he could use it to fill tires. Since I believe its the baby one...NO, he can't. (edit) Wait a sec... COULD use it? (maybe if he's being chased by hungry Zombies), or SHOULD use it (still no)? Helpful linky: http://www.arbusa.com/uploads/PDF/ne...A12_retail.pdf
If the answer to your diagnostic test is indeterminate, you must enlarge the context of the question. Peterson's 4 Wheel & Off-road UA2014 Alumni. Last edited by Cooter!; 04-12-2012 at 06:35 PM. |
#13 (permalink) | |
Member # 92250
I have used a CKMA12 with a 9L tank for about 3 years now. My lockers run off the 9L tank. Regularly used to pump 35'' tyres from 7 psi to 35psi, never any problem. The extra head of air really heaps when seating beads etc too and I can run my 1/2'' rattle gun too. |
#14 (permalink) | ||
Member # 10063
You must not be paying attention. The link I posted was not for the CKMTA12 either. ![]()
#15 (permalink) |
"So what makes this compressor special? It's small enough to fit into even the tightest space and quiet enough to mount in the cab. It has enough output to air up four 35" - 37" tires in a single duty cycle and typically airs up a 35" tire in just over two minutes. And, it works. We've tested this unit in ovens, freezers, underwater and in the silty dust of the Simpson Desert and it continues to perform."
Sent from my DROIDX
Size does matter. Leave the Zukes to those who really understand. |
#16 (permalink) | |
Member # 113181
#17 (permalink) | |||
Member # 198356
I've never had to air down my tires, all though it would have been nice at KOH, but I didn't. Quote:
Thanks for the info.
#19 (permalink) | ||
Member # 198356
#20 (permalink) |
Permanent Newb
Member # 176672
Yup, totally missed the part # posted by the OP. Sorry dude.
I'll get my suitcase and report to the fail thread now. But it's still too small IMO ![]()
#21 (permalink) | |
Member # 198356
It's all good. I figured it was too small, but it was just a thought.
#22 (permalink) |
Member # 12920
If you've ever tried to re-seat a bead with out starter fluid having an air tank helps a lot. If you plump a small compressor to your air tank you can cycle it on an off multiple times over the day to fill your tank with out killing the compressor. Heat from running the compressor over it's duty cycle kill the motor.
I've used this method to re-seat 42"s. I wouldn't do this to get tires back to street pressure because it would take for ever, but it's definitely come it clutch at times |
#23 (permalink) |
Member # 193488
I fun-king love the attitudes here
![]() And appreciate all the info too , I'm looking for a small 12V compressor for running air tools ( impact) and airing tires back up . Regardless of what I decide on , I'm hooking up a separate tank and will incorporate a cooling fan for the unit . I'm liking the specs on this unit , seems pretty decent for the $150 price . ![]() Compressor Amps 45.0 amps Maximum Pressure (psi) 150 psi CFM 5.65 Air Lines Included Yes Pressure Gauge Included Yes Case Included Yes It claims the max duty cycle is 40 minutes . I'm not looking to spend $400-$500 on a 12V compressor and this will prolly fit the bill nicely ......we'll see .
[B][SIZE="2"][COLOR="Lime"]Μολὼν λαβέ -[/COLOR] [COLOR="Navy"]"Percussa Resurgo"[/COLOR][/SIZE] [SIZE="2"][COLOR="Red"]FBHO !![/COLOR][/SIZE][/B]:flipoff2: 04' RAM ~ 94' RAM ~ 2010 German Shepherd :smokin: Last edited by GUNSLINGER 67; 04-22-2012 at 12:05 PM. |
#24 (permalink) |
Member # 121349
The CKMA12 will air up 33's fine for what it is.
It will be hot as hell afterwards, but it will do it. The dual arb compressor(CKMTA12) is just two CKMA12 together with a cooling fan and a 150psi pressure switch. Now for clarification, if someone was trying to air up tires with the CKSA12, they would have problems. That compressor is obviously too small. I thought a slightly less Ignorant post was needed in this thread!
Vince |
#25 (permalink) | |
Member # 198356
A bump to this thread...
Currently I have the tire inflation kit, which comes with the coupler that the hose attaches to, I want to move that coupler to another location, basically extending it. Any idea on what type of fittings I need to make this work, or where I can buy them?
Thread Tools | |
Display Modes | |
